broken diff housing - TCCoA Forums
post #1 of 56 (permalink) Old 01-07-2011, 06:51 PM Thread Starter
dragracer969's Avatar
broken diff housing
Just wondering if anyone has ever cracked a mark viii aluminum diff housing because I did the other day and am trying to find out if this is a common thing. I've heard of halfshafts but didn't figure the housing would crack. I figured a u-joint would let go first. I can see two cracks one from where the cover bolts forward and one from the top of the housing going down. There could be more, can't fit under the car to look much closer. Any input/advice on preventing this from happening again would be greatly appreciated
1994 Lincoln Mark VIII
-Strutmasters coil conversion lowering kit
-17" Borbet wheels
-03 GT valve body with Jmod
dragracer969 is offline
post #2 of 56 (permalink) Old 01-07-2011, 08:40 PM
Usually people break the rear cover, not the housing itself. I think I've only ever seen one other housing cracked.
MadMikeyL is online now
post #3 of 56 (permalink) Old 01-07-2011, 09:29 PM Thread Starter
So should I just chock this up as a freak accident or should I buy something to reinforce the new housing so I don't do this again?
-17" Borbet wheels
post #4 of 56 (permalink) Old 01-07-2011, 09:49 PM
What's the condition of the bushings/mounts?
Case failure is very uncommon, even the cover is uncommon in a stock power auto car.
post #5 of 56 (permalink) Old 01-07-2011, 09:58 PM
conversion02's Avatar
The only casing I've seen cracked was due to a drop off a diff jack from about 5 feet.
I've also only seen 1 cover cracked. Neither one is very common.
conversion02 is offline
post #6 of 56 (permalink) Old 01-07-2011, 11:12 PM Thread Starter
I will check everything out and take plenty of pictures when I go to replace it. I have a jmod and stomped on it from a standstill, it was spinning just the right rear and then when it shifted to 2nd is when the rear let go. I haven't been able to get under the car to look at too much but from just looking at it while the cars on all four wheels I noticed the two cracks I mentioned
-17" Borbet wheels
post #7 of 56 (permalink) Old 01-08-2011, 12:05 AM
A lot of people have put a lot of power down through mark8 cases without a case breaking. Could be from an accident of some kind?
post #8 of 56 (permalink) Old 01-08-2011, 12:08 AM Thread Starter
I was thinking maybe it could be damage from the previous owner and it finally let go but I've had it for about 60,000 miles now and they have all been hard miles so I would think it would have gone by now if it was from some sort or wreck or previous damage. I've never lifted the car by the diff or anything like that. I'm wondering if this is just one of those fluke breakages
-17" Borbet wheels
post #9 of 56 (permalink) Old 01-08-2011, 08:01 PM
This is the only one I remember seeing: Race it, Break it, Fix it, Repeat
Do you have a pic of your damaged diff?
Delete my account.
94 Thunderbird XX is offline
post #10 of 56 (permalink) Old 01-08-2011, 08:08 PM Thread Starter
I don't have any pics yet. I will once I get it tore apart. Hopefully this week if the weather cooperates since the real race car is in the shop and there is so much crap in the other bay of my shop
-17" Borbet wheels
post #11 of 56 (permalink) Old 01-09-2011, 03:59 PM Thread Starter
here is a picture of the crack, little bigger than I thought originally. Havent started to tear it apart yet, they are callin for 4-6 iches of snow tonight here
-17" Borbet wheels
post #12 of 56 (permalink) Old 01-09-2011, 04:43 PM
When you said, "when it shifted to 2nd is when the rear let go", I suspect you'll find a grenaded ring/pinion and/or trac lock/differential. I say that because the crack looks to have been pushed outward.
Now the question will be which came first: the grenaded innards causing the cracked case, or the cracked case causing the grenaded innards?
My money is on the innards failing first. I bet a bearing went out and allowed the ring/pinion to “meet” in a very “unkind” manner.
But I’m definitely no expert!
69 F100 LWB w/460 Engine
post #13 of 56 (permalink) Old 01-09-2011, 09:04 PM
Yeah, you'll have to get that diff out from under the car and give it a good autopsy. Until then, I'm leaning towards an internal failure too.
Delete my account.
post #14 of 56 (permalink) Old 01-09-2011, 09:06 PM Thread Starter
What's the quickest way you guys have found to pull those out. I was thinkin just pop the halfshafts out the sides and unbolt the driveshaft then just four bolts and it drops down. Am I right?
-17" Borbet wheels
post #15 of 56 (permalink) Old 01-09-2011, 09:10 PM
That's pretty much it. It takes a little longer to get everything ready to drop out the diff than it does to actually drop it out. Don't be intimidated by it though.
Have a good pair of jackstands and a good floorjack handy.
Delete my account.
post #16 of 56 (permalink) Old 01-09-2011, 09:14 PM
And while you're there.....what gears do you have? You may want to upgrade to a better ratio. Sounds like you need a TL as well.
