Differential Cover Cleaning - TCCoA Forums
post #1 of 32 (permalink) Old 05-01-2012, 03:47 PM Thread Starter
Goldeneagle's Avatar
Question Differential Cover Cleaning
What is the best cleaner for the aluminum differential cover? I've tried brake cleaner, carb cleaner, various aluminum wheel cleaners, wire brushes attached to a drill,and high presser washer. And still can't get it completely clean. I've gotten the rust off the rectangular block on the back that hooks to whatever bracket it attaches to, but it looks like some kind of grime and the wire brushes don't seem to take it off.
Anybody got any suggestions as to a chemical I can spray on this ans clean it?
All is appreciated for any help.
Thanks in advance.
Does NOT play well with others
I might be fat, but your ugly and I can go on a diet
Goldeneagle is offline
post #2 of 32 (permalink) Old 05-01-2012, 04:28 PM
Gasoline
post #3 of 32 (permalink) Old 05-01-2012, 04:46 PM
Easy off oven cleaner? LOL no really gas could work.
post #4 of 32 (permalink) Old 05-01-2012, 04:49 PM
Purple power
post #5 of 32 (permalink) Old 05-01-2012, 04:50 PM
Purple power
careful......it ate some aluminum stuff i was cleaning on a diff case for a yerf dog, go-kart.
post #6 of 32 (permalink) Old 05-01-2012, 04:52 PM
Gear head's Avatar
Try a mild acid like a rim cleaner, or you can try a stronger chemical like air craft paint remover. You can pick it up at your local auto zone or any auto parts store.
Because they said it could not be done.
Gear head is offline
post #7 of 32 (permalink) Old 05-01-2012, 04:55 PM Thread Starter
Well I guess I'll try that, I already used a quart of lacquer thinner and that didn't work,
although it cleaned the inside to an almost new appearance.
Gasoline it is then. I'll let ya know if it worked tomorrow, unless for some reason
it catches on fire, then I'll be really, really mad.
post #8 of 32 (permalink) Old 05-01-2012, 05:06 PM
Makes for lighter parts Mr. Lightweight lol
post #9 of 32 (permalink) Old 05-01-2012, 05:08 PM
I did mine by sand-blasting then powder -coated
post #10 of 32 (permalink) Old 05-01-2012, 07:03 PM
X2!
post #11 of 32 (permalink) Old 05-01-2012, 07:55 PM Thread Starter
When you write power coat it, are you referring to the aluminum part or the whole pumpkin case? If it's the whole case then I'll sand blast the steel part then send it to
http://nitroplate.com/
to get it shinny. I'm just looking for the aluminum cover. Please be specific.
Not being nasty, just want clarification.
Thanks you.
post #12 of 32 (permalink) Old 05-01-2012, 09:25 PM
Just the back cover , the rest cleaned up well so I just put a few coats on the Punkin A friend at Harvick Racing done the back cover not sure if he used sand or soda .
post #13 of 32 (permalink) Old 05-01-2012, 10:15 PM
DLF
DLF's Avatar
Bead blasting...
My Web Site
DLF is offline
post #14 of 32 (permalink) Old 05-01-2012, 11:06 PM Thread Starter
Quite making me jealous darn it.
post #15 of 32 (permalink) Old 05-02-2012, 12:44 AM
....Still just a heavy iron case
Since we got people commenting on weight and diff covers quick question>>> whats heavier the LPW cover or the stock cover with a billetflow or similar custom brace
I also agree bead blasting is the best and if you can do that instead then by all means. But if you want to be cheaper about it then you have to resort to more primitive methods like a scuff wheel meant for body work that you can attach to a drill. And just scuff the crap out of it and it will shine with time. There are many wheels that can do this job Im sure just throwing you an idea.
post #16 of 32 (permalink) Old 05-02-2012, 08:21 PM Thread Starter
Okay, gasoline didn't work. Going to try Easy off oven cleaner. I was told that it would work well, and I am a little on the lazy side of this type of job. I will let ya'll know how that works, after I try it. If that doesn't work, I'm going to use acid. And if that doesn't work, I'm sand blasting the darn thing.
post #17 of 32 (permalink) Old 05-02-2012, 09:56 PM
skinnytick's Avatar
Easy Off worked very well for my truck's engine, it got most of the baked on oil from the leaky push rod cover. However, if you're looking for results like Darren's, you'll probably want to blast it.
On my differential I scrubbed with Simple Green and a small wire brush then hit it with brake cleaner, it left a lot to be desired but it's good enough for now...
skinnytick is online now
post #18 of 32 (permalink) Old 05-04-2012, 01:22 AM
I personally gave up trying to get that "clean look" myself. I dont think it can be done with just cleaning solutions alone. Youll need some physical abrasive.
post #19 of 32 (permalink) Old 05-04-2012, 01:58 PM Thread Starter
Will, it's already got me P-O, so I think I'll stick it back together and leave well enough alone. It's not going into a car that is for show, and the car is slammed what looks like 2" anyway, so who the hill of beans is gonna see it anyway?
Thanks for all the input and help people.
post #20 of 32 (permalink) Old 05-04-2012, 02:14 PM
I thought a little cleaning would help it too but it didnt all I did was clean off excess grease and dirt. Its better than nothing but the best I got was a dull silver look.
post #21 of 32 (permalink) Old 05-04-2012, 02:24 PM
I'd rather do it right the first time and sand blast. Every time I hear about you guys using purple power or simple green, make sure you're in a well-ventilated area.
I'm not sure about most areas, but there is a place near me that is called "U-Spray". You basically take your part or parts to a place where you sand blast your own parts for a dollar a minute. They use 36 grit Aluminum Oxide (Like sand) or plastic media. Do a Google search in your area for a DIY sand blasting shop.
post #22 of 32 (permalink) Old 05-04-2012, 02:56 PM Thread Starter
If I'm going to go through the time to pull the guts out and sand blast, then I'd send it to this place and have them cover it.
post #23 of 32 (permalink) Old 05-14-2012, 12:27 PM
Just had the diff sand blasted today at a DIY place I was talking about. Only took 6 minutes at $1.75 a minute. $11 something plus tax. Whatever the price, a lot less hassle then doing it with chemicals and wire brush.
Before and After...
post #24 of 32 (permalink) Old 05-14-2012, 12:32 PM
Sweet ! its nice to have a place like that around
post #25 of 32 (permalink) Old 05-14-2012, 02:59 PM
Dude that is fantastic results for that money and not having the mess at home is a plus. Makes me wonder what I would blast??? I dont have any iron to clean and the luminum I run looks 4 years old aka clean.
post #26 of 32 (permalink) Old 05-15-2012, 11:23 AM
Powder coated in less than 24 hours and $40 at a place not too far from me.
post #27 of 32 (permalink) Old 05-15-2012, 12:37 PM
97Tturd's Avatar
very nice!
97Tturd is offline
post #28 of 32 (permalink) Old 05-15-2012, 03:19 PM
Looking good Josh, now it's time to do the cover!
post #29 of 32 (permalink) Old 05-15-2012, 03:24 PM
Get the cover done in your alpine green would look cool
post #30 of 32 (permalink) Old 05-15-2012, 04:24 PM
Originally Posted by 97Tturd View Post
very nice!
Thanks guys! I love it, they did a great job.
I was thinking a silver or chrome if it's not going to cost that much.
