Track-Loc additive/extra clutches? - TCCoA Forums
post #1 of 7 (permalink) Old 02-04-2011, 08:46 PM Thread Starter
96blackbird's Avatar
Exclamation Track-Loc additive/extra clutches?
1:i have been told that a trick to make the clutches grab harder is to put only HALF the additive in so its enough not to tear the clutches up but allows for less slip. Is this true?
2:for someone who has tried, when my new T-loc diff gets here . i am going to do a clutch rebuild kit but i wanted to know if i will be able to put an extra clutch in?
Thanks!
"you make the most power rrrightt before the pistons melt"
96blackbird is offline
post #2 of 7 (permalink) Old 02-04-2011, 09:12 PM
I have to ask: What exactly are you planning to do with the car?
Street driven only?
Track only (drag racing)?
Track only (circle/roadcourse)?
Some combo of the above?
Delete my account.
94 Thunderbird XX is offline
post #3 of 7 (permalink) Old 02-04-2011, 09:28 PM
Unless you know exactly what you're doing in a rear end, I wouldn't suggest playing around inside. Anything out of spec (and the tolerances are VERY tight) and you'll have a noisy differential that could have abnormal gear wear.
No offense, but from the sound of things you might want to have someone help you in the event you tear it apart.
Friction modifier is specified to be added in a certain amount because that certain amount allows for optimal friction in the clutches. If your traction-lok rear end spins one tire with the correct amount friction modifier, the clutch packs are already shot and need a rebuild.
post #4 of 7 (permalink) Old 02-05-2011, 12:53 AM
I can tell you this. We ALWAYS use the GM 1052358 posi additive no matter what brand vehicle. Reason? It is superior and we've had issues with other manufacturer's additives. Mostly learned this from past 4 wheeling, mud-trucking days when we were really hard on differential clutches. It comes in a 4 oz container.
And yes, the additive is to allow more slip and less "chatter". If you used less additive, you run a greater risk of chatter. But if your rear end is turning wonderful after just adding 2 oz, I would run it!
~Rick
TCCoA Sig
post #5 of 7 (permalink) Old 02-05-2011, 12:17 PM Thread Starter
Street driven only?
Mostly street driven but im may do some scca solo races here and there, but mostly street
post #6 of 7 (permalink) Old 02-05-2011, 12:20 PM Thread Starter
Well if i can get away with putting less additive in and have it not hurt the clutches. i can deal with some chatter....im young haha.
post #7 of 7 (permalink) Old 02-05-2011, 02:00 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
I have never tried the Delco stuff. On my last rear, I used a bottle of lucas oil stabilizer and both tires seemed to spin (this makes it go sideways easier) on every hard shift and burnout with no clutch chatter on turns.
-Rob
Rob is offline
