Ford 8.8 IRS Questions - TCCoA Forums
post #1 of 11 (permalink) Old 11-07-2011, 01:58 PM Thread Starter
Raptor22's Avatar
I have a friend on another forum that knows I have a Thunderbird and PMed me some questions about the differentials in our cars, however I dont really know the answers to most of them but I figure most of you guys probably do. Here's the PM:
Originally Posted by Speed_Demon
I am having little luck in finding pictures and info on these IRS 8.8's out of the Explorers and Mark 8/T bird's. I am curious about a possible swap into my 240sx.
Do you have any decent pics of the pumpkin by itself?
Also, do you know of any years that had an aluminum pumpkin as well as stub shafts to bolt axles to, rather than splined axle ends that insert into the diff? If there were none, is it possible to swap parts over to get this setup?
This is what I mean - http://i53.photobucket.com/albums/g41/addaea/4361_1.jpg
I need those diff output flanges with the lighter aluminum case. The IRS 8.8 should survive with around 600hp at the wheels, right?
Hopefully you guys can help us.
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #2 of 11 (permalink) Old 11-07-2011, 03:16 PM
The aluminum pumpkin came on all MarkVIII's, as well as the 99-04 cobras. I wasn't aware of anyone making a stub shaft conversion, but evidently someone did because that diff in the link is an 8.8 out of an MN12. Whatever it is, it has to be aftermarket because it was never factory installed by ford.
MadMikeyL is online now
post #3 of 11 (permalink) Old 11-07-2011, 03:49 PM
skinnytick's Avatar
Let me know if you need more pictures as it is not installed yet.
Differential from FRPP catalog.
skinnytick is offline
post #4 of 11 (permalink) Old 11-07-2011, 05:09 PM
Outside of the half-shafts, there isn't a whole lot of difference between IRS and a live axle. After a certain year, all 8.8 rears had beveled side gears (I'm not sure of what year). Older 8.8" Ford rear ends side gears are not beveled at an angle for easy removal of the half shafts.
There are also two different spline counts for the axles, 28 and 31 spline.
I'm not sure I'm getting the question I guess. Cause the more I read the OP's first post, I'm realizing I'm way off for what he's asking. lol
I'll let someone with more experience with the pic he posted give some answers. Sorry.
As for the 600hp mark, there are plenty of Cobra's with more HP than that running with the IRS rear.
~Rick
TCCoA Sig
post #5 of 11 (permalink) Old 11-07-2011, 06:28 PM
Anyone know what year this bevel started? I am getting a carrier from a 94-98 mustang. Not sure of the year. And if it has the beveled gears already that would save me some money and time. How can I tell if the gears have the appropriate bevel or not?
Thank you
Mark
fordfreak300 is offline
post #6 of 11 (permalink) Old 11-07-2011, 07:06 PM
Thank you
Mark
That's too early. They need machining.
The change was this millennium sometime. Not sure when, but I only heard about it in the last couple of years.
Grog6 is online now
post #7 of 11 (permalink) Old 11-07-2011, 07:37 PM
I am going with the easy solution, send my side gears to dirtydogracing and get them machined
post #8 of 11 (permalink) Old 11-07-2011, 10:44 PM
skinnytick's Avatar
Thank you
Mark
I'm confused, I thought 94-98 Mustangs all came with solid rear axles.
post #9 of 11 (permalink) Old 11-07-2011, 10:52 PM
If I were to take a wild guess I'd say those stubs are from a GTO
post #10 of 11 (permalink) Old 11-08-2011, 05:39 AM
SATURN5's Avatar
GTO are 6 bolt.
84 SVO Bright Amber Met, B234F 16V Volvo head conversion, RPE custom intake, header, FMIC, 38MM BOV, RPE modified diamond pistons, Crower rods, HE351 Holset, 44MM WG/dump, A1000/sumped tank, -8AN lines, 72lb injectors, 03 Cobra hydroboost, rack, brakes, IRS, Bilsteins/coil overs, MM lower control arms, RPE bumpsteer kit, T-tops
96 Mark VIII Black, black, Bullitts, Hub swapped/redrilled rear hubs, full RPE chassis brace kit, Maruader TC, Jmod
68 F100 Flareside CVIFS/M8IRS, 32V, T45, Cobra brakes, hydroboost, 3.55, 03 Cobra wheels
RAW Performance Engineering
SATURN5 is offline
post #11 of 11 (permalink) Old 11-08-2011, 05:09 PM
davis97xr7's Avatar
You are correct. The actual 8.8 differential works in both solid and IRS setups though.
-Joe-
1994 Ford Thunderbird SC 5-Speed
1996 Ford Mustang SVT Cobra #1251
davis97xr7 is offline
