How much gear is too much gear? - TCCoA Forums
post #1 of 21 (permalink) Old 10-12-2010, 07:09 AM Thread Starter
95xbird's Avatar
Ok im very bored with my car. All mods are listed in my sig, i found a set of 4.10's for a good price online . Im running 3.73's now and a 3500 stall. Its a decent combination but honestly everyday I drive this car it just feels slower and slower. I was curious on if 4.10's would be a good choice. Im not worried about gas mileage obviously and ill also be contacting Alan for a 4000 stall (minimum) around tax time. So give me your opinions. Are 4.10's beneficial to run with and svo blower? Every little bit helps right?
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #2 of 21 (permalink) Old 10-12-2010, 07:40 AM
IMHO 4.10 is as high as I would go, And Mine seams to get faster. & faster .I guess my trans & top end is getting broke in . Very pleased with how this SVO runs
post #3 of 21 (permalink) Old 10-12-2010, 07:53 AM
Toombs's Avatar
I'm a bad person to ask....
I geared mine so the RPM was where I wanted it going through the traps. I can deal with driving it with that gear. I don't know what your car runs, or what you think your useful RPM limit is, but I'd start with that info, and adjust the gear to put you there in a quarter mile. Just my .02.
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- DirtyDog Converter (3,800)
- SCT Micro Tuner from Blue Oval Chips
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #4 of 21 (permalink) Old 10-12-2010, 08:12 AM Thread Starter
95xbird's Avatar
It ran 12.8 at like 105ish. It feels like it needs to pull harder in the mid to high rpm range in 3rd. Im thinking if I can get threw the gears faster it'll trap higher and run a faster time.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #5 of 21 (permalink) Old 10-12-2010, 08:40 AM
If you don't care about gas mileage, and you don't do a lot of highway driving with the car, 4.10s should be fine. There are plenty of birds running around with 4.10s without issues. Personally, I prefer the 3.73s because you can still cruise at 80 on the highway without the motor screaming, but if you're looking for a quick fix to make the car feel faster again, 4.10s should do the trick. I don't know how much they'll actually help in the 1/4, but on the street it will make the car a lot more fun.
post #6 of 21 (permalink) Old 10-12-2010, 08:49 AM
your trap won't go higher do to the gear...you will just a get a lower E.T.
post #7 of 21 (permalink) Old 10-12-2010, 09:17 AM
Gl@re's Avatar
I always heard that 3.73's were as high as you wanted to go with a supercharger, because they need the load... is this not true?
I vote you go with a blown 4v build
14.8 @ 95
post #8 of 21 (permalink) Old 10-12-2010, 09:52 AM
You must be thinking turbo.
Delete my account.
94 Thunderbird XX is offline
post #9 of 21 (permalink) Old 10-12-2010, 10:03 AM
Gl@re's Avatar
no, turbo's love gear, because it makes them spool faster.
14.8 @ 95
post #10 of 21 (permalink) Old 10-12-2010, 10:17 AM
You may either want to A: rephrase that, B: learn more about it, or C: go ahead and bet your car on that statement.
At any rate....we're done hijacking OP's thread.
Delete my account.
post #11 of 21 (permalink) Old 10-12-2010, 10:47 AM
hotrodseanxx's Avatar
Send a message via AIM to hotrodseanxx
I'm running an 8.8 tac-lok with 4.10s as my daily driver. Lost a little bit of gas mileage, but not much. MadMike actually is the one that installed the new 4.10s and rear into my bird. I like them and I have not had a problem. I take it down the highway to work and I've had it at 80-90ish mph with no problems. It gives a good pull especially hitting around 60mph and up. Now if I could only get the transmission to shift better then we'd be golden lol.
-Sean
1993 3.8 LX
cold air intake
Rebuilt AOD w/ Transgo shift kit
8.8 T-Lok w/ 4.10s
custom gauge set/custom dash
hotrodseanxx is offline
post #12 of 21 (permalink) Old 10-12-2010, 11:50 AM
Come down again some time and we can do a B&M shift kit in that trans if you want.
post #13 of 21 (permalink) Old 10-12-2010, 11:51 AM Thread Starter
95xbird's Avatar
Lower ET is fine. I'd like to at least get 115mph though in the 1/4. I just wanna know if the 4.10's are going to be beneficial on a SVO car.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #14 of 21 (permalink) Old 10-12-2010, 12:33 PM
Gl@re's Avatar
I guess you're right, you don't want to go crazy with gearing in a turbo car because the engine needs load to create back pressure to spin the turbo.
I think when it comes to superchargers it depends on the superchargers type. if it's centrifugal, then gearing really helps you get into the power band, because those don't make as much down low. If it's roots, or twin screw, it's more about making sure you don't shift into OD before the 1/4 mile. here they have an Optimum Rearend Ratio Calculator http://www.hotrodpitstop.com/tools.html#6
Edit: using that calculator, as long as i'm using it correctly (1:1 trans ratio for third gear, and 0 converter slip because it's locked in third, 6500 rpm, and 115 mph) your optimum rearend ratio is 4.37. so 4.10 might be good, but 4.30's would be better
14.8 @ 95
post #15 of 21 (permalink) Old 10-12-2010, 01:34 PM
you won't gain anywhere near 10 mph with a gear change.
In fact, the better you hook, your trap might go down...
post #16 of 21 (permalink) Old 10-12-2010, 04:54 PM Thread Starter
95xbird's Avatar
This I know, More spin creates a higher trap. Im just saying I wanna do 115 through the traps. I know gears wont do that for me. But if gears will help me run a faster time then I'll go for it.
If I could find 4.30 gears I would rather go that route. But 4.10's should work nicely.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #17 of 21 (permalink) Old 10-12-2010, 04:55 PM
gotcha
post #18 of 21 (permalink) Old 10-20-2010, 12:55 PM
paintme205's Avatar
I just got a set of ford racing 4.30's for $205. I don't know if I would go that high on a blown car though. 4.30s and an svo are going to be a nitemare on the rear end and also on your 60ft times.
paintme205 is offline
post #19 of 21 (permalink) Old 10-20-2010, 03:36 PM
LOL no, it's because the air is getting cooler and I'd venture to guess that you're still getting use to your new 3.73's.
Good luck at Rockingham! I wish I could make it this month. It will be November before I can join you guys down there.
To the OP. Hans runs 4.10's and RobertP just switched to 4.10's with his Vortech. I'm considering 4.10's too. It's not that big a jump from 3.73's. Like Darren said; I wouldn't go any higher than 4.10's with a SVO.
post #20 of 21 (permalink) Old 10-20-2010, 06:44 PM
Moderator & Teksid Whore
guitar maestro's Avatar
Mike
if you're bad, i'm worse
guitar maestro is offline
post #21 of 21 (permalink) Old 12-18-2010, 06:09 PM
for every .25 gear ratio change, the rpm's will change by 300
beechkid is offline
