Mini Spool - TCCoA Forums
post #1 of 11 (permalink) Old 01-16-2011, 10:56 PM Thread Starter
TonyD.'s Avatar
Mini Spool
Can a mini spool be used in an 8.8 instead of a trac lok? i want positraction but im on a tight budget
ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ
TonyD. is offline
post #2 of 11 (permalink) Old 01-16-2011, 11:07 PM
If you do any driving at all away from the track you don't want a spool.
post #3 of 11 (permalink) Old 01-16-2011, 11:54 PM
Buckcreekbilly's Avatar
If you just want a "posi" strictly for drag racing, on a cheap budget, weld the spider gears. Lol
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #4 of 11 (permalink) Old 01-17-2011, 10:25 AM
r429460's Avatar
A mini spool will work well, for mostly dragracing duty.
Don't weld.
r429460 is offline
post #5 of 11 (permalink) Old 01-17-2011, 11:58 AM
Dan Nelson's Avatar
It will work for the street but you will have to get used to it being always locked, the handling will change and it will cause a lot more stress on the axles and cv joints, and the pinion shaft that holds it in to the carrier will wear a lot faster than it did with an open rear.
Dan Nelson is offline
post #6 of 11 (permalink) Old 01-19-2011, 10:03 AM
i welded an open diff and put it in my 89...after a few passes i ended up breaking the cvshaft at the point were it goes into the spindle.with the welded diff i was able to drive it off the track to the trailer
a mini spool doesnt sound like to bad an idea
mike
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #7 of 11 (permalink) Old 01-19-2011, 11:19 AM
Dan Nelson's Avatar
mike
The shaft broke because the spiders were welded, spool or weld you will have the same broken shaft unless you upgrade the axles and even then it will find the next weak link.
A locker is by far more forgiving on the drive train. With a spool or welded spiders it is required to spin at least one tire in a corner and it is less stress on the drive train to spin both tires, so not the best street setup but it is doable with the correct upgrades.
post #8 of 11 (permalink) Old 01-20-2011, 04:27 PM
shaft didnt break because spiders were welded.....shaft broke because that is were they all break with to much torque from a 5spd launch
mike
1990 ford f150 5.0
1984 tbird 5.0 auto
post #9 of 11 (permalink) Old 01-20-2011, 04:45 PM
mike
so you had a 5 speed...hmmmmm...I have been thinking about a spool myself...
hmmm
hmmmm
hmmmmmmmm
post #10 of 11 (permalink) Old 01-20-2011, 06:00 PM
hmmm
hmmmm
hmmmmmmmm
yep 3500 rpm launch off the line on drag slicks with a 100 shot .i took the 5spd out and am installing a fmvb aod with transbrake now
mike
1990 ford f150 5.0
1984 tbird 5.0 auto
post #11 of 11 (permalink) Old 01-20-2011, 07:55 PM
+1 We "lincoln-locked" the front diff (welded the spider gears) on a mud truck and used a standard locker in the rear. Any time one front wheel would get wedged (a lot more traction) and the others spin - Snap! - another front axle gone. It got so bad we only used the truck for mud runs cause taking it 4 wheeling always broke axles.
~Rick
TCCoA Sig
