Are all 8.8 gears the same? - TCCoA Forums
post #1 of 10 (permalink) Old 12-26-2009, 04:15 PM Thread Starter
RCReevesPhotography's Avatar
I can't seem to find a Yes or No on this.
I have a set of 3.55's with a Trac Loc out of a Mustang with an 8.8, will they work in an 97 Tbird with an 8.8?
I called Jegs they told me yes, I looked it up online and it told me yes, I looked it up on here some say yes, some say no.
Help needed....
"Dream like you will live forever, live like you will die today"
RCReevesPhotography is offline
post #2 of 10 (permalink) Old 12-26-2009, 04:28 PM Thread Starter
OOPS.....
http://www.tccoa.com/articles/mn12-t...action-lok.htm
Never mind..
post #3 of 10 (permalink) Old 12-26-2009, 04:29 PM
Raptor22's Avatar
I know sometimes the number of splines changes in each application, I believe my F-150 8.8" 3.55 Trac loc is 31 spline, but the one in my Mustang is 28 spline...
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #4 of 10 (permalink) Old 12-26-2009, 04:33 PM Thread Starter
"The MN12 8.8 and 7.5 differentials use a 28-spline shaft. The difference between the standard solid axle and the IRS differential is a "Step" (grove) in both differential side gears in order to retain the Circlip (C clip) that holds the Halfshafts in place"
So my question is now, could I take the both differential side gears and swap them for the ones in my car now and make this work?
post #5 of 10 (permalink) Old 12-26-2009, 04:59 PM
Raptor22's Avatar
hmm, makes sense. I aint never done it though...
Raptor22 is offline
post #6 of 10 (permalink) Old 12-26-2009, 05:22 PM
The 8.8s will swap back and forth between ford setups. There's no difference between any Ford 8.8 gears of a given ratio that I know of.. it's just a ring and pinion. The difference comes in the side gears. Solid axles are retained via a C clip. Our half shafts are retained at the hub. The pumpkin side slides and "snaps" in. The reason the IRS gears have a bevel cut into them is so that with a little bit of prying pressure, you can pop them back out. Solid axle side gears have a step groove cut into them to retain a C-clip that holds solid axles in the housing. The pumpkin side of the half shaft will go in and pop into place.. but you'll have a heckavu time trying to get it back out... more than likely, you would have to pull the rear cover to get the half shafts back out. The side gears, I believe, are interchangeable between same type differentials, swap the step-groove side gears for the IRS gears in a traclok. I'm not sure on if they're the same from open to traclok differnential.
a black car.
Sophosis is offline
post #7 of 10 (permalink) Old 12-26-2009, 05:38 PM
dDUBb's Avatar
Ford Racing FRPP ring and pinon are not the same quality as Ford Factory OEM.
dDUBb is offline
post #8 of 10 (permalink) Old 12-26-2009, 08:35 PM
Fine, then I'll rephrase for you..
As far as fitment and usability, ford ring and pinions will swap.
a black car.
Sophosis is offline
post #9 of 10 (permalink) Old 12-27-2009, 01:20 AM
There is a difference between 8.8 FRONT diffs and 8.8 REAR diffs. The ring & pinions are NOT interchangeable. Factory Ford or FRPP gears are generally accepted as being best quality and easiest to set up. Everyone has their own opinion, though.
Decy is offline
post #10 of 10 (permalink) Old 12-27-2009, 08:47 AM
No you can't. The side gears for a trak-lok unit are not interchangable with the side gears for an open rear. You need to either modify the solid axle side gears or get a trak-lok unit for an IRS car.
