any truth to rear end swap - TCCoA Forums
post #1 of 26 (permalink) Old 08-04-2012, 12:17 AM Thread Starter
is there any truth to this that you can swap a ford mustang rear end to a thunderbird as easy as just bolt in
HYDETHERAT is offline
post #2 of 26 (permalink) Old 08-04-2012, 12:24 AM
unless it's a 99 cobra, No.
post #3 of 26 (permalink) Old 08-04-2012, 12:42 AM Thread Starter
ok thanks
post #4 of 26 (permalink) Old 08-04-2012, 12:50 AM
search IRS side gear notching.
post #5 of 26 (permalink) Old 08-04-2012, 02:36 AM
Only the Cobra IRS, for certain values of "just bolt in".
And why? On a 5.0HO, until you're pushing power levels that'll split blocks routinely, the 28 spline should be quite adequate. About all the Cobra gets you is 31 spline. Which changing the spline count would also call for new half shafts ...
RalphP is online now
post #6 of 26 (permalink) Old 08-04-2012, 02:38 AM
And even then the outer splines are still 28
post #7 of 26 (permalink) Old 08-04-2012, 10:20 AM
97Tturd's Avatar
I've also wondered if I would be able to swap the solid axle from my mustang into my tbird but I've been told the axle tubes aren't long enough and mounting the rear end is different?
1997 Thunderbird LX
2003 Mach 1
2002 Escape
97Tturd is offline
post #8 of 26 (permalink) Old 08-04-2012, 10:41 AM
Just a bit, 97Tturd.
I have a really silly question.
If what you want is a Mustang, why not buy a Mustang?
post #9 of 26 (permalink) Old 08-04-2012, 02:22 PM
97Tturd's Avatar
Are you asking me about buying a mustang?
I have a 03 Mach 1 MUSTANG as well as the 97 thunderbird...
I was just thinking one day if it would be possible to swap rear ends on the cars lol
1997 Thunderbird LX
2003 Mach 1
2002 Escape
97Tturd is offline
post #10 of 26 (permalink) Old 08-04-2012, 02:31 PM
Have a look under the two of them and report back
post #11 of 26 (permalink) Old 08-04-2012, 02:41 PM
97Tturd's Avatar
Probably be a waste of time.
1997 Thunderbird LX
2003 Mach 1
2002 Escape
97Tturd is offline
post #12 of 26 (permalink) Old 08-04-2012, 03:41 PM
*images elided*
Swap?
Why?
As was suggested, best thing to do is to crawl under there and look.
I mean, you have both - why not just look?
Originally Posted by "Time For The Stars" by Robert A. Heinlein
"How can you tell how many robin eggs are in a nest? Oh, we can do statistical analysis and probability studies, but sometimes the best way to tell is to climb the tree and look."
post #13 of 26 (permalink) Old 08-04-2012, 06:00 PM
Mustang rear end swap? Probably work as good as a Lincoln Mark VIII rear end swap into a TBird!
~Rick
TCCoA Sig
post #14 of 26 (permalink) Old 08-04-2012, 07:12 PM
You ARE aware that they're not plug and play (Mustang to MN12/FN10) like the MN12 and FN10 are, right?
post #15 of 26 (permalink) Old 08-04-2012, 08:50 PM
97Tturd's Avatar
I knew that it isn't possible to do EASILY w/o a lot of time, $, and fabrication... I was just saying i've thought about it a few times...
1997 Thunderbird LX
2003 Mach 1
2002 Escape
97Tturd is offline
post #16 of 26 (permalink) Old 08-04-2012, 09:57 PM
Why? to make a heavy car that handles/rides like crap?
post #17 of 26 (permalink) Old 08-05-2012, 09:10 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
Well, with a cobra subframe swap, you can get IRS on the Mach 1 without worrying about making brackets. Do like I did and sell the New Edge, keep IRS in the bird and never look back. That GT I had was clean but it sucked. I did get beat by it on my bday though. It ran a best of 14.9 and I ran a 15.3 even though I beat it to the end. I was getting hella wheel spin. I cant wait to destroy this thing later with gears. Beating new edge stangs used to make me feel so good
-Rob
Rob is offline
post #18 of 26 (permalink) Old 08-05-2012, 12:54 PM
97Tturd's Avatar
2v mustangs are junk
1997 Thunderbird LX
2003 Mach 1
2002 Escape
97Tturd is offline
post #19 of 26 (permalink) Old 08-05-2012, 12:58 PM
97Tturd's Avatar
I think we answered this guy's question a while ago soooo lock it up!
1997 Thunderbird LX
2003 Mach 1
2002 Escape
97Tturd is offline
post #20 of 26 (permalink) Old 08-05-2012, 01:16 PM
We don't need to tell the moderators what they should be doing.
post #21 of 26 (permalink) Old 08-05-2012, 04:00 PM
Tbird1997's Avatar
There was a guy here in TN tht did a solid axle swap on a tbird. Never actually met the guy but he's on the tn mustang forums. Supposedly did it to loose some weight, I don't think he was happy with it tho. Sold it a while back IIRC
Why? I like them. Not as much the 99-04 but I like the 97 and 98. And they weigh nothing compared to our beasts.
-Patrick
Tbird1997 is offline
post #22 of 26 (permalink) Old 08-05-2012, 09:18 PM
It's not a for sale thread and all discussion has been basically on topic soooo why should we lock it?
post #23 of 26 (permalink) Old 08-05-2012, 11:58 PM
97Tturd's Avatar
Woah!
sometimes I forget all forums are different
1997 Thunderbird LX
2003 Mach 1
2002 Escape
97Tturd is offline
post #24 of 26 (permalink) Old 08-06-2012, 09:52 AM
I can't wait to get rid of this POS IRS, and get a solid axle under mine!!!
post #25 of 26 (permalink) Old 08-06-2012, 10:12 AM
In what way is it a POS? In your application, that is?
post #26 of 26 (permalink) Old 08-06-2012, 10:18 AM
Its old, outdated, and for me, a straight axle would be better suited.
