4.10s - TCCoA Forums
post #1 of 24 (permalink) Old 05-18-2011, 12:48 AM Thread Starter
dew the thunder's Avatar
4.10s
I've searched but I don't think I'm using the correct phrasing or words...
My buddy has a set of 4.10s with really LOW mileage on them that he pulled out of his Mustang. From what I've been able to find, these will work fine in my Bird correct?
And if that is correct, what other parts will I need to source other than a new speedo gear and a tune? Will I be forced to change my driveshaft and do a forced lube setup on the tail shaft of the tranny? I know I will definitely have to change the shaft if I plan on exceeding upper 80s/lower 90s.
He is giving me a great deal on these gears and I don't want them just sitting around going to waste while I gather other parts that I don't ABSOLUTELY need.
-Brice-
1996 Thunderbird Sport 4.6L SOHC
85,300 miles
MODS:
Really rockin' stereo
Go-Parts
- Screamin' Demon packs - Livewire plug wires - Magnaflow resonated X pipe
PBR front brake conversion - 245/45-18 BFG KDWs - K&N hot air intake
H&R Sport Springs - Tokico Blues (F) - Bilstein Cobra Verts (R) - A/C Delete
Sights - New paint w/ black accents - 18x8 ASA JH9s - Painted calipers - Custom trunk layout
Sounds - JL Audio ZR525-CSi (F&R) - JL Audio 8W7-3 (2) - JL Audio HD900/5
Pioneer AVIC-Z120BT - AudioControl Matrix - ALL JL Wiring
The Daily Duties Handled By 2000 Audi A4 1.8T Quattro 5-Speed
dew the thunder is offline
post #2 of 24 (permalink) Old 05-18-2011, 01:35 AM
stay_unique_91's Avatar
The gears are all universal on all 8.8 differential cars. Mustang, Thunderbird, MkVIII, Cougar, F150, etc. On the other hand the differential is not universal, you need a 28 spline IRS compatible carrier.
The problem with the driveshaft is that as it spins it becomes less stable. It will eventually reach critical rotation and will bow and break eventually. You will notice vibration around 70 mph so, by 80 it will become unbearably loud. Continued driving like this will cause rear seal damage on the transmission and you will more than likely leak ATF.
You will need the driveshaft, but a forced lube set up will not be required. Also while your there, find yourself a LSD differential and install it. That is if you weren't one of the lucky few to attain the 3.27 TL option on your car.
Daily Driver - 2014 Ford Mustang GT 5.0 manual black on black. Stock for now.
Current Project - 1996 T-bird LX 4.6L: PI head swap, factory 3.27 TL, tuned by Don LaSota.
Retired Car - 1995 T-bird LX 4.6L: 4v swap plus Cobra goodies
stay_unique_91 is offline
post #3 of 24 (permalink) Old 05-18-2011, 07:06 PM
coggonobrien's Avatar
another required buy will be large meaty tires i like my 275/60r15 with my 4.10's
coggonobrien is offline
post #4 of 24 (permalink) Old 05-19-2011, 12:22 AM Thread Starter
Stay Unique - My car did come equipped with the 3.27 TL unit. So basically all I'll need to effectively run this in addition to the speedo gear is a new driveshaft? That sucks... time to start looking for an aluminum Mark shaft I guess.
Coggonobrien - My current BFG KDWs in 245/45/18 seem to be plenty sticky enough with the 3.27s. They'll probably shred exactly like I want them to with 4.10s. But in long term I plan on switching to 275s or 285s in the rear to help fill out the fender well a little more.
-Brice-
85,300 miles
MODS:
Go-Parts
post #5 of 24 (permalink) Old 05-23-2011, 12:22 AM
That drive shaft swap is pretty important. I think the cut-off for that is 3.55's if I remember correctly.
