used - TCCoA Forums
post #1 of 5 (permalink) Old 02-11-2010, 11:03 PM Thread Starter
used
Hello all.If i where to look at a used set of gears,besides the obvious broken or missing tooth,is there anything else one should look at?Would age be a consideration,even if all looked ok? I tried search but all i found was info on used TL.thanxs.mb
shadetreemike is offline
post #2 of 5 (permalink) Old 02-12-2010, 07:25 AM
CometGSR's Avatar
How much money are you paying for used gears? I know ebay sells brand new Ford gears for $100.00 or so. Might as well go new so you know it will work right the first time. Just my .02 cents.
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #3 of 5 (permalink) Old 02-12-2010, 01:13 PM
Nitemare's Avatar
$130-$140 for new FRPP in box off ebay, comes with crush sleeve and pinion nut. You'll have less problems. Trying used gears without knowing what you're doing is asking for trouble later on. If you have to go with the used R&P, then at least get new bearings, a new crush sleeve, pinion nut, carrier and pinion shims, and have fun setting that up.
Needs more stall.
Nitemare is offline
post #4 of 5 (permalink) Old 02-12-2010, 04:17 PM
I like used gears
I buy them when I can.....
When buying a set of used gears, make sure that on the pinion, there is no bearing race left on before you go try pressing a new bearing on.
post #5 of 5 (permalink) Old 02-12-2010, 04:36 PM
Nitemare's Avatar
I like used gears
You'd be fine in that area, but for someone who's never done it before, or isn't sure what to look for, they would probably be better off with a new set for now.
Nitemare is offline
