gear lube - TCCoA Forums
post #1 of 6 (permalink) Old 04-06-2010, 11:45 PM Thread Starter
gear lube
Want to know how many people run royal purple in there trac lock diffs. I was just running 75w-140 with the friction modifier but want to know if royal purple is a better choice.
95 Thunderbird LX
Drive train Mods:
full PI swap (03 grand marquis engine), 2000 Mustang GT 4R70W, C & L intake elbow, 73mm TB, 73mm MAF housing, CAI, flowmaster exhaust, 3.73 w/ trac lock and upgraded clutches, BOC tune.
Interior Mods:
SC seats
2008 Mazdaspeed 3
Drive train Mods:
Mazdaspeed cold air intake, TWM short throw shifter, motor mounts, and muffler delete
autoxbird is offline
post #2 of 6 (permalink) Old 04-07-2010, 12:13 AM
Bradone's Avatar
Don't know if it is better but I have been running it over two years. I check fluids every 6 months or so. Diff smells clean. Not like the old crap.
Brad
[email protected] (engine/trans is stock)
Bradone is offline
post #3 of 6 (permalink) Old 04-07-2010, 03:30 PM Thread Starter
My other question is with running royal purple do you need the friction modifier or no.
95 Thunderbird LX
Drive train Mods:
Interior Mods:
SC seats
2008 Mazdaspeed 3
Drive train Mods:
post #4 of 6 (permalink) Old 04-07-2010, 05:22 PM
I have heard thats what makes the royal purple better than conventinal diff fluid. it has the friction modifyer's right in it already. But i would check that info before i run just the RP
My Lug Nuts Require More Torque Than Your Honda Makes
Tbird64 is offline
post #5 of 6 (permalink) Old 04-08-2010, 05:34 AM
Bradone's Avatar
No friction modifier. Run it as is.
Brad
Bradone is offline
post #6 of 6 (permalink) Old 04-08-2010, 08:35 AM
read the bottle of all brands of diff fluid....you would be surprised to see how many come with friction modifier..
