1997 Tbird sport rear questions - TCCoA Forums
post #1 of 10 (permalink) Old 10-21-2009, 05:42 PM Thread Starter
1st question: What info on my door sill tag will tell me if I have a trackloc or an open rear in my car?
2nd question: Is my car an independant rear suspension? Does that mean it is set up in the back like a front wheel drive?
3rd question: I was told if it was an open rear I would have to swap carriers. How much do the trackloc (both wheels) carriers generally go for on the used market?
Thanks folks!
MadMatt4.6 is offline
post #2 of 10 (permalink) Old 10-21-2009, 05:46 PM
1---Axle code -------check tech articles under gears/gears for axle codes.
2---yes....yes more or less.
3---I picked up both of mine used and functional for 150 bucks each. Smokin deal though I think.
blueMN12 is offline
post #3 of 10 (permalink) Old 10-21-2009, 05:53 PM Thread Starter
Originally Posted by blueMN12 View Post
1---Axle code
Thanks for the quick reply! Damn that was fast! Ok,
1: Is the code on the rear end or the door sill?
2: Gotcha
3: Each? Are there two separate carriers in and independant rear end?
post #4 of 10 (permalink) Old 10-21-2009, 05:55 PM
its on the door sill AND on a aluminum tag on one of the diff bolts.
There is one carrier (pumpkin) per car. I have two cars, so I needed two tracloc diffs.
blueMN12 is offline
post #5 of 10 (permalink) Old 10-21-2009, 06:20 PM Thread Starter
It's raining like hell out here. What part of the door sill sticker gives the info? The only part I could see that might be pertaining is R0081
post #6 of 10 (permalink) Old 10-21-2009, 06:23 PM
Where it says axle on the sticker.
post #7 of 10 (permalink) Old 10-24-2009, 08:07 AM
The label sit in the rear of the door opening under the lock. In the end of the label there are some letter witch says TAPE R S AX TR. Under the AX will you find what type of axel you have. On my -94 T-Bird it says Y, which means that it is a conventional with 3.08
Berth is offline
post #8 of 10 (permalink) Old 10-25-2009, 05:20 PM Thread Starter
Thanks, I have a conventional rear end on the car. What parts are involved in getting to a real track loc rear end? How many splines? I will assist a mechanic friend in the install. I need all the specifics. W5 is the code
post #9 of 10 (permalink) Old 10-25-2009, 09:21 PM
CableguyJJS3's Avatar
Send a message via AIM to CableguyJJS3 Send a message via Yahoo to CableguyJJS3
W5 is a 3.27 open rear end, I had the same in mine from the factory. As far as parts all you need is a trac lock IRS specific differential, and drop it in. Simplest swap you can do to get trac loc is find a SC in the boneyard and snag the pumpkin. Its a direct bolt in swap. Next best thing to do is come up with the IRS trac lock, a Mark 8 aluminum pumpkin and whatever gears you want and have the whole thing assembled fresh, and then its still a direct bolt in swap. Just an FYI, the Explorer IRS or any straight axle trac lock wont work for vairous reason without modification. Yes they can be made to work, but they need extra work. Your best friend is an SC in the yard and/or a Mark 8, even though the Mark 8 got 3.07 open rears, they had the good aluminum pumpkin, or find a 99-01 Cobra rear as they had the 3.55 aluminum 28 spline trac loc rear that bolts right in as well.
Ban low performance driver's, not high performance cars.
"Any idiot can make a Mustang fast, but it takes a special kind of idiot to make a Thunderbird fast."
CableguyJJS3 is offline
post #10 of 10 (permalink) Old 10-26-2009, 02:18 AM
It'd be a lot easier and cheaper to just buy a used traction lok pumpkin and swap yours out. Unless you feel the need to have a completely rebuilt unit in your car, used ones are usually in very good condition.
Decy is offline