John Fritz is offline
post #6 of 24 (permalink) Old 05-23-2011, 01:39 AM
No, It is correct that you will need a new driveshaft, but you can not just swap the speedo gear, the PCM only corrects up to 2 steps up. So with 3.27's the highest you can go is 3.73's without a retune. Also the most important thing is not to run the 4.10 gear speedo gear, it will tear itself to pieces inside the tailshaft housing and junk your transmission from what I've read.
In order to run anything higher then 3.73's you will need:
1) A better 1 piece driveshaft, professionally balanced with new u-joints
2) A tune so your car doesn't top out at 90
3) A speedometer correction device such as a dallas speedcal (good luck with the actual settings)
post #7 of 24 (permalink) Old 05-23-2011, 03:04 PM
If you do the gear swap and don't do the tune, will the engine hit the limiter before it knows to upshift? Assuming you were hard enough into the throttle for this to happen.
post #8 of 24 (permalink) Old 06-01-2011, 08:28 AM
mechman1984's Avatar
You will also need new pinion bearings, seal, crush sleeve, a few pinion shims and some other miscellaneous stuff. You will also need access to a press. From what I have read as long as you are reusing your differential then a gear swap is very trivial and should not require much if any shimming to get the proper patterns. I am curious myself to hear about how 4.10s work in a street driven tbird. I was just thinking the other day that gears might be a good upgrade.
Will
Will
08 Ford Ranger
95 Thunderbird V8-Sold!
mechman1984 is offline
post #9 of 24 (permalink) Old 06-01-2011, 08:55 AM
tbirdtess's Avatar
8.8?
Hello
Are you sure both are 8.8's?
I have 7.5 3.27's form my t-birds & 4.10's from a van, also 7.5"
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #10 of 24 (permalink) Old 06-01-2011, 09:15 AM
Banned
91bluecoupe's Avatar
Dew The Thunder,
Also just so you know NO 4.6 Thunderbirds came from the factory with TL. Or they would have to order it that way.
To get TL a buyer would have to request it.
If you have a TL unit then someone swapped in the diff.
Look at the tag on the diff it will have a TL on it.
91bluecoupe is offline
post #11 of 24 (permalink) Old 06-01-2011, 11:32 AM
Originally Posted by 91bluecoupe View Post
Dew The Thunder,
Also just so you know NO 4.6 Thunderbirds came from the factory with TL. If you have a TL unit then someone swapped in the diff.
AFAIK No Mark VIII's came with a TL, but TL's were an available option for many Thunderbirds/Cougars.
69 F100 LWB w/460 Engine
post #12 of 24 (permalink) Old 06-01-2011, 11:44 AM
davis97xr7's Avatar
Dew The Thunder,
Also just so you know NO 4.6 Thunderbirds came from the factory with TL. Or they ordered it that way.
Trac-Lok was a factory installed option.
-Joe-
1994 Ford Thunderbird SC 5-Speed
1996 Ford Mustang SVT Cobra #1251
davis97xr7 is offline
post #13 of 24 (permalink) Old 06-01-2011, 12:51 PM
CableguyJJS3's Avatar
Send a message via AIM to CableguyJJS3 Send a message via Yahoo to CableguyJJS3
Dew The Thunder,
My 97 came with a 3.27 TL rear straight from the factory, and nearly every SC ever built also had a TL, if not all of them. The above information is not at all correct with the exception of the tag. If it is a original to the pumpkin and it is equipped with TL it will read something like 3 L 27 or whatever gear is in there, or 3 27 if no TL is in there, the space between the numbers designates it as an open rear end. From what I recall, you could have 2.73, 3.08 or 3.27 from the factory in either TL or open, and the Mark VIII's came with a 3.07 open rear and as far I as know that was the only option.
Ban low performance driver's, not high performance cars.
"Any idiot can make a Mustang fast, but it takes a special kind of idiot to make a Thunderbird fast."
