Pumpkin swap....how much oil? - TCCoA Forums
post #1 of 15 (permalink) Old 01-08-2012, 03:07 PM Thread Starter
Gonna swap the rear ends from a 97 sport (3.27 ls) with the one in my 94 LX (3.08 open).
The replacement pumpkin has 137k on it so I was gonna drain and refill it with Mobil 1 75/90 LS gear oil. How many bottles is it gonna take? Do I need to add additional friction modifier if using the the LS oil.
Also is there a gasket for the cover?
Any trick to pulling the driveshafts out of the pumpkin? Or putting them back in?
Max
2014 Chevy SS
1995 T-Bird LX 4.6
1994 T-Bird LX 4.6
2014 Chevy SS Sedan
2013 Camaro SS
2009 Dodge Charger Daytona
1975 Oldsmobile Delta 88 Royale Convertible 455.
Smkn600ctd is offline
post #2 of 15 (permalink) Old 01-08-2012, 03:18 PM
THe only trick I know of I using a 12mm gear wrench and a light blow hammer. I pop the cover cover off the get all the old oil out.
I cant answer your question of if you should use the ford friction mod. Just use mtorcraft gear oil and add the FM if you have any doubt.
People go with and without gaskets. I have one and it doesnt leak and I used gray rtv to seal it back up after the break in.
post #3 of 15 (permalink) Old 01-08-2012, 05:26 PM
It will take about 1 1/2 quarts of differential oil. Mobil 1 LS Gear lube already has modifiers so you do not need to add any additional friction modifier.
Yes, you need a standard Ford 8.8" differential gasket (some people don't use them, but you should).
I've never removed 'Bird half-shafts, but I've done plenty of front-wheel drives and I just pop the shafts out with a crow bar.
~Rick
TCCoA Sig
post #4 of 15 (permalink) Old 01-08-2012, 05:27 PM
I used black RTV to re-seal. Took about 1.75 quarts of fluid.
post #5 of 15 (permalink) Old 01-08-2012, 05:51 PM Thread Starter
Ok.....thanks. Hopefully no surprises tomorrow doing the swap.
Max
2014 Chevy SS
1995 T-Bird LX 4.6
1994 T-Bird LX 4.6
2014 Chevy SS Sedan
2013 Camaro SS
post #6 of 15 (permalink) Old 01-08-2012, 05:52 PM
Mgino96tbird46's Avatar
When the 3.73 TL rear was put in my car, it took 2 qts of oil and a container of the Ford friction modifier. For oil, I used Royal Purple 75W-140. When I replaced the oil in my old rear end, I just used ultra black rtv as the cover gasket. Laid down 3 rows of it and let it set for an hour before refilling.
Mgino96tbird46 is offline
post #7 of 15 (permalink) Old 01-08-2012, 06:18 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
+1 For RTV. I have always used this in the past with good results.
-Rob
Rob is offline
post #8 of 15 (permalink) Old 01-08-2012, 07:04 PM
ClintD's Avatar
I always use RTV on the differential cover. As a matter of fact so did Ford!
ClintD is offline
post #9 of 15 (permalink) Old 01-08-2012, 07:08 PM
Yup. Even the Ford shop manual tells the technicians to do the same thing.
post #10 of 15 (permalink) Old 01-08-2012, 08:27 PM
sousa632's Avatar
I've never done it before, however every time I have seen a diff opened, RTV was used to seal it back up. Not a gasket.
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #11 of 15 (permalink) Old 01-08-2012, 08:50 PM
75w140 is a bit thick. I run the factory spec 80w90 or 75w90 even here in Las Vegas. Friction modifier is required on any ford trac-lok differential, if there is friction modifier added to the product contact the hotline on their bottle to confirm that it is enough for a ford limited slip differential. I know of a few that call for the factory additive on top of their own additive package mixed into the oil.
As far as gasket or no gasket If your using the factory cover RTV only. If your using an aftermarket cover like the LPW unit then I'd use the gasket only. I wouldn't use both, but I have seen and heard of people doing so.
post #12 of 15 (permalink) Old 01-08-2012, 09:06 PM
I just did as RobertP recommended.
post #13 of 15 (permalink) Old 01-08-2012, 09:55 PM
I know at the shop we always use RTV because that's what the boss tells us to do. Like y'all said, most every rear end I see come in there was sealed with RTV. The fluid is so thick, it's not likely to leak.
As for the Mobil 1 LS fluid - that's totally synthetic which is great to use and it includes all modifiers for the trac-lok. It's also much thinner than standard 75-90, 75-140, or whatever other conventional y'all use, which is why - again - if it was MY vehicle and I was running total synthetic, I'd use a gasket.
~Rick
TCCoA Sig
post #14 of 15 (permalink) Old 01-08-2012, 10:16 PM
I ran Valvoline full synthetic with my original ford trac-lok limited slip differential without issue.
I was told NOT to run the full synthetic with the carbon clutches and stiffer s-spring in my rebuilt unit by my local builder and the ford fluid hotline. Currently I use 80w90 conventional with the ford friction modifier.
Contrary to what many think the modifier doesn't make the clutch type engage it actually makes it slip to avoid chattering and damage.
I was told that with the setup I'm using I would risk excessive slipping even with straight synthetic with no modifiers. Hence fully synthetic with a friction modifier would only be worse.
As far as synthetic being thinner theoretically it shouldn't be any thinner hence why the weight is the same, however it does typically flow faster than or looser then conventional. Which is one of the reasons why it is a better lubricant, on top of the fact that it resists thermal breakdown, varnishing, and foaming better.
post #15 of 15 (permalink) Old 01-08-2012, 11:11 PM
Synthetic oil is WAY thinner at all grades. Go pour out a bottle of 75-90 conventional versus a 75-90 fully synthetic if you don't believe it. Viscosity (weight) numbers (for the most part) refer to the oil's resistance to allowing contact of two metal surfaces (of which synthetic is FAR superior; this property changes with temperature. Point being, it's not how "thick" the oil is (not totally, anyways).
Good reading about it here:
http://www.synthetic-oil-tech.com/Ge...te%20Paper.pdf
Oh, and most synthetics do not require frictions modifiers added AT ALL. And yes, the modifier added to conventional is to allow slip for chatter control, not make it grab as you stated.
As for not running synthetic with carbon clutches, I have no idea - haven't had enough experience with them. If that's what you were told by some experts and it works for you, then go for it!
~Rick
TCCoA Sig
