Diff Recommendation for Big Torque - TCCoA Forums
post #1 of 51 (permalink) Old 01-23-2012, 02:02 PM Thread Starter
What are the cars making over 400 lb-ft using for differentials? Anybody using an Auburn Pro or Ected Max? How are they holding up?
I've got a Torsen T2 that has survived about 120 dragstrip launches, but most of those were before the latest combo which puts down 416 lb-ft.
MikeB
1997 Thunderbird Sport
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #2 of 51 (permalink) Old 01-23-2012, 07:10 PM
I am a believer in 31 spline ford OEM housings, for big torque you nmeed to look at a level 5 setup for the rear and modified cobra axles. Stack the clutches with 4 on each side for a 25% upgrade and use a solid pinion spacer.
post #3 of 51 (permalink) Old 01-23-2012, 07:29 PM
I'm running a stock track loc unit with 516 ft lb
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #4 of 51 (permalink) Old 01-23-2012, 07:29 PM
+1 on that solid pinion spacer.
Delete my account.
94 Thunderbird XX is offline
post #5 of 51 (permalink) Old 01-23-2012, 09:07 PM
I'm still using a Trac-Loc with the alternate stacking and F-150 S-spring at 478rwhp/390 rwtq. No issues thus far. I want to say that David Neibert's '91 SC (499.66 rwhp/467.65 rwtq) is running the same, and his '93 turbo'd SC (726.7 rwhp/592.2 rwtq) is running a Auburn Pro. If I ever kill the Trac-Loc, I'll either rebuild it or go to a Auburn Pro.
post #6 of 51 (permalink) Old 01-23-2012, 10:01 PM
driller's Avatar
My take on it is the clutch type differentials will smoke the clutches at about the same torque level as when the gear type differentials break.
driller is offline
post #7 of 51 (permalink) Old 01-23-2012, 10:10 PM
Sounds about right and if you need stronger than that you get a spool!
post #8 of 51 (permalink) Old 01-24-2012, 07:48 AM Thread Starter
Alan,
I realize that differentials are not the core of your business, but do you build them? If not, who would you recommend to set me up with all the hardware you described? I have a good shop locally who could install the parts, but they are not a high performance builder.
MikeB
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #9 of 51 (permalink) Old 01-24-2012, 07:57 AM
The best rear end out there is a true trac way stronger that a torsen I broke a torsen in my 86 in 3 passes with the blower, been running a true trac ever since, I installed a tru trac in oscars rear end build
10.75 @128.38
RobertP is offline
post #10 of 51 (permalink) Old 01-24-2012, 12:05 PM Thread Starter
Robert,
Do you happen to know the part number for the Tru Trac which works with IRS? Do you also recommend 31-spline axles?
MikeB
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #11 of 51 (permalink) Old 01-24-2012, 01:21 PM
392Bird's Avatar
I am running a Tru Track aka Detroit Locker in mine that holds up fine. It is pretty rough for regular street use, but much stronger than the clutch or gear type units. I have to be very careful with the gas while doing any turning, since it goes from normal differential action in a corner to like a spool with just a slight increase in gas pedal action.
I have been using this for 9 years with no problems. It takes almost as much concentration driving as a Spool does. I am above 800 on Torque and HP, but I only run it 3-4 times a year, and use Drag Radials only. At least using a steady gas pedal, it will turn a corner normal, unlike a spool.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #12 of 51 (permalink) Old 01-24-2012, 01:24 PM
Originally Posted by MikeB View Post
Alan,
Are you talkign abotu the level 5 setup? There was a thread all about it on sccoa you might want to go look for. The cobra IRS axles I guess you have to find reman or used. Level 5 is expensive. That is the setup Mike Siska has in his. Prepare to put $1500 or more in it not counting the differential.
post #13 of 51 (permalink) Old 01-24-2012, 02:02 PM Thread Starter
392Bird,
I certainly don't want something with a hair trigger on the street. Are we confusing two products here? Eaton makes both the Detroit Locker (which sounds like what you have) and the Detroit Truetrac, which is an all-gear limited slip (apparently similar to the Torsen but stronger).
dirtyd0g,
Yes, I'm talking about a Level 5 setup, if that is what I need for reliability. But, as noted above, it also needs to be fully streetable since that is where the car spends most of its time. I'm willing to put a couple thousand into the right set of hardware.
MikeB
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #14 of 51 (permalink) Old 01-24-2012, 02:04 PM
Yes he is talking about the locker the tru trac is smooth
10.75 @128.38
RobertP is offline
post #15 of 51 (permalink) Old 01-24-2012, 03:54 PM
392Bird,
dirtyd0g,
have you thought of doing a straight axle swap?
post #16 of 51 (permalink) Old 01-24-2012, 03:57 PM
dirtyd0g,
Check the thread on sccoa you'll have to buy direct from level5 I don't think they do any vendor discounts. Several of the guys are talking about doing a group buy. I know Neibert for sure was thinking about the swap.
post #17 of 51 (permalink) Old 01-25-2012, 01:55 PM Thread Starter
_95badbird,
No, not seriously. I like the ride and handling with the IRS.
dirtyd0g,
I read a couple threads regarding diffs and halfshafts at SCCoA. Still confused: is Level 5 a company, or is it a product from The Driveshaft Shop?
