Swapping axels - TCCoA Forums
post #1 of 5 (permalink) Old 07-17-2010, 04:25 PM Thread Starter
bagged95's Avatar
Swapping axels
im going to do the drum to disc swap, and was wondering if i would be able to pull the entire assemblies off in 1 piece from both cars (remove the bolts from the UCA's and LCA's then slide the spindles and drive axels out then replace them in reverse order)
The only concern im having without actually getting into the job is - are there any differences in the axels from a 95bird with drums and axel code of Y And A 96bird with disc and axel code of E?
bagged95 is offline
post #2 of 5 (permalink) Old 07-17-2010, 04:57 PM
It will work, just make sure they are V8 halfshafts
post #3 of 5 (permalink) Old 07-17-2010, 05:38 PM Thread Starter
bagged95's Avatar
Yeah both cars are v8's.
bagged95 is offline
post #4 of 5 (permalink) Old 07-18-2010, 11:51 PM Thread Starter
bagged95's Avatar
The axels from the 96 have a gear on them on the Diff. side and the ones from my 95 do not.
Will this make any difference when putting them on the 95?
bagged95 is offline
post #5 of 5 (permalink) Old 07-19-2010, 12:24 AM
Those are for the ABS sensors, it doesnt matter if you have them or not on yours.