Delete my account.
post #17 of 56 (permalink) Old 01-09-2011, 10:33 PM Thread Starter
If I had the money I would but I'll just be putting stock stuff back in place. I have 4.10s but I don't have a TL or the extra time and cash to have someone set up the gears for me. I'm assuming just seperate the rear control arms so you can swing the hub out enough to pull out the halfshafts?
-17" Borbet wheels
post #18 of 56 (permalink) Old 01-09-2011, 10:50 PM
i did a number on mine
im guessing that prostock launching a 5spd on dragslicks didnt help....any real power needs an iron case
mike
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #19 of 56 (permalink) Old 01-09-2011, 11:32 PM
I don't see a problem with the iron or aluminum case, the condition of the internal parts is what matters. The LPW cover has girdle support which would strengthen both parts.
post #20 of 56 (permalink) Old 01-10-2011, 04:40 PM
Now that's the kind of breakage I'm expecting to see whenever someone says they broke their diff.
Dragracer969, you're just going to have to try harder next time. lol
Delete my account.
post #21 of 56 (permalink) Old 01-10-2011, 05:10 PM Thread Starter
Lol I'm hopin there isn't a next time. The car might be getting sold this spring
-17" Borbet wheels
post #22 of 56 (permalink) Old 01-16-2011, 10:05 AM
The_coop_08's Avatar
Send a message via AIM to The_coop_08
Thats what i bought, was like $215! Its really beefy tho
Silver 96 T-bird
Major Mods: Stage II PI head swap w/Stage II cams, Kooks headers, 2.5" exhaust with borla xr1, 9.5" Converter 3800 stall, Aluminum rear 3:73 gears, lots of suspension and bolt ons. 13" Cobra brakes, ss lines, lowered 1.6" on staggered saleens
Tim Barth tuned at MPH 274rwhp/298rwtq on 93
Compiling parts for Vortech build
95 SC 5 speed: bone stock for now
The_coop_08 is offline
post #23 of 56 (permalink) Old 01-16-2011, 01:06 PM
To get the diff out: after the DS is unbolted, unbolt the diff, and let it drop down a bit. Put a jack under it, so it doesn't waste the halfshafts. You can lower it until the HS about touches the LCA.
Then you'll have to unbolt the lower knuckle bolts on one side, and pull that side out of the diff, then ease out the other halfshaft; a large flat screwdriver helps to pop the circlips out. (Remember, If one side has been off, it will be the easiest to get the bolts out of.)
I'd say "Be careful of the seals", but that's not going to be a problem in your 'case'.
That's the easiest way I found.
BTW, Does this ever happen in Auto tranny cars?
Grog6 is online now
post #24 of 56 (permalink) Old 01-16-2011, 06:22 PM
I'm guessing that prostock launching a 5spd on dragslicks didnt help....any real power needs an iron case
mike
You da'Man Joker.
Here are my pictures of Joker's handy work.
post #25 of 56 (permalink) Old 01-28-2011, 08:51 PM Thread Starter
Thunderbird XX, is this trying hard enough?? haha
http://a5.sphotos.ak.fbcdn.net/hphot..._5342968_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._1156218_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._2709700_n.jpg
http://a6.sphotos.ak.fbcdn.net/hphot..._3729154_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._5817422_n.jpg
I got the old diff out as you can see, the new one is in. surprisingly the new one went in a lot easier than the old one came out. the only things holding the one side of the housing on was the bearing inside. took a pretty good chunk out of the ring and the carrier itself and there were pieces of the pinion gear wedged up aroudn the pinion. Im gonna guess possible over tightening of the cover bolts when the last person changed the fluid or just a flaw in the cast like previously thought
-17" Borbet wheels
post #26 of 56 (permalink) Old 01-28-2011, 08:52 PM Thread Starter
also found out the car already has a 93 one-piece driveshaft. so now i have a spare lol
-17" Borbet wheels
post #27 of 56 (permalink) Old 01-28-2011, 09:10 PM
I think the phrase catastrophic failure applies here
post #28 of 56 (permalink) Old 01-28-2011, 09:21 PM
I went through two covers on my mark viii housing with my t-lok after the second one broke I shortly after replacing the cover broke the ears on the front although I suspect they may have been damaged durring one of the two cover incidents. I replaced the assembly with an iron carrier with a newer t-lok with an f150 spring, carbon fiber clutches, and a different cover. I've had no problems with the new unit.
post #29 of 56 (permalink) Old 01-28-2011, 10:20 PM
These braces are nice insurance May have helped .But my punkin is iron
Made by 94 Thunderbird XX
post #30 of 56 (permalink) Old 01-28-2011, 10:22 PM Thread Starter
id start spending money for that kind of stuff but my mark will be going up for sale in the next couple months, so i cant justify it.....it looks good though
-17" Borbet wheels
Last edited by dragracer969; 01-28-2011 at 10:22 PM. Reason: didnt wanna post twice