MikeB
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #18 of 51 (permalink) Old 01-26-2012, 07:48 PM Thread Starter
OK, ignore the under-informed question above. I went back to SCCoA and reread those threads, plus several more. Now I think I understand that Level 5 is DSS halfshafts with 31-spline inner and 33-spline outer ends, which require special hubs. Level 2, then, must be 28 or 31-spline inner and 28-spline outer ends. Both would be stronger than what I have, but Level 5 is the strongest possible IRS setup.
So, back to my original inquiry. Assuming I can resolve the high IAT issue (working on that now) and get more timing advance into the tune, I could end up with ~400 RWHP and ~450 RWTQ. The car is never going to have nitrous or a transbrake, and likely will stay on DRs. Given all that, do I really need Level 5 or would Level 2 be enough? The combination I'm thinking about upgrading to would be a Detroit Truetrac and DSS Level 2 shafts, both 31-spline. Will likely go back to 3.73 gears at the same time. What do you guys think?
MikeB
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #19 of 51 (permalink) Old 01-26-2012, 08:28 PM
Honestly, stock SC halfshafts would suffice, especially if you switched to a set of bias-plys instead of DR's. Level 2 shafts should be more than strong enough.
post #20 of 51 (permalink) Old 01-26-2012, 10:12 PM
The stock stuff is plenty strong, Hans ran 11.47 with a 1.59 60ft if u want something stronger just supercoupe half shafts
10.75 @128.38
RobertP is offline
post #21 of 51 (permalink) Old 01-26-2012, 11:34 PM
I actually trust the markVIII shafts more because the outboard joint is hardened and that is where they break first.
post #22 of 51 (permalink) Old 01-27-2012, 05:26 AM Thread Starter
Thanks for the quick feedback. So, Mark VIII shafts, assuming I can find a set in good condition, and stay 28-spline at both ends. Is there anybody out there who reconditions these parts? I prefer to put new or "like new" parts on my car, which is part of what attracted me to the DSS shafts. Also, would adding a diff cover with IRS girdle be worthwhile?
MikeB
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #23 of 51 (permalink) Old 01-27-2012, 07:49 AM
Yes I'm running the atomicperfoance cover
10.75 @128.38
RobertP is offline
post #24 of 51 (permalink) Old 03-29-2012, 10:30 AM Thread Starter
Reviving an idle thread. I considered everybody's input but went for the overkill solution anyway. Ordered DSS Level 2 31-spline axles from Lethal Performance today, along with new 3.73 gears, installation kit and a Ford Racing IRS diff girdle. Also ordered a Detroit Truetrac 31-spline diff from Summit because Lethal could not match their price.
Interesting sidelight: the price Lethal has been advertizing for the DSS axles on their website was wrong ($176 lower than intended) and they changed it this week. But, they honored the old price for my order.
These parts will make the rear of the car as "bulletproof" as possible, make it a better cruiser, eliminate the diff / gear noises I've been hearing, and other than occasional fluid changes I should never need to touch that part of the car again.
MikeB
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #25 of 51 (permalink) Old 03-29-2012, 11:27 AM
As I've stated stock is pretty stout being I'm at 660 rwhp and 516 torque I run drag radials on the street as it still breaks loose at 75 80 mph
10.75 @128.38
RobertP is offline
post #26 of 51 (permalink) Old 03-31-2012, 02:05 PM Thread Starter
Rob or Alan,
Since I'm changing from 28-spline axles and diff to 31-spline, do I also need to change the side gears?
Does somebody make a rebuild kit for the 8.8" IRS that includes all bearings and seals needed for a complete freshening?
MikeB
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #27 of 51 (permalink) Old 03-31-2012, 02:25 PM
Well the truetrac u bought is 31 spline? Correct if so u don't need to change anything, if u are keeping a trac lok u need a 31 spline trac lok
Let me know if this is what your asking
10.75 @128.38
RobertP is offline
post #28 of 51 (permalink) Old 03-31-2012, 05:46 PM Thread Starter
The Truetrac I bought is 31 spline. Not having had an 8.8" IRS rear end apart before, I'm not clear on whether the axles connect via splines with the side gears.
MikeB
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #29 of 51 (permalink) Old 03-31-2012, 08:23 PM
Moderator & Teksid Whore
guitar maestro's Avatar
Truetrac FTW. As for your question, I know Rob will know for sure, but I think you'll be OK with what you have; the truetrac's side gears will accept the correct # of splines from the halfshafts.
guitar maestro is offline
post #30 of 51 (permalink) Old 04-01-2012, 08:40 AM Thread Starter
OK, I misunderstood the exploded drawing in the Service Manual. The side gears must be inside the differential, which means they came with the 31-spline Truetrac.
Been looking at rebuild kits online. It appears the Ford Racing M-4210-B or B1 (which includes high torque pinion bearing from the Shelby GT500) would be good choices. Anybody on here have experience with either of these kit?
Also found an old TCCoA tech article which says I need P/N 714569 axle shaft oil seals which are not in the FRP kits.
MikeB
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
