Differential leak opinion (pic) - TCCoA Forums
post #1 of 5 (permalink) Old 08-04-2009, 09:56 PM Thread Starter
So I discovered this morning that my differential seems to be leaking. I searched around and understand the process to repair the rear seal and found some info on replacing the seals at the halfshafts.
My question - based on the picture below, does it look like the right seal could be only thing that is leaking and is just dripping down the side of the case to make it look like that it's leaking too? I'd prefer to keep the work to a minimum for now, so if I only have to replace the right seal vs. right seal + remove the cover and RTV that... I'd prefer to simply do the right seal. But if it simply makes no sense to not re-RTV the rear cover then I suppose I can handle doing that. I just have a very limited window to have the car non-roadworthy.
I have never seen any spots on the driveway from the leak.
post #2 of 5 (permalink) Old 08-04-2009, 10:53 PM
sik97bird's Avatar
by the looks of it you will need some new axle seals, and a diff cover seal. for the diff cover you can just use some RTV. it's not hard at all to replace the axle seals.
I'M BACK
97 Supercharged Ford Thunderbird with warpdrive
Check out my Gallery
vist the Man RobertP at www.robstireandauto.com
sik97bird is offline
post #3 of 5 (permalink) Old 08-05-2009, 11:34 AM
I bet it's all the axle seal but might as well change the fluid and reseal it all.
post #4 of 5 (permalink) Old 08-05-2009, 06:16 PM
sdavis872's Avatar
Mine has a leak out the passenger side axle too. Where could I find info on the seal replacement? Are there any write ups?
sdavis872 is offline
post #5 of 5 (permalink) Old 08-05-2009, 07:28 PM
motor city poster
Red96Bird's Avatar
yes...axle seal...just make sure your vent tube/vent is open and not clogged up..
a lot of axle leaks will come from clogged vents and pressure building up inside the diff.
Red96Bird is offline
