what kind of diff do i have? - TCCoA Forums
post #1 of 15 (permalink) Old 06-03-2010, 11:10 AM Thread Starter
richs1000's Avatar
Send a message via AIM to richs1000
its a 97lx with 3.8 v6. wondering about the details of this diff.
Rich
US Air Force
Oil Leak? No thats the frame lubricator.
richs1000 is offline
post #2 of 15 (permalink) Old 06-03-2010, 11:12 AM
RESET's Avatar
check the diff code on you door sill sticker then SEARCH. The codes have been posted somewhere, just can't remember ATM.
EDIT: http://tccoa.com/articles/gears/gears.html I don't know if these codes apply to the 7.5 and the 8.8 or just the 8.8. Remember to search the Articles when doing your research before posting. I got this page as an answer to a question I posted a couple months ago. It is about 15 entries below your post.
RESET is offline
post #3 of 15 (permalink) Old 06-03-2010, 01:48 PM
You have a 7.5" with 3.27 gears. You probably don't have trac-lok, but it's always possible.
post #4 of 15 (permalink) Old 06-04-2010, 05:14 AM Thread Starter
richs1000's Avatar
the only thing i saw was axel. and under that it said F5. under R it said H. under TR it said L.
Rich
US Air Force
post #5 of 15 (permalink) Old 06-04-2010, 05:22 AM
I do believe that you have a Trac -Lok .Being that you have a L
post #6 of 15 (permalink) Old 06-04-2010, 05:44 AM Thread Starter
richs1000's Avatar
whats trac lock?
Rich
US Air Force
post #7 of 15 (permalink) Old 06-04-2010, 06:34 AM
Awaiting E-Mail Confirmation
tinman_72's Avatar
http://www.tccoa.com/articles/gears/gears.html
The axle code is a one digit letter or number so F5 is not valid. If you have an F it is 3.45 open gears. If it is 5 then it is 3.27 open gears. I have never heard of factory 3.45 gears in an MN12.
The axle code will not tell you if it is 8.8" or 7.5", although most N/A V6's got 7.5's. I think I remember reading that the 97's had a higher chance of having an 8.8 because they were trying to use up all the parts before shutting down the manufacturing of the MN12. The only way to tell for sure is to crawl under it and look at it.
tinman_72 is offline
post #8 of 15 (permalink) Old 06-04-2010, 07:16 AM Thread Starter
richs1000's Avatar
i doubled checked. it says F5 for the axel code.
Rich
US Air Force
post #9 of 15 (permalink) Old 06-04-2010, 07:48 AM
dDUBb's Avatar
Weird. Well, the only way to know for sure is to get under your car and visually ID it by the numbers on the Tag.
dDUBb is offline
post #10 of 15 (permalink) Old 06-04-2010, 08:05 AM
Post a pic of your door sticker if u can
post #11 of 15 (permalink) Old 06-04-2010, 11:43 AM
Raptor22's Avatar
Just jack the ass end and spin a tire to see if it has trac loc...
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #12 of 15 (permalink) Old 06-04-2010, 12:17 PM
Yes, and by looking at your cover you'll see down on the lower right it will say "8.8" or "7.5".
This pic showing "8.8" for reference:
The metal tag with the ratio will more than likely be up higher on the cover and much harder to see....and that's still not an absolute guarantee as to what's inside. Sometimes people do weird things like changing the ratio and keeping the stock tag in place.
Delete my account.
94 Thunderbird XX is offline
post #13 of 15 (permalink) Old 06-04-2010, 05:29 PM Thread Starter
richs1000's Avatar
well its 7.5 which i figured. i just cant figure out the F5 axel code. Or if it has trac lok or not.
Rich
US Air Force
post #14 of 15 (permalink) Old 06-04-2010, 10:42 PM
F5
My references say F5 is 7.5", could be one of two ratios, 4.10 or 3.55, most likely 3.55:1, cause the 4.10 comes in trucks with the F5 code. And yes, trac-lok (Ford's posi).
post #15 of 15 (permalink) Old 06-05-2010, 12:21 AM
Nitemare's Avatar
It's a non T-lok 3.27 rear end.
...unless your car was the only T-bird ever to be produced with a factory 3.55 gear or the 10.25" dually solid axle.
Needs more stall.
Nitemare is offline
