Sealing the diff cover - TCCoA Forums
post #1 of 7 (permalink) Old 05-05-2010, 03:52 AM Thread Starter
Question Sealing the diff cover
Ok the old "gasket" was torn missing etc.. from it's groove. I have a spare felpro gasket for the 8.8 laying around. How should I go about sealing the cover. I also have a new can of right stuff rtv gasket maker.
Should I:
1: fill the groove with the rtv and bolt it on
cover/rtv/housing
2: fill the groove with rtv, rtv the diff housing and use the felpro gasket in between. So cover/rtv/gasket/rtv/housing
3: install the gasket dry with no rtv in the groove in the cover
cover/gasket/housing
4: fill the groove with rtv, put the gasket on dry against the housing
cover/rtv/gasket/housing
My local drivetrain/diff shop recommended method 1 or method 2 just wanted a second opinion.
post #2 of 7 (permalink) Old 05-05-2010, 06:37 AM
DLF
DLF's Avatar
cover/rtv/housing
My Web Site
DLF is offline
post #3 of 7 (permalink) Old 05-05-2010, 07:12 AM
Bradone's Avatar
The groove was meant for RTV.
[email protected] (engine/trans is stock)
Bradone is offline
post #4 of 7 (permalink) Old 05-05-2010, 07:25 AM
I personally like the reusable rubber gaskets from FRPP (I’m not sure if they still offer them).
Very thin coat of RTV on both sides of the gasket, produces a solid seal, and simple removal when/if needed.
69 F100 LWB w/460 Engine
post #5 of 7 (permalink) Old 05-05-2010, 12:53 PM
machausta's Avatar
cover/rtv/housing
x2 -- this worked perfectly for me after a little cleaning with a brass brush
2011 Dodge Durango Crew 5.7L HEMI
2001 Volkswagen Beetle GLX 1.8T
machausta is offline
post #6 of 7 (permalink) Old 05-05-2010, 01:42 PM
I find a old spark plug works great at cleaning the groove. Use option #1.
post #7 of 7 (permalink) Old 05-19-2010, 12:24 AM
nall_one's Avatar
yeah, ive done both my 90 and 95 with just RTV in the groove, still no leaks from the 95 after like 3 years, still watching the 90, though it leaks from the halfshaft seals anyway :P
heck i had no idea they even had a gasket for it...
nall_one is offline
