explorer 31 spline axle swap - TCCoA Forums
post #1 of 7 (permalink) Old 09-08-2010, 07:41 AM Thread Starter
while i was on summit racing looking for differentials, i clicked on the detroit locker, and had two of them narrowed down, 28 spline or 31 spline, i researched and found out that that starting on 2002, the explorers came equipped with the irs and 31 spline axles, my question is how will it fit, is it a simple swap, or will many mods be needed, i know there are plenty of 28 spline birds and cougar running good times, but id rather be safe than sorry, what else would i need to do this swap, im going back and forth with this swap, because gearbanger(has a 97 cougar) from stangnet said that i wont really need a 31 spline swap unless im planning on doin hard launches or will be running with slicks, but i google and google and i come to the thought that the 31 splines are better, any advice greatly appreciated
here is a picture of rear passenger axle
http://www.autopartswarehouse.com/de...QA1602179.html
here is the cougar axle(most of you probably know) rear or driver passenger
http://www.partstrain.com/store/deta...Passenger_Side
rgc_95xr7 is offline
post #2 of 7 (permalink) Old 09-09-2010, 04:05 PM
31 spline axles are only slightly better than the 28 splined ones....and only because of that extra tiny bit of surface area more splines provide.
That miniscule amount of improvement is really not worth the extra hoopla IMO. But to answer your question, the carrier should fit once you source out the correct length (for mn12) 31 spline halfshafts and change all that stuff around.
Delete my account.
94 Thunderbird XX is offline
post #3 of 7 (permalink) Old 09-09-2010, 04:46 PM
VicRattlehead's Avatar
im putting a 31 spline diff in my bird this week. ive got the axles and center section in the garage. the axles need to be modded and im good to go.
CMP Drag Racing
VicRattlehead is offline
post #4 of 7 (permalink) Old 09-09-2010, 08:47 PM
USAF_Bowman's Avatar
What do you mean by the axles need to be modded?
"Let's take my Thunderbird and leave tonight. I'll keep the pedal to the floor till we see the morning light."
-Reckless by Alabama-
June 13 2010 - Took 2nd in all Ford Car Show in the High School Division
USAF_Bowman is offline
post #5 of 7 (permalink) Old 09-09-2010, 08:50 PM
they are about 5/8" to short
CMP Drag Racing
post #6 of 7 (permalink) Old 09-10-2010, 06:08 AM Thread Starter
well i know i can get the locker in 28 spline, but there is no locker price difference if i get 28 spline or 31 spline, im starting from rear end towards front end and leaving motor and performance till the end, i dont want to leave the 28 spline, put slicks and snap the axle and regret not putting the 31 splines since the beginning, thanks for your opinion btw
post #7 of 7 (permalink) Old 09-10-2010, 07:59 AM
I've pulled 1.60 60 fts on stock axles and my buddy has pulled 1.59, just depends what your doing with it a heavy shot of nitrous off the line you might wanna change them
Robert
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
