Discussion: Gear Ratio vs. Acceleration - TCCoA Forums
post #1 of 7 (permalink) Old 09-15-2010, 08:55 AM Thread Starter
Riddle me this: Which will accelerate faster in first gear (all things being equal except those listed):
Transmission first gear ratio: 2.84 w/final gear ratio: 3.73
(effective final drive ratio 10.5932:1)
or
Transmission first gear ratio: 3.88 w/final gear ratio: 2.73
(effective final drive ratio 10.5924:1)
In other words, does it matter "where" the torque multiplication takes place (and why)?
69 F100 LWB w/460 Engine
post #2 of 7 (permalink) Old 09-15-2010, 01:39 PM
r429460's Avatar
Come on, get back to work.
The question, for the first 20 feet, the second choice.
r429460 is offline
post #3 of 7 (permalink) Old 09-16-2010, 06:47 AM Thread Starter
Come on guys, doesn't anyone have any thoughts?
In my mind they would accelerate at the same rate, but I'm not sure if that is true.
r429460: If the second one would accelerate faster.... why?
post #4 of 7 (permalink) Old 09-16-2010, 08:31 AM
tbirdtess's Avatar
Engine?
Hi
Is this with the same engine? car?
Does this trany have an over drive?
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #5 of 7 (permalink) Old 09-16-2010, 08:33 AM
r429460's Avatar
Its a granny gear from a truck.
r429460 is offline
post #6 of 7 (permalink) Old 09-16-2010, 08:38 AM Thread Starter
I'm talking only theory here.
Assume:
Same car, same engine, same one speed transmission (just with the listed different gears), one speed rear end (again, just with the listed different gears), same temperature/humidity, no traction problems, etc.
This is just a question about does it matter acceleration wise "what device" (tranny or differential) does the torque multiplication?
post #7 of 7 (permalink) Old 09-16-2010, 02:18 PM
Weight/Mass and Drag
Well, it would make sense to me #2 because even though the final ratio figures to be almost exactly the same, with the gearing early on, that is less weight/mass to spin up to speed since the output shaft/driveshaft/rear gears are all spinning less and the rotational acceleration of those components are lower. That results in less resistance/drag and less parasitic losses.
That's my analysis in a nutshell, but what do I know!
~Rick
TCCoA Sig
