oh what the hail - TCCoA Forums
post #1 of 6 (permalink) Old 03-15-2010, 07:57 PM Thread Starter
Charger1352's Avatar
oh what the hail
i get in there and find this. will this effect anything at all?
also anyone know where i can get a spacer like this i went everywhere and no luck! they said it would be hard to find.
-BIRDGUY-
Charger1352 is offline
post #2 of 6 (permalink) Old 03-15-2010, 08:29 PM
That might not affect anything, but for the time involved in setting up a diff and how catastrophically they can fail, I wouldn't trust it. As for the "spacer" part, that is one of the factory shims for the diff. An install kit will have replacement shims, but they will be thinner and you will have to stack a bunch of them up to match the thickness of the factory one. At this point, if it were mine, I would just get another housing to put together, as well as some steeper gears and a trak-lok while you are in there.
post #3 of 6 (permalink) Old 03-15-2010, 08:39 PM Thread Starter
its a 3.55 trac-loc lol it was given to me
-BIRDGUY-
post #4 of 6 (permalink) Old 03-15-2010, 11:49 PM
As long as the shims rest against the case flat and square you would probably be okay, but personally, I would find another one (aluminum). I'm no differential guru, but have put together quite a few. Grab another case off of one of the cars you and your buddies smashed up.
coolhandzep is offline
post #5 of 6 (permalink) Old 03-16-2010, 07:40 PM
I do have an aluminum one sitting in my garage, as well as a cast iron housing down at the shop. Make me an offer for either one if you want. Since you already have gears and a diff, I can pull them out to save on shipping.
post #6 of 6 (permalink) Old 03-16-2010, 09:43 PM
95xbird's Avatar
Just reuse your original housing.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
