Remarkable technical video from the 1930s explaining differential operation in detail - TCCoA Forums
post #1 of 11 (permalink) Old 01-28-2010, 05:26 PM Thread Starter
Thought about putting it in miscellaneous, but this is really good. The real explanation starts at 1:50, but its worth watching the whole thing if you don't understand exactly how a diff works. They use tinkertoys to demonstrate and build it up from there.
95 4.6L Rusty Survivor!
tbirdguy is offline
post #2 of 11 (permalink) Old 01-28-2010, 06:06 PM
white lincoln's Avatar
Nice explanation.
1995 Lincoln Town Car Signature Series - 180k!
1994 Mercoury Cougar XR7 - still going....
1988 Lincoln Mark VII LSC - SOLD!
I've had too many other cars to mention...
white lincoln is offline
post #3 of 11 (permalink) Old 01-28-2010, 06:20 PM
Lovely. This is great heritage, and also a great lesson.
Fender is offline
post #4 of 11 (permalink) Old 01-28-2010, 06:36 PM
good one
post #5 of 11 (permalink) Old 01-28-2010, 07:26 PM
Raoul Duke
cougarcragar's Avatar
The ending was spooky.
1996 Mercury Cougar XR7
cougarcragar is offline
post #6 of 11 (permalink) Old 01-28-2010, 07:47 PM Thread Starter
Amazing how after 80 years this technology is used in every car.
tbirdguy is offline
post #7 of 11 (permalink) Old 01-28-2010, 09:04 PM
Gl@re's Avatar
how is a trac lok different?
post #8 of 11 (permalink) Old 01-28-2010, 10:15 PM Thread Starter
Remember in an open diff 100% of the power is transferred to the wheel with the least traction! That is obvious from the video.
When one wheel loses traction (like on ice) clutch packs lock one of the axles to the differential case (thats why you need friction modifier, it builds friction as the wheel starts to slip and develop heat). Then the axle locks to the case and the wheel on ice starts to spin (along with the other wheel too).
Trac assist uses the rear brake to lock the spinning wheel thru the ABS system. The ABS computer monitors the relative wheel speeds and reacts almost instantaneously when there is a speed delta. When the wheel on ice(slipping one) is locked it becomes equivalent to dry pavement, and the other wheel starts to spin. The locked (formerly slipping) wheel does not have the least traction anymore, so power shifts to the other wheel.
Problem is that usually both wheels are on ice, so it just fights each other. Also, I was playing with it in the snow and I don't think the brakes have the grabbing power to fully lock the wheel.
tbirdguy is offline
post #9 of 11 (permalink) Old 01-28-2010, 10:31 PM
Wow, that was good. Even I understood it.
post #10 of 11 (permalink) Old 01-28-2010, 10:41 PM
beamerboy46350's Avatar
Send a message via Yahoo to beamerboy46350
Nice
92 Cougar LS 5.0: Air Silencer delete, Flowmaster Cat-back System, Big 3,Cold Air Intake,
77 BMW 530i(no longer running will come spring)
02 Caravan SE(DD 4 kids)
beamerboy46350 is offline
post #11 of 11 (permalink) Old 01-31-2010, 02:01 PM
Mgino96tbird46's Avatar
Good find.
Mgino96tbird46 is offline
