How to machine side gears on solid trac loc. - TCCoA Forums
post #1 of 8 (permalink) Old 12-26-2009, 04:14 PM Thread Starter
djoc2000's Avatar
If I pick up a solid axle trac loc how do I machine it to work properly ? Pics would be a n awesome bonus.. And is it hard to do ??
You can go as fast as your money will let you
djoc2000 is offline
post #2 of 8 (permalink) Old 12-26-2009, 04:43 PM
There is a diagram floating around on what needs done. It must be tough, I can't get any machine shops locally to tackle it. They are hardened gears, but I am going to take an afternoon and use a dremel and see what I can do. I know people have done it, but I don't feel good leaving the circlip off.
Bangster is offline
post #3 of 8 (permalink) Old 12-26-2009, 06:36 PM
You need to bevel the inside edge so that the circlip will compress when you go to pull the axle out. The easiest way would be to take a side gear and an inner axle joint and as soon as you slide it on you will see what needs to be beveled. By doing it out of the diff this way, you can use a pick to pull the circlip off, grind the inner part of the side gear, and retest it until you get it right.
post #4 of 8 (permalink) Old 12-27-2009, 04:45 PM
392Bird's Avatar
Here is what you need.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #5 of 8 (permalink) Old 12-27-2009, 09:36 PM
CometGSR's Avatar
Send an email to [email protected]. Mike rebuilds these and offered to machine the modification for me. It wasn't cheap though, you might be better off getting a IRS Trac-Lock.
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #6 of 8 (permalink) Old 12-28-2009, 08:00 PM
94TchikinV8's Avatar
Send a message via AIM to 94TchikinV8 Send a message via Yahoo to 94TchikinV8
Alan @ dirtydogperformance.com machined mine down for me. He chucked them in a lathe and had them done in about 5 minutes while I watched.
-Rob
1994 Thunderbird LX V8
Still in pieces in the garage awaiting body work, paint, and a drivetrain...
Currently driving a 98 Mustang GT convertible:
02 Explorer engine, Comp 262ah cams, Steeda underdrives, aftermarket H-pipe with high flow cats, SLP LM1 exhaust, MGW shifter, RAM clutch
[email protected], 2.17 60ft(stock 2.73s, worn-out trac-lok)
94TchikinV8 is offline
post #7 of 8 (permalink) Old 02-28-2019, 01:36 AM
Just re-posting the drawing, I don't see it in the above posting anymore. Thankfully this guy saved it a few years ago: IRS | A Turn of the Nut
Yellowoctupus is offline
post #8 of 8 (permalink) Old 02-28-2019, 07:54 AM
T6Rocket's Avatar
That is good to have. I have a copy of it somewhere. The issue is, if you find an original 28 spline Trak-loc for sale, it's a crap shoot whether it's the newer style with beveled gears, or the older style without. They both have the same part #, IIRC it's M4204-F288.
I bought two off E-bay over a 6 month period, and ended up selling the one for the solid axle to a guy with a Crown Vic.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
