gear change - TCCoA Forums
post #1 of 18 (permalink) Old 04-20-2010, 04:51 PM Thread Starter
gear change
where is the best place to get a set of 3.73 gears? I just purchased a 3.27 TL diff and am wanting to change to 3.73s. I have searched and looks like I will be spending $160+ after shipping for FRPP. Any where cheaper? or other gears that are cheaper, but decent quality?
seth
oh yeah, while I'm here. What all is involved in removing the rear differential? I found a non-thunderbird specific guide and it mentioned removing/loosening rear sway bar and dissassembling brakes and stuff. Is that all necessary? I have searched here and can't find any information. thanks
[email protected]=iii=<| is offline
post #2 of 18 (permalink) Old 04-20-2010, 05:14 PM
Tbird1997's Avatar
you could look around on craigslist or ebay but $160 isnt going to get much better and you know you will get a brand new set of gears.
-Patrick
Tbird1997 is offline
post #3 of 18 (permalink) Old 04-20-2010, 10:31 PM
seth
$160 for a 3.73 TL diff is an EXCELLENT price and good deal. Things to look for are that the splines are 28 spline (our 'Bird axles), not the 31 spline (which is common in the Explorers). Also that the gears are machined for the IRS (beveled, so you can pry the axles out to remove them and the snap ring will pop out). All late model 8.8 28 splines are machined for IRS, but the older ones are not, I don't remember the cut-off year.
post #4 of 18 (permalink) Old 04-20-2010, 10:37 PM
tbirdtess's Avatar
3.90's
Hello
I paid more for my 3.90's. Motive Gear.
I don't run a TL, rule thing!
I got 3.73's for a 7.5 in a auto 80's pony
I got 4.10's for a 7.5 from a 90's mini van.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #5 of 18 (permalink) Old 04-21-2010, 05:23 PM Thread Starter
so, there is no need to open the differential to remove the snap rings to remove the halfshafts? I found some good instructions after more search, but just want to be clear about that, because I have found some conflicting information elsewhere that is not t-bird specific.
thanks,
seth
post #6 of 18 (permalink) Old 04-21-2010, 05:34 PM
Bradone's Avatar
thanks,
seth
The axles just pop out. I just put a 373 together for my sons Mark VIII. I think he paid like $156 for FRPP gears.
Brad
[email protected] (engine/trans is stock)
Bradone is offline
post #7 of 18 (permalink) Old 04-21-2010, 06:26 PM
CometGSR's Avatar
Check Ebay. I got a fantastic deal on my gear. Sometimes you have to be in the right place at the right time.
Don't get Motive, they are made in China and I hear they are noisy. Doing a gear is something you want to do only once due to $$$$
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #8 of 18 (permalink) Old 04-21-2010, 06:55 PM
tbirdtess's Avatar
My car is sooo! loud I can't hear them. So I can't say they are noisy.
I had to go to someone that had 3.90's for a 8.8. Ford did not!
Been running them for 4 seasons so far. Make sure they are in correctly.
You shouldn't have problems.
351W 2bbl.
C-4 Auto
3.90 open rear
post #9 of 18 (permalink) Old 04-21-2010, 11:19 PM
Bradone's Avatar
I had 3.91's in my 340 Duster years ago and for an auto I thought they were perfect in the 1/4. I had pigs with 4.10 and I think 4.56 but I was way high rpm coming through the traps even with the 4.10. Used to pop the 4.56 in for the parking lot drags wintertime at Michigan Truck (Ford pickup plant). '72 I was consistently beating a 429 Hemi Mustang (he was really a bad driver). We raced 700'. Lots of fun and "lots" of money even by todays standards.
Brad
Bradone is offline
post #10 of 18 (permalink) Old 04-22-2010, 02:16 PM
Traveler's Avatar
Seth, I got my 3.73's from Ebay... just be careful who you buy them from. All you really need is the gears themselves, (the ring and pinion). The pumpkin you bought already has the Trac-loc in it. (some of the posts sounded confused on that point)
Buy a set of 3.73's and the two diff rebuild kits.. (one is for reassembling the pumpkin and the other for the trac-loc itself, including new clutches). then take all the parts and kits to a reputable rebuilder and have him put them together.
LOL almost felt sorry for the guy that did mine. I showed up with a VERY worn out 3.27 trac-loc pumpkin, the two rebuild kits, the 3.73 ring and pinion, and an aluminum Mark VIII case and said "i want the parts out of the old case, rebuilt and assembled in the aluminum case, with the 3.73 gears, using an F-150 "S" spring"... LOL fortunately he a good ol' small town guy who knows what he is doing. When he was finished I picked up a brand new rebuilt 3.73 TL in an aluminum case, and a box full of old, worn out, and VERY stinky dif parts.
But I digress....
To remove the rear end, just loosen the rear spindles from the control arms giving them room to move.. then remove the driveshaft bolts. Pry the shafts from the diff with a big screwdriver, (they should just "pop" out) then put a jack under the diff and remove the bolts holding it in place... lower carefully and roll the jack out.
Oh yea, you'll ned to remove the exhaust to.
If you want any help, just let me know and I'll see if I can manage a trip over to springfield.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #11 of 18 (permalink) Old 04-23-2010, 05:40 AM Thread Starter
Thanks traveler. I think i can manage. You're welcome to come anytime, but it sounds like you have alot going on. Have you already gotten moved?
I already have my transmission being worked on. I have a 93 mkviii drive shaft waiting to go in. I have the differential that I need rebuilt/regeared. I am ready to get it all back together and drive my car again.
Seth
Thanks for the reassurance of the rear differential removal.
post #12 of 18 (permalink) Old 04-28-2010, 08:21 AM Thread Starter
post #13 of 18 (permalink) Old 04-28-2010, 09:10 AM
The first one - do you need all the bearings?
the second - do you really want the carbon cluthes? the regulars work really good.
and the third...I believe that is still a motive gear set...hence the M on the part number.(yes, it does have a ford part number, but the gear is motive).
post #14 of 18 (permalink) Old 04-28-2010, 12:46 PM
Traveler's Avatar
I used an "S" spring for the F-150.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #15 of 18 (permalink) Old 04-28-2010, 06:40 PM Thread Starter
I don't know. I was going to get the whole diff rebuilt while I had it out as was suggested by Traveler. Should I just get the basic kit instead of the deluxe?
it was the first thing I saw. I didn't know there were others. I have since found them. (M-4700B)
anybody else know if this is correct. The gears listed on fordracing.com begin with an M. (M-4209-F373N). If that is not the FRPP gears. Where can I get them?
Thanks.
Seth
post #16 of 18 (permalink) Old 04-30-2010, 08:07 AM Thread Starter
if you haven't noticed. i ask a lot of questions. I just want to make sure and buy the right thing. Should I just get this for rebuild? http://supercoupeperformance.com/par...spx?partId=191
Still unsure about gears and the correct part number for FRPP. I will search more.
seth
post #17 of 18 (permalink) Old 04-30-2010, 08:20 AM
1) It just depends, if you had the time to open the case and inspect the bearinngs. If not, there is nothing wrong with the delux kit.
2) yep, m-4700B
3) I hope I did not scare you about the gear.....it was just what I ran across when searching for gears a couple years ago.(I could be totally wrong...as I really have nothing to back my claim)
post #18 of 18 (permalink) Old 04-30-2010, 08:45 AM Thread Starter
Well after a little research the m-4700c kit has the ford f-150 s spring in it. So I may go with that. Not sure of the others yet.
