Trac-Lok questions, help and opinions. - TCCoA Forums
post #1 of 3 (permalink) Old 11-21-2009, 09:49 AM Thread Starter
Question Trac-Lok questions, help and opinions.
So a buddy of mine gave me a trac-loc out of a 1986 mercury capri... It has 40K on it and was pampered most of it's life. It also came with the gears from the capri. My buddy thinks there 3.73's but i wanna check them to be sure. If they are 3.73's can i swap them into the bird without massive problems? I know on the trac-loc i have to bevel the gears or take my cir clips off and i am looking at just taking the clips off. I will be doing axle seals when i am doing the trac-loc or trac-loc and gears. I don't remember everything i had to do the last time i broke an axle and replaced it so I am hunting for info on it and it's been years since i have played with a rearend and the last one i played with was a 9 inch.
So i guess what i am asking here is for a daily driver is the trac-loc a good thing, Would the other gears if there 3.73's be a good idea, does the trac-loc help in the snow at all, Did i miss a writeup on doing the gear swap and track-loc install? Any comments advice and all is appreciated.
SvoSvt88 is offline
post #2 of 3 (permalink) Old 11-24-2009, 08:41 AM
CometGSR's Avatar
From what I gathered, it is best to have a Trac-Lock unit from a IRS car, otherwise you run into some issues. Do some searching around, there is enough info here to get a pretty good idea on how good they work in the MN12.
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #3 of 3 (permalink) Old 11-24-2009, 05:37 PM Thread Starter
Yea that is what I have been told and read also. I was told by a fellow member who i have known for years that the one from the capri would work with little modification. I was just asking if the gears would be the same and if the case had to come out of the car to do it or if i could leave the case in and do it.
SvoSvt88 is offline
