CV Axle/Half Shaft - TCCoA Forums
post #1 of 11 (permalink) Old 08-04-2011, 09:45 PM Thread Starter
stay_unique_91's Avatar
CV Axle/Half Shaft
Just curious haven't been able to find it on here thus far. What is the size of the nut that connect the CV axle/Half Shaft to the Knuckle/Hub assembly? It's ridiculously large, bigger than my 32mm at least. Also, while I am here, what is the torque specs on that nut??
Daily Driver - 2014 Ford Mustang GT 5.0 manual black on black. Stock for now.
Current Project - 1996 T-bird LX 4.6L: PI head swap, factory 3.27 TL, tuned by Don LaSota.
Retired Car - 1995 T-bird LX 4.6L: 4v swap plus Cobra goodies
stay_unique_91 is offline
post #2 of 11 (permalink) Old 08-04-2011, 10:14 PM
36mm, 250 ft/lbs
post #3 of 11 (permalink) Old 08-04-2011, 10:16 PM
DLF
DLF's Avatar
36mm ~250 Lb-Ft.
My Web Site
DLF is offline
post #4 of 11 (permalink) Old 08-04-2011, 11:25 PM Thread Starter
Wow thats maxing out my torque wrench! Ok thanks for the information.
post #5 of 11 (permalink) Old 08-04-2011, 11:48 PM
pettyfog's Avatar
Make sure that breaker bar is warranteed. And front wheels are securely chocked.
Sad part is anything less than a shop impact wrench wont do it, either. You need the kind that'll snap your lug studs right off.
pettyfog is offline
post #6 of 11 (permalink) Old 08-05-2011, 12:11 AM
Pettyfog - Not our fault you're whiplash thin
At 5 foot 8 and 315 pounds, with a 24" breaker bar, I have NO problem getting them off *snrk*
It's you whisper thin guys what has fits
RalphP is offline
post #7 of 11 (permalink) Old 08-05-2011, 07:29 AM
PaGreenCat's Avatar
It's not impossible to remove, even in the junkyard.
I hit the set I removed with a good dose of your loosener of choice (PB or Kroil, I used Kroil).
That and standing on a Craftsman 1/2" drive with a screwdriver holding lugs from turning got both loose.
Now putting them on is another story
The manuals recommend you use new bolts when putting them back on. With the amount of Torque involved, I would agree.
PaGreenCat is offline
post #8 of 11 (permalink) Old 08-06-2011, 01:10 AM Thread Starter
I have a Snap-On impact that I paid a pretty penny for so hopefully it will knock it off. haha.
post #9 of 11 (permalink) Old 08-06-2011, 12:50 PM
The kind of bolts they are is why you don't want to reuse them.
They are either purposely deformed, or multiple layers each with slightly different threads; they will not come off by themselves if set properly, but they "roll form" the threads when they get taken off in a way that will let them come off easier. And it gets easier each time you use them from there...
Remember to roll the wheel when you reinstall these; the bearings will move very slightly under the large torque, and you want the bearings touching when you put final torque on it. Take it up to the final torque in two or three steps.
I also recommend rechecking them daily for a few days after you install one; I'd hate to lose a wheel.
post #10 of 11 (permalink) Old 08-06-2011, 06:17 PM
PaGreenCat's Avatar
Good to note. I did put in new bearings on the knuckles (or rather had a shop do it).
post #11 of 11 (permalink) Old 08-07-2011, 11:22 PM
Send a message via Skype™ to KJH95
I used the bar from the jack as a breaker bar. Easy as pie.
KJH95 is offline
