2.73 to 3.27 - TCCoA Forums
post #1 of 12 (permalink) Old 04-17-2010, 04:17 AM Thread Starter
warbird90's Avatar
2.73 to 3.27
I'm about to swap my gearset from 2.73 to a 3.27 in my 90 5-speed sc. Just curious how much of a differeance this will make. I want more off the line and not concerened too much with highway stuff. Should I have gone with the 3.55 or 3.73???
The key to life is to always be in remote control
warbird90 is offline
post #2 of 12 (permalink) Old 04-17-2010, 04:35 AM
You'll notice a nice difference going from 2.73 to 3.27 and yes, you should have gone to 3.73
post #3 of 12 (permalink) Old 04-17-2010, 08:17 AM
CometGSR's Avatar
Isn't 3.73 a little much for a SC? I thought 3.55 was the way to go for the 6s.
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #4 of 12 (permalink) Old 04-17-2010, 08:22 AM
bowez's Avatar
From what I've read on SCCOA with 3.73 you won't go anywhere with the M5R2.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #5 of 12 (permalink) Old 04-17-2010, 08:00 PM Thread Starter
warbird90's Avatar
I read conflicting threads, that's why I asked. I heard the 3.27 was best for a 5-speed and the 3.55 was good for the auto. On the Super coupe performance website they reccomend that setup. I'm just thinking with that heavy of a car it would need more gear. Anybody know what the first gear ratio is in those 5speeds?
post #6 of 12 (permalink) Old 04-17-2010, 08:29 PM
dDUBb's Avatar
The 89-93 SC have a different 1st and 2nd gear ratio than the 94/95's. The 3.27 makes 1st gear really short on the early style trans, but is not so bad on the late models. It runs great around town, quick .. just not as good on the freeway top end. I have an early model trans in my 94 SC with the stock 3.31 rear end .. I will be swapping it out for a 3.08 or 3.07 later on even though I have a 2.73 in storage.
dDUBb is offline
post #7 of 12 (permalink) Old 04-18-2010, 07:39 AM
bowez's Avatar
89-93 is 3.72
94/95 is 3.42
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #8 of 12 (permalink) Old 04-18-2010, 09:11 AM Thread Starter
warbird90's Avatar
Thanks for the info. I'll find out here next weekend when I do the swap. See if I can't get it's fat a$$ to get up a go a little quicker!! Its a good thing it makes torque like a diesel.
post #9 of 12 (permalink) Old 04-18-2010, 10:33 AM
decipha's Avatar
I can't stand the 3.27s on the gen1 trans, sooner or later they will be replaced for the original 2.73s which has a mean second!
also i had 3.08s as well and I didn't notice much difference than the 2.73s other than my highway revs were higher, not worth it at all, ford did a pretty good job when they put the 2.73s behind the earlier style m5r2
stock 89-93 5spd supercoupe has a first gear ratio of 10.15 where as the stock 5.0 automatic birds got a first gear ratio of 7.392
so a stock 89-93 5spd sc has gearing equivalent to a 4.10 in an aod car.
putting a 3.73 in a 5spd gen1 sc is like putting a 5.8 rear end gear in an AOD thunderbird.
just comparing in different terms to make it more understandable
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #10 of 12 (permalink) Old 04-20-2010, 11:56 PM Thread Starter
warbird90's Avatar
So your sayin the 3.27 is too much?
post #11 of 12 (permalink) Old 04-21-2010, 08:27 AM
winkysrides's Avatar
Send a message via AIM to winkysrides
I like my 3.27s but @ some point im going to go 3.55. 3.73 is a bit much for 1st gear from what I hear that being said ime is a five point hoe
  • "Chuck Norris built my shortblock. It runs on the tears of small children and makes 10,000 hp. He said it's his 'street version' "
wheel hoppin and poppin!
91 Thunderbird sport 357W 5speed
88 stripped out 5.0 C4 and 4:56 gears in a 9in Ford
winkysrides is offline
post #12 of 12 (permalink) Old 04-21-2010, 11:28 AM
T-Bird Tim's Avatar
Having gone through this myself I can tell you that 3:73 gears in a 5-speed is way too much gear. You will be shifting to second just going through a red light and will need another gear at highway speeds. I ran 3:55s after that and it was an improvement. Lots of fun but still a little much. I found the 3:27s were just about perfect. Good hard launches and still pretty good on the highway also. By the way, my car is a 91 SC.
T-Bird Tim is offline
