T-Lok rebuild questions - TCCoA Forums
post #1 of 28 (permalink) Old 09-27-2010, 05:53 PM Thread Starter
I picked up a differential out of an early 90s SC today at the junkyard for a hundred bucks. I plan on rebuilding the t-lock with this (www.summitracing.com/parts/FMS-M-4700-B/). Is there anything else Im going to need, Ive done some searching but havent found anything substantial. Also, how hard is it just to rebuild the traction-lok, I plan on doing it myself but have zero experience at doing it.
thanks
1995 Thunderbird 4.6
Clear corners, HID's, 2 15" Kickers, CAI, 2 1/2 Dual exhaust w/ x-pipe original 40s, 3.27 TL
sprite is offline
post #2 of 28 (permalink) Old 09-27-2010, 06:22 PM
paintme205's Avatar
there is nothing to hard about it. Are you keeping the stock gears that were inside it? If no then it gets a little harder depending on your skill set. The trac loc is easy enough. The gears shouldn't be to bad and you can probably reuse your stock pinion shim if you are planning on the 3.55's mentioned in your sig and they are ford gears.
Always double check pinion depth, gear pattern and backlash though. Have you looked at some of the articles on it?
paintme205 is offline
post #3 of 28 (permalink) Old 09-27-2010, 07:00 PM
That kit is to just rebuld the trak-lok unit. That does not include the new bearings to rebuild the diff itself, which I would reccomend doing since the unit just came out of a junkyard and you don't know the condition of it. If you are not rebuilding the diff or changing gear ratios and just looking to swap in a trak-lok unit, then that is all you'll need, plus new gear oil. The only tricky part about putting the trak-lok back together is getting the spider gears lined up right because you have to put them in on the sides perfectly opposite from each other, and then spin it over to get them in position, making sure neither of them drops out. Sometimes it takes a few tries to get it lined up right, but other than that, it is pretty straight forward, just put it all back the way it came apart, only with the new parts. The rebuild kit is basically new frictions and steels, and some shims. Just make sure the frictions and steels alternate, and use the shims to get it tighter if the topmost friction is not flush with the top of the trak-lok housing.
post #4 of 28 (permalink) Old 09-27-2010, 09:58 PM Thread Starter
Im just going to order the traction lock kit and keep my fingers crossed that its not thrashed. I also plan on keeping the 3.27s that are in it now for a little while. My sig is outdated and Im going in a different direction. I saved a couple grand for a down payment on a mustang...then found out insurance would be 2650 a year sooo Im gonna do up the thunderbird. I have a couple grand in the bank now and am going to save until spring, by then I should have 5-6k in the bank. Ill be doing an explorer swap with a marauder tc, 3.73 gears, j-mod, cams and a tune. Im not positive what the total cost of it all will be, but if theres anything left over I got some other plans.
Thanks for the info though, mikey, you make it sound like peanuts lol hopefully it gets done without a hitch, if not theres some pretty knowledgeable people here that could shed some light on it.
sprite is offline
post #5 of 28 (permalink) Old 09-27-2010, 10:12 PM
If you are just replacing the diff itself, it is peanuts. Where it gets slightly more complicated is changing the ring and pinion gear, and where it gets really complicated is if you start with an empty case and don't know what shims came from where and you need to either buy special tools or keep putting it together and taking it back while measuring clearances so you can figure out what size shims are needed where. But since all you are doing is replacing the clutches, the only thing that you need to keep track of is which shim goes on the left and which goes on the right.
post #6 of 28 (permalink) Old 09-27-2010, 10:19 PM Thread Starter
10-4. I just ordered the rebuild kit, hopefully this time next week Ill have this sucker in.
sprite is offline
post #7 of 28 (permalink) Old 09-27-2010, 10:23 PM
Dan Nelson's Avatar
Donít forget to use the friction modifier additive in the oil
Dan Nelson is offline
post #8 of 28 (permalink) Old 09-27-2010, 10:27 PM Thread Starter
Any suggested weight of oil for it, and how much should I need?
sprite is offline
post #9 of 28 (permalink) Old 09-28-2010, 08:34 AM
2 quarts of 75W90
post #10 of 28 (permalink) Old 09-28-2010, 10:26 AM Thread Starter
k, thanks
sprite is offline
post #11 of 28 (permalink) Old 09-28-2010, 10:51 AM
Faster than Porkchop
cjchevez's Avatar
http://www.mustang50magazine.com/tec.../photo_03.html
Found this today , might come in handy for you or me. I just took my 4.10's out of my car. There was so much play with the pinion I think I killed the trac lock lol.
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #12 of 28 (permalink) Old 09-29-2010, 11:29 AM
If you're going to the trouble of replacing the clutches, be sure to replace the "S" spring, the cross shaft/pin, & spider gear thrust washers. These can all be purchased thru Sumitt also.
FastGast is offline
post #13 of 28 (permalink) Old 09-29-2010, 01:18 PM
rbrown's Avatar
The kit comes withthe friction modifier.
