what rear end is in my car? - TCCoA Forums
post #1 of 19 (permalink) Old 12-09-2010, 09:13 PM Thread Starter
hey how do you tell what rear end you have?
i have a 1996 4.6l t bird and am looking to switch to 3.73 gears and i am not sure what rearend i have??
robby655 is offline
post #2 of 19 (permalink) Old 12-09-2010, 09:15 PM
http://www.tccoa.com/articles/gears/gears.html
3.27's since you have a 96
post #3 of 19 (permalink) Old 12-09-2010, 09:16 PM
What letters/numbers does it say on the door sticker under "AX" or "Axle" ? It's an 8.8" with IRS for sure, but that'll tell you the ratio (if it hasn't been changed).
What XR7-4.6 said works too, lol!
~Rick
TCCoA Sig
post #4 of 19 (permalink) Old 12-09-2010, 09:18 PM Thread Starter
alright ill go check out my door real quick! but some guy told me 3.73 gears would help acceleration. but i dont know for sure haha im kinda new with gears. thanks for all your help in advance
robby655 is offline
post #5 of 19 (permalink) Old 12-09-2010, 09:19 PM Thread Starter
the AX number is a 5
robby655 is offline
post #6 of 19 (permalink) Old 12-09-2010, 09:21 PM
Axle code 5 is 3.27 Open (non-locking) differential. 3.73 gives you quicker off the line, but hurts highway mpg slightly. Do some searches around here, quite a few have done that swap.
Good Luck & Happy Holidays!
~Rick
TCCoA Sig
post #7 of 19 (permalink) Old 12-09-2010, 09:23 PM Thread Starter
so was the guy wrong when he said to drop 3.73 gears in there?
robby655 is offline
post #8 of 19 (permalink) Old 12-09-2010, 09:27 PM
No, but it's quite a job. If you've never installed rear gears before, you will HAVE to get some help with it. It's a big job and must be shimmed correctly or you will wind up with a very LOUD rear end that may or may not last long.
And if you're gonna do that, you might as well get a trak-loc carrier to install as well.
~Rick
TCCoA Sig
post #9 of 19 (permalink) Old 12-09-2010, 09:28 PM
Nope, they are worth it. 3.73's should be the minimum gears on these cars
post #10 of 19 (permalink) Old 12-09-2010, 10:11 PM Thread Starter
yeah my shop teacher was a ford tech for 11 years and he said he has done plenty of them haha and we are just getting into gearing and driveline so he said he would just use mine as a demo and do it for me so it kinda works out! ill shadow him so i can learn a thing or two though. should i buy the 3.73 gears for the 8.8 rearend?
robby655 is offline
post #11 of 19 (permalink) Old 12-09-2010, 10:20 PM
Yes, and as NetKeym said get a Trac lok carrier (make its 28 spline and for IRS)
post #12 of 19 (permalink) Old 12-09-2010, 11:49 PM Thread Starter
so i was browsing around ebay in search of the gearing i need and i came across this and it says for thunderbird 87-94... and mine is a 96? but it is the 8.8 rearend? i dont understand why its not for my car?
robby655 is offline
post #13 of 19 (permalink) Old 12-09-2010, 11:51 PM
Vendors have no idea what these cars are let alone the year ranges, don't worry about it.
post #14 of 19 (permalink) Old 12-10-2010, 12:18 AM Thread Starter
oh alright cool. thanks for all your help clearing everything up xr7 and netkey you have been a great help
robby655 is offline
post #15 of 19 (permalink) Old 12-10-2010, 03:28 AM
Bradone's Avatar
To repeat a past post (x2) put in a TracLoc at the same time. 3.73 without the TracLoc results in single wheel burn.
Brad
[email protected] (engine/trans is stock)
Bradone is offline
post #16 of 19 (permalink) Old 12-10-2010, 05:35 PM
Brad
Yep, if you're in there to swap out the gears...no sense putting it all back together without a TL carrier.
Delete my account.
94 Thunderbird XX is offline
post #17 of 19 (permalink) Old 12-10-2010, 10:42 PM
You won't see mileage effects from the 3.73's even with the increased highway RPM's, both the gears and converter are good to have.
post #18 of 19 (permalink) Old 12-11-2010, 02:13 AM
Tbird1997's Avatar
yes many of my buddys run 373 gears in there mustangs its really the best mod you can do to your stock 4.6. they really didnt loose much highway MPGs maybe 1 or 2 if they are cruising at 70mph. high stall TC will drop some in city MPG but you will love it off the line. and really if your going to go fast your going to waste fuel so get over it.
tyring to get these two done on my car now -im broke and in college so trying to get some money for a 3500 stall and 373 gear.
EDIT: 410 is a great gear for these 2v but will cost you a bit more in highway MPG so its up to you
-Patrick
Tbird1997 is offline
post #19 of 19 (permalink) Old 12-11-2010, 09:36 AM
Yeh, a buddy of mine has 3.73's in his 5-speed Mustang convertible, as well. It turned that 5.0 into a totally different car. I actually thought he had 4.10's in it the way the car acts, but he said they're 3.73's (I guess the lower ratios in the 5-speed tranny as compared to the AOD/4R70 is what makes the rear gears feel lower).
~Rick
TCCoA Sig