CableguyJJS3 is offline
post #14 of 24 (permalink) Old 06-01-2011, 01:26 PM
davis97xr7's Avatar
Originally Posted by CableguyJJS3 View Post
My 97 came with a 3.27 TL rear straight from the factory, and nearly every SC ever built also had a TL, if not all of them. The above information is not at all correct with the exception of the tag. If it is a original to the pumpkin and it is equipped with TL it will read something like 3 L 27 or whatever gear is in there, or 3 27 if no TL is in there, the space between the numbers designates it as an open rear end. From what I recall, you could have 2.73, 3.08 or 3.27 3.31's were also available from the factory in either TL or open, and the Mark VIII's came with a 3.07 open rear and as far I as know that was the only option LSC's came with Open/3.27's.
-Joe-
post #15 of 24 (permalink) Old 06-01-2011, 02:03 PM
The only MN12s you couldn't get TL on were cars with traction assist, otherwise base to SC had the option over the years.
post #16 of 24 (permalink) Old 06-01-2011, 02:30 PM
Banned
My 96 Tbird had all the options except for TA and ABS.
But it still did not have TL. Just 3.27 open diff.
post #17 of 24 (permalink) Old 06-01-2011, 02:50 PM
My car came with every option including ABS/TA, sunroof, autolamp, JBL, CD changer, ect, but didn't have SACT! It's all a matter of how they were ordered, that's why they're options.
post #18 of 24 (permalink) Old 06-01-2011, 09:32 PM Thread Starter
I'm fairly sure the only two options my car did not have from the factory is TA and Premium Sound.
Really all I need to know is exactly what parts I will need to acquire before I take this car to a shop and they look at me with a stupid expression wondering why I want 4.10s in a Thunderbird.
Will - I will be having a shop do the installation as this is not something that I am qualified to do nor do I have the time to do it myself. My friend, whom I am acquiring the gear set from, said that I can buy a installation kit of some kind that includes all those wear parts and the shims. Hopefully I can have this done by the end of summer but springs and exhaust are far above gears on priority. If/when I get it done, I'll let you know how the road manners are. I am prepared to kiss any and all wet traction goodbye with my foot.
Paul - Yes, I am sure that the diff in my friend's Mustang is an 8.8 and that my diff is also an 8.8.
-Brice-
85,300 miles
MODS:
Go-Parts
post #19 of 24 (permalink) Old 06-01-2011, 10:29 PM
tbirdtess's Avatar
I purchased a kit from Motive Gear, when I put in my 3.90's
I would pick up another 8.8 center section, Put the gears & TL in.
Then swap sections. I can swap centers in a couple of hours, by my self.
351W 2bbl.
C-4 Auto
3.90 open rear
post #20 of 24 (permalink) Old 06-02-2011, 01:55 AM
ogbird95's Avatar
so what is the button saying trak lock on the center councel ? when i push it, it says off?
yeah what is that? i hope its cool
ogbird95 is offline
post #21 of 24 (permalink) Old 06-02-2011, 02:22 AM
It's traction assist, it's pretty much useless with a trac lok differential
post #22 of 24 (permalink) Old 06-02-2011, 02:55 AM
Basically when the computer detects wheel spin it uses the rear brakes to eliminate wheel spin. It's a very crude traction control system. Due to it's sometimes aggressive nature it can give the illusion or feel of having a limited slip differential and even leave a two wheel peel from what I've experienced in the past, but ultimately it is over rated and doesn't do it's limited job even remotely well. It does however wear brake pads nicely in the rain on the v6 models.
post #23 of 24 (permalink) Old 06-02-2011, 10:58 AM
Send a message via Skype™ to KJH95
Is there any short term effects to 2.73.s in a car tuned for 4.10s. Until I can get a new set of 4.10
KJH95 is offline
post #24 of 24 (permalink) Old 06-02-2011, 01:41 PM
Faster than Porkchop
cjchevez's Avatar
I'm running a 4.10 tune with 3.27's, the only difference is shift points. When I floor it I have to take the OD off so that it shifts sort of like when I had the 4.10's. If not It just wont move.
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
