stock aod with 3.73 - TCCoA Forums
post #1 of 7 (permalink) Old 12-13-2010, 11:18 AM Thread Starter
stock aod with 3.73
what is the top speed in each gear at say 6000rpm
i know there is a calc somewhere i just cant find it
mike
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #2 of 7 (permalink) Old 12-13-2010, 11:31 AM
Google search for "Speed vs rpm calculator":
http://wahiduddin.net/calc/calc_speed_rpm.htm
We can't answer your question without all the information. And note that the tire measurement in the above link is the radius, not the diameter.
69 F100 LWB w/460 Engine
post #3 of 7 (permalink) Old 12-13-2010, 11:37 AM Thread Starter
1.Gear ratios, the 4R70W has the wide ratio gears whereas the AOD-E doesn't.
4R70W ratios are: (1st) 2.84, (2nd) 1.55, (3rd) 1.00, (OD) .7
AODE ratios are: (1st) 2.40, (2nd) 1.40, (3rd) 1.00, (OD) .67
shud i assume that an aod and aode have the same gearing?
1990 ford f150 5.0
1984 tbird 5.0 auto
post #4 of 7 (permalink) Old 12-13-2010, 11:42 AM Thread Starter
what is tire radius?
i am running a 27x9x15 slick?
1990 ford f150 5.0
1984 tbird 5.0 auto
post #5 of 7 (permalink) Old 12-13-2010, 11:45 AM
Here's the one I usually use
http://www.catherineandken.co.uk/sti/tyres.html
post #6 of 7 (permalink) Old 12-13-2010, 11:53 AM Thread Starter
cool...thanks for the help guys
1990 ford f150 5.0
1984 tbird 5.0 auto
post #7 of 7 (permalink) Old 12-13-2010, 12:23 PM
Rayo's Avatar
Very Cool..Good Info Mikey!
Rayo...
1991 Ford Thunderbird Sport
Rayo is offline
