Ok to use a gasket for a rear end w/o RTV? - TCCoA Forums
post #1 of 9 (permalink) Old 01-28-2010, 01:01 PM Thread Starter
Well its for an Explorer, 8.8 rear, my diff cover totally rusted out and I got a new one with a free gasket. I usually use Permatex Black RTV, but I'm wondering if I can get away with just the gasket and avoid the mess. It was replaced 2 years ago, my bad for not getting new cover then. I just want to get this over with.
I wonder though if the bolts loosen up a bit if it will seep, the RTV glues everything together.
tbirdguy is offline
post #2 of 9 (permalink) Old 01-28-2010, 01:11 PM
RVT really is not that expencive why not put it on there anyways just so you have that piece of mind that it will not leak
My Lug Nuts Require More Torque Than Your Honda Makes
Tbird64 is offline
post #3 of 9 (permalink) Old 01-28-2010, 01:21 PM Thread Starter
Thanks..
Its not the price but its just a mess, I was just seeing if I can get off easy.
I'm going to use the Black RTV though, I'm thinking if it does leak the job would have to be redone. I don't want to do this again for a long time.
The gaskets are not a good idea, it looks like a flimsy one too on closer inspection. I wonder why they sell those gaskets, even the factory uses RTV. Probably gaskets leak and cause warranty comebacks.
95 4.6L Rusty Survivor!
tbirdguy is offline
post #4 of 9 (permalink) Old 01-28-2010, 01:34 PM
Yeah the cost and the mess out weigh the price of having to do the job twice. I HATE doing that !
Tbird64 is offline
post #5 of 9 (permalink) Old 01-28-2010, 02:39 PM
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
I rec Ultra Grey RTV. I have and never will use a gasket on rear ends.
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #6 of 9 (permalink) Old 01-28-2010, 03:39 PM Thread Starter
Looks like there is a brand new product just for this purpose:
http://www.permatex.com/products/Aut...tv_sealant.htm
tbirdguy is offline
post #7 of 9 (permalink) Old 01-29-2010, 04:31 AM
I buy transmission grade black silicone. It is all I will use on them.
post #8 of 9 (permalink) Old 01-29-2010, 12:26 PM
Mgino96tbird46's Avatar
It's not messy if you use a tip that is usually included with the tubes of RTV these days. The messiest part about changing my differential lube was the lube itself, not the RTV. Just make sure you are thorough with the RTV application. I put 3 constant beads of RTV around my differential cover just for insurance. Not a leak thus far *knock on wood*.
Mgino96tbird46 is offline
post #9 of 9 (permalink) Old 03-12-2010, 08:22 PM
I rebuilt an 8.8 with my buddy at work a couple of weekends ago and we used a little bit of RTV all around the edge and around the holes and then added the paper gasket. It's just a little extra security to keep it in place for install and help it from not leaking down the road.
tbirdsc14 is offline
