will the spider gears from an open diff go into an IRS diff - TCCoA Forums
post #1 of 6 (permalink) Old 08-26-2011, 03:49 PM Thread Starter
my friend, reloader, and I are both thinking of doing the trac-lok diffs in our cars. I am just curious if the open diff spider gears will go into the trac-lok diff? I have not read on here any one saying to just swap out the spider gears from the open diff, but i thought I would double check and see if we could do that, He is changing the spider gears on an 04 cobra carrier and housing to make it a 28 spline. I will be changing the spider gears on a mustang 8.8 carrier to make it an irs carrier so it has the beveled edge pnt eh spider gears. Thank you again for your help.
Mark
fordfreak300 is offline
post #2 of 6 (permalink) Old 09-08-2012, 02:32 PM
MadGoat's Avatar
Send a message via AIM to MadGoat Send a message via MSN to MadGoat
I'm curious about this as well...
As it stands I have a spare Open T-bird pumpkin I would like to build up. I can grab a 8.8 solid axle trac-lok carrier from the shop. If I can pull the spider side gears out of the open diff and rebuild the 8.8 solid axle carrier with them, that would be great!
Thanks ahead of time...
MadGoat's Birds
94 Thunderbird LX 4.6L PI
03 Aluminum PI Engine, J-Mod, Aluminum one piece drive shaft, 3.27's, 2.5" to single 3" custom MagnaFlow exhaust, 07 17x8 Bullit Wheels
97 Thunderbird LX 4.6L V8
RIP
MadGoat is offline
post #3 of 6 (permalink) Old 09-08-2012, 02:53 PM
Won't work. The spider gears for trac-lok have outer splines on the carrier side to hold the clutches in place. Opens are completely smooth
post #4 of 6 (permalink) Old 11-26-2014, 08:34 AM
Those would be the side gears, with the splines for the steel plates in the clutch packs. But perhaps the "pinion" spider gears are the same?
I have heard the smaller gears called "pinion" gears, not to be confused with the other "pinion" gear in the differential.
Blaine B. is offline
post #5 of 6 (permalink) Old 11-26-2014, 03:51 PM
Technically speaking the splined gears are side gears and the other two are spiders. I've never heard those referred to as pinion gears.
post #6 of 6 (permalink) Old 11-26-2014, 04:26 PM
I saw them called that on the sheet that is included with a Ford spider gear kit.
"Differential pinion gear" and "limited-slip differential side gear"
so I guess the "pinion/spiders" are the same between open and traction lock units.
I just replaced my spider gears when I rebuilt the traction lock. Some of the smaller "pinion/spiders" were chipped.
