any oil recommendations - TCCoA Forums
post #1 of 5 (permalink) Old 07-31-2011, 11:43 PM Thread Starter
coggonobrien's Avatar
swapping my 4.10 posi into my new car, any recommendations on a readily available oil for it, how much do I need, and does it recquire an additive for the trac-lok (if so what and how much)
David
coggonobrien is offline
post #2 of 5 (permalink) Old 07-31-2011, 11:46 PM
David
I used some Valvoline synthetic on mine recently to top off, and it had the friction modifier in it.
First recommendation : A synthetic if you can.
Second: If it doesn't specify it has the friction modifier for limited slip diffs, then yes, you'll need the additive.
Past that, I suggest your favorite. I mean, I'd have LOVED to use Royal Purple, and it wasn't that much, but they didn't have any when I found out I couldn't feel any with my finger in the fill/check hole.
RalphP is offline
post #3 of 5 (permalink) Old 08-01-2011, 03:08 AM Thread Starter
what's the easiest way to fill in chassis?
post #4 of 5 (permalink) Old 08-01-2011, 03:50 AM
Long hose and a funnel.
Did you really just call a Trac Lok a Posi?
post #5 of 5 (permalink) Old 08-01-2011, 09:02 AM
*shrug* My lube came in a plastic jug that fits good enough to get started topping off, no funnel needed. I just clipped the end off the spout, shoved it into the fill hole, and started squeezing.
Helps I used to help my first wife with cake decorating
RalphP is offline
