Mark 8 years ? - TCCoA Forums
post #1 of 4 (permalink) Old 07-20-2013, 03:26 AM Thread Starter
Mark 8 years ?
What year models will work for our complete rear end swaps ?
Are there any certain model years that are better than others ?
Other than all the normal rear end stuff , plus the upper & lower arms is there anything else I would need off a M8 to complete a swap ?
THill is offline
post #2 of 4 (permalink) Old 07-20-2013, 06:34 AM
Define "complete rear end". Because, a complete rear end should be subframe and all - and if so, you wouldn't be asking about "plus the upper and lower arms".
HOWEVER ...
The diff swaps right across, but do match the VSS gear (BIG hint: If you're getting out of a yard, and the tranny is still in the car, grab the VSS out of the tranny also. That way you have the right gear to hand).
The LSCs have a 3.27 gear, the non-LSCs a 3.08.
NO Mark VIII has a tracloc from the factory.
The upper arms are identical, no need to grab them unless you just want to. Not a bad idea, you can swap the inner bushing while still driving the TBird, and that includes pressing the old one out, getting the arms powder coated or painted, and then pressing a new one in!
While swapping, go ahead and replace the spindle bearings.
Also, all bushings that you can get. Due to availability, that pretty much means Energy Suspension poly bushings for the spindle and LCA, factory style UCA/frame bushing.
Also grab new diff/chassis bushings - again, Energy Suspension has those.
Keep the parking brake cables, unless you're already disc in the back.
RalphP is offline
post #3 of 4 (permalink) Old 07-20-2013, 01:55 PM
Upper arms are not identical. Same basic design but they have holes stamped into them to reduce weight
post #4 of 4 (permalink) Old 08-15-2013, 10:58 AM
If changing out the entire subframe you should put in you bushings that isolate the subframe to the body of the car. Factory ones are no longer available but SCP has those available in 6061 T6 aluminum.
They offer every single bushing and control arm on the entire car, with many in upgraded material.
Super Bill is offline
