changing diff lube - TCCoA Forums
post #1 of 13 (permalink) Old 12-29-2009, 07:51 PM Thread Starter
Mgino96tbird46's Avatar
changing diff lube
Hey guys, how much of a PITA is it to change out the differential lube? It's getting very close to 100K miles and I want to do it. What is involved in this job?
Mgino96tbird46 is offline
post #2 of 13 (permalink) Old 12-29-2009, 09:05 PM
Icarus's Avatar
You need to take the cover off, or suck the fluid out. The latter being easier, but then you can't see what it looks like inside nor get it near as clean.
Taking the cover off can be a pain if the bolts holding the rear mount to the subframe or cover don't want to move. You can either undo the two attaching the hanger to the cover, or the two attaching the hanger to the subframe. The first is the easier way, but it will a bit harder to get the cover off then.
Wipe out the insides once the cover is off with lint free rags, and clean the mating surface and cover well.
Put a bead of sealant on the cover continuously around the inside of the bolt holes (theres a groove there to follow,) and reattach the cover (20-27 lb-ft).
Reattach the hanger bolts (either way above-~90 lb-ft)
Let sealant dry a bit and fill till its level with the fill plug. If it's a Traction-Lok unit, make sure to add a bottle of friction modifier as well...
Ϣr
1994 Lincoln Mark VIII
4.6L DOHC; meter4it.com chase/sequential tail lights; 20" Giovanna Dalars; 4.30 gears; FRPP Track-Lok; SCT tuned; Baumann ReCal; Addco bars; Cobra brakes...
RIP - '86 Mark VII LSC
Icarus is offline
post #3 of 13 (permalink) Old 12-29-2009, 09:31 PM Thread Starter
I know the cover bolts to the subframe. Do I need to support the differential housing when I take those bolts out? Thankfully, this should be relatively easy since there is very little corrosion around that area. I have the conventional differential (code 5), do I still need the friction modifier?
post #4 of 13 (permalink) Old 12-30-2009, 01:46 AM
Icarus's Avatar
If you don't have a Traction-Lok, you don't need the modifier.
Put a jackstand/blocks under the pumpkin so it stays in place. Better than having to wiggle it around to line it up again if it does move to much, as it will drop some. The driveshaft and front mounts will hold it but best not to put all the weight on the front diff ears...
Ϣr
Icarus is offline
post #5 of 13 (permalink) Old 12-30-2009, 02:10 AM Thread Starter
okay, sounds good. I was worried about that. Especially since none of that stuff has really been touched in 13 years.
post #6 of 13 (permalink) Old 12-30-2009, 11:31 AM
an air or battery powered ratchet would help you out a lot to loosen the cover bolts. An impact would help for the subframe nuts.
Also, the subframe nuts may need a wrench on the bolt head to keep them from spinning.
tbirdguy is offline
post #7 of 13 (permalink) Old 12-26-2014, 01:59 PM
Can someone clarify this part some more? I got the two large bolts going across the cover to back out some but cannot fully remove them. Do I just need to lift the pumpkin with a jack to align the holes?
I used drive-on ramps to get under the car, so the suspension was loaded. Does this have anything to do with my problem?
mustang46kid is offline
post #8 of 13 (permalink) Old 12-27-2014, 05:09 AM
You need to support the pumpkin.
post #9 of 13 (permalink) Old 12-28-2014, 09:21 PM
I've tried jacking up the pumpkin to no avail. The only way I could get the bolts to move a bit is if I stuck a prybar in between the two and even then they would not come out all the way. And now they won't move in either direction.
post #10 of 13 (permalink) Old 12-29-2014, 04:44 AM
rushtonracing's Avatar
Once you're reasonably assured there is no binding, either by the weight of the pumpkin, or supported too high, use a long thin shank drift punch, or a smaller diameter bolt to tap bolts out with a hammer.
1995 Thunderbird LX 4.6l 97 Headlamps/Hood All Red Tails Muffler/Resonator Delete
2004 Tahoe 5.3 4x4
2008 Acadia Limited AWD
...still looking for a clean, low mileage, rust free 96/97 Thunderbird 4.6
rushtonracing is offline
post #11 of 13 (permalink) Old 07-06-2015, 11:25 PM
gordonm1's Avatar
So is it better to have the suspension loaded on ramps or hanging free using jack stands? I didn't see an answer to that question above.
I changed out differentials using jack stands so I would think it would be ok here if you support the differential with a jack.
I'm getting a little noise from my gears so I was maybe going to change fluid completely and look for metal before pulling the differential. My oil looks thin and I suspect it has too much friction modifier because that's all I added through the axle hole and it was overfull.
gordonm1 is offline
post #12 of 13 (permalink) Old 07-07-2015, 07:05 AM Thread Starter
I can't see why not. I think that's how I did mine.
post #13 of 13 (permalink) Old 07-07-2015, 02:59 PM
Rayo's Avatar
When you're changing the Differential..
The only time you want the suspension loaded is when you go to tighten the nuts and bolts of the knuckles/control arms..
Keep the suspension unloaded until you start tightening those fasteners..That way you get things lined back up properly to avoid a trip to the alignment shop..
When you fill the differential..Use 1 (4 oz) bottle of friction modifier then top it off with your favorite gear lube until it starts running out of the fill hole..
If your gear lube already has friction modifier in it..All bets are off how much friction modifier you need to add if any..
I know it's late, but my advice is to completely drain your differential..That means taking the cover off..
Then refill like I suggested..Use 1 (4 oz) bottle of friction modifier then top it off with your favorite gear lube until it starts running out of the fill hole..
Use a gear lube that does not include friction modifier..So you know for sure how much friction modifier is actually in there..
Good Luck with your used Differential..
1991 Ford Thunderbird Sport
Rayo is offline
