Trac-Loc Swap - TCCoA Forums
post #1 of 9 (permalink) Old 08-28-2009, 03:08 PM Thread Starter
Lx40thbird's Avatar
Trac-Loc Swap
Hey all...quick question. I just bought a 94 LX that doesn't have trac-loc, but I have a 95 parts car with trac-loc. Can I swap the trac-loc from the 95 to the 94? The main reason I ask is because the 95 has discs in the rear and the 94 has drums. So my dad said it might be more complicated because they will have diffenerent hubs or axles or something like that. Any info is greatky appreciated. Thanks.
95 LX 40th anniv: Retired, but lives as on as a parts car for my 94. If Anyone needs parts let me know
94 LX V8: Lowered, cone filter and removed resonator.
Soon to come: True duals and more
Lx40thbird is offline
post #2 of 9 (permalink) Old 08-28-2009, 03:10 PM
Faster than Porkchop
cjchevez's Avatar
i think so , I have a pumkin from a cobra . you should be ok !
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #3 of 9 (permalink) Old 08-28-2009, 03:11 PM
Its a direct swap, just use your current halfshafts
post #4 of 9 (permalink) Old 08-29-2009, 05:57 AM
Swap in the rear discs while your at it!
post #5 of 9 (permalink) Old 08-31-2009, 10:09 AM
Texas Chapter Director
Send a message via AIM to speed95 Send a message via Yahoo to speed95
What if he was to just swap over the whole subframe?
speed95 is offline
post #6 of 9 (permalink) Old 08-31-2009, 10:31 AM
jco1385's Avatar
similar question... i found a '90 SC. iirc, they are t/l 8.8. this should swap right into my 94, correct? what about the half-shafts?
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #7 of 9 (permalink) Old 08-31-2009, 02:20 PM
You could, but its not at all worth the effort for a pumpkin swap.
Yup, direct swap.
post #8 of 9 (permalink) Old 08-31-2009, 02:35 PM
Oh I know it would be pointless for just the pumkin but the guy before me said to swap out the drums for the disks. Thats why I figured it might be easier to just swap it all out at once. It would also be a good time to see if any bushings need to be replaced. Plus he could clean up the rust and paint if he wanted. I wish I would of done that when I had the parts car.
speed95 is offline
post #9 of 9 (permalink) Old 08-31-2009, 02:42 PM
Even then I wouldnt do it. The subframe bolts like to snap or the nut inside the body likes to break on these when removing the subframe. The amount of effort involved in fixing that isnt worth it.
All you need for a drum to disc swap is the knuckles, flex lines, calipers and rotors, the knuckle assembly needs to be partially removed for a pumpkin swap anyway, so its pretty low effort.
