posi rear - TCCoA Forums
post #1 of 7 (permalink) Old 11-10-2010, 09:12 AM Thread Starter
posi rear
like to put in a posi rear on my 1992 thunderbird. has an 8.8 rear. The car has a 5.0 ho engine. What gear ratio should I get? How hard is it to put in. I brough the car new did not change anything. Any way You can get instructionson on how to install?
redzie407 is offline
post #2 of 7 (permalink) Old 11-10-2010, 12:05 PM
Buckcreekbilly's Avatar
Here's the tech articles. This has been discussed hundreds of times. General concensus seems to be 3:73 for all round usage.
http://www.tccoa.com/articles/gears/index.html
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #3 of 7 (permalink) Old 11-10-2010, 12:23 PM
Never tried putting a GM rearend in a bird before. This should prove interesting.
But, if what you meant was a traction-loc, then yes, follow the link above for your info. For gears I would say at least 3.73's, maybe even 4.10's. These cars a heavy and having good gears and a higher stall TC help get them moving.
Jay
FordMan77 is offline
post #4 of 7 (permalink) Old 11-10-2010, 12:36 PM
conversion02's Avatar
4.10s? It all depends on what the dood wants to do with his car. If it's a daily driver, I would most likely not put in 4.10s. I'd probably go with 3.55s.
Since the car's stock and unless you plan on changing out the converter, I probably wouldn't put in 4.10s. Why have such a low stall converter and a 4.10 gear ratio?
conversion02 is offline
post #5 of 7 (permalink) Old 11-10-2010, 01:02 PM
don't fear the gear.....I would say these cars need 4.10's at a minimum....
post #6 of 7 (permalink) Old 11-10-2010, 03:22 PM
Agreed
post #7 of 7 (permalink) Old 11-10-2010, 04:08 PM
machausta's Avatar
I went from a 3.08 open to a 3.27 TL and now I'd say at least 3.73 or else you'll end up wanting more.
2011 Dodge Durango Crew 5.7L HEMI
2001 Volkswagen Beetle GLX 1.8T
machausta is offline