If you want to go simple and just do the clutches (I have with great success) just match the old shim to a new one and you can try to go the next size larger but I have yet to get that to work. I always end up putting the same shim size that comes out. And the old spring.
Hope it goes well. I did one a year ago I thought was good, 3.8 non sc car, couldn't be beat.... yeah well it made so much noise on the road I had to pull it.
rbrown is offline
post #14 of 28 (permalink) Old 09-29-2010, 11:14 PM Thread Starter
Just got home from work and had a nice little box on my steps It also came with a small bolt about 1 1/2" - 2" thats only thread a quarter way down from the top? I guess Summit is partners with Shick because I also got one of the new Shick Hydro 5 razors too lol.
Now I just have to wait until monday to throw it all in.
sprite is offline
post #15 of 28 (permalink) Old 09-30-2010, 08:18 AM
THANK YOU!
little side story....lol
I recently switched razors, I had always used gillette 2 blade crap. Well, I had this shick razor sitting around, and for the life of me, I could not remember where it came from. I knew I got it in the mail, but forgot from who....
thanks for the reminder!
post #16 of 28 (permalink) Old 09-30-2010, 08:37 PM Thread Starter
glad i could be of help lol.
sprite is offline
post #17 of 28 (permalink) Old 09-30-2010, 10:26 PM
That bolt holds in the cross pin. It's called the "Differential Pinion Shaft Lock Bolt". It has to be removed in order to remove the cross/pinion shaft. Then you push the axles in to remove the "C" clips in order to remove your axles. It's a big mechanical puzzle. Try this link for a pdf of the differential parts & pieces. http://www.2005stang.com/gallery/alb...rearend8-8.pdf
FastGast is offline
post #18 of 28 (permalink) Old 09-30-2010, 10:33 PM
...be sure to completely soak the clutches in the axle lube for a good day or two before assembly. After you have it all assembled w/the gear lube & friction modifier, & your ready for a test drive, take it to a close open parking lot a& do a series of tight L/H & R/H circles. Just take it easy & drive in circles to get all the lube & friction modifier between the clutches. This will help eliminate chatter w/the new clutches.
FastGast is offline
post #19 of 28 (permalink) Old 09-30-2010, 11:24 PM Thread Starter
Thanks, the picture and info were good. It got rid of a lot of that "wtf is this thing gonna look like on the inside?" thoughts lol. Ill also remember to soak the clutches. thanks.
sprite is offline
post #20 of 28 (permalink) Old 10-04-2010, 08:39 PM Thread Starter
Finished the rebuild today. It really was pretty simple once me and my friend realized how everything needed to come apart. I was also able to get the largest shim that came in the kit to fit in there. (.040) So tomorrow Im going to call around and get some prices on how much it would be to put it in, but I talked to someone at a shop today and they gave me a number that made me think about just doing it myself. Hopefully next monday or tuesday Ill have it installed either way. Thanks for all the info.
sprite is offline
post #21 of 28 (permalink) Old 10-04-2010, 09:13 PM
rbrown's Avatar
You soaked the washers in fluid before assembly yes?
rbrown is offline
post #22 of 28 (permalink) Old 10-04-2010, 09:33 PM Thread Starter
yessir.
Also can anyone tell me what bushing this is called? http://forums.tccoa.com/showthread.p...umpkin+removal - post 19 picutre 5, the two on the right side of the pic.
sprite is offline
post #23 of 28 (permalink) Old 10-04-2010, 11:45 PM
davis97xr7's Avatar
differential bushings
-Joe-
1994 Ford Thunderbird SC 5-Speed
1996 Ford Mustang SVT Cobra #1251
davis97xr7 is offline
post #24 of 28 (permalink) Old 10-05-2010, 10:36 AM Thread Starter
That makes sense lol. thanks
sprite is offline
post #25 of 28 (permalink) Old 10-09-2010, 10:09 AM Thread Starter
I just oredered some diff. bushings. Energy Suspension 4-1126G, I plan on putting it all in Mon-Tue, after reading around it sounds pretty easy, so is there any tips or anything to look out for while Im doing this? I only plan on hitting all the bolts with PB for the next couple days.
sprite is offline
post #26 of 28 (permalink) Old 10-09-2010, 10:48 AM
paintme205's Avatar
Just make sure you mark the caps up/down and left and right plus write down which shim came from where. The bushings are cake. Just put them on.
post #27 of 28 (permalink) Old 10-09-2010, 10:55 AM Thread Starter
10-4 thanks
sprite is offline
post #28 of 28 (permalink) Old 10-11-2010, 09:18 PM Thread Starter
I just got done installing the diff. about an hour ago. It took me and a friend about 7.5 hours, we would of been done sooner but the last while we were working in the dark with a fluorescent light. Everything worked nice though, no problems with anyhting i replaced. Other than every nut and bolt fighting us the whole way, it was good biz. Even got to drive up town with no exhaust after the x-pipe lol Im going to put the exhaust back on tomorrow, just no day left today.
Thanks for all the info and help.
sprite is offline
