irs suspension question. - TCCoA Forums
post #1 of 5 (permalink) Old 03-24-2013, 01:19 PM Thread Starter
what would it take to get a 96/7 Tbird irs to handle 550-600rwhp?
poly bushings, HD 8.8 cover, what else?
mrt2you is offline
post #2 of 5 (permalink) Old 03-24-2013, 01:37 PM
Delrin bushings, rear girdle.
Standard or auto? I ask because traditionally the auto application can take more due to the shock absorption of the torque converter, whereas you can spit half shafts at a lower HP due to the sudden shock.
OH! Don't forget to use non-greasable U-joints! And the GOOD ones, not the $1.298 cheapies at Honest Charlie's Dry Cleaner and Auto Parts Ebay store!
RalphP is offline
post #3 of 5 (permalink) Old 03-24-2013, 01:38 PM
Do a search on RobertP's monster , His IRS handles things nicely , Just weak half-shafts at times (maybe a thing of the past in time )
post #4 of 5 (permalink) Old 03-24-2013, 03:43 PM Thread Starter
it will be a auto
mrt2you is offline
post #5 of 5 (permalink) Old 03-24-2013, 10:04 PM
Moderator & Teksid Whore
guitar maestro's Avatar
if anything, the half-shafts are the weakest links due to the CV joints that can pop on ya on a good launch. Obviously what you mentioned will help, but unless you're going to to massive fabrication, there's nothing that will make it "match" a solid axle. That mentioned, the IRS will handle your anticipated power level just fine.
guitar maestro is offline
