Axle/Gear question - TCCoA Forums
post #1 of 12 (permalink) Old 11-29-2013, 09:57 PM Thread Starter
Tweety Bird's Avatar
Axle/Gear question
First of all, keep in mind, that I AM NOT A MECHANIC of any kind.
I was reading, (trying to understand), under an asle/gear post, about what rear end/gears my car has.
It said that under the AX part of the door post label it would say........ and it gave a list of letters/ratios.
My car under the AX =Y
Under lock = Z
Under ratio+ 3:08
The 3:08 I basically understand.
What does the "Z" represent? i am confused here.
Thanx, for any explanation.
Tweety Bird
Tweety Bird is offline
post #2 of 12 (permalink) Old 11-29-2013, 10:28 PM
rushtonracing's Avatar
"Y" is a 3.08:1 conventional open differential. Non-locking.
If the sticker has the letter "Z" then it's a 3.08:1 Trac-Lok.
Here is a link to the TCCoA Articles under the heading "Gears" that has a chart, and useful info'.
http://www.tccoa.com/articles/gears/gears.html
1995 Thunderbird LX 4.6l 97 Headlamps/Hood All Red Tails Muffler/Resonator Delete
2004 Tahoe 5.3 4x4
2008 Acadia Limited AWD
...still looking for a clean, low mileage, rust free 96/97 Thunderbird 4.6
rushtonracing is offline
post #3 of 12 (permalink) Old 11-29-2013, 11:18 PM
S4gunn's Avatar
Open Differential?
I prefer the term Unlimited Slip Differential.
-g
http://goo.gl/csaet4
S4gunn is offline
post #4 of 12 (permalink) Old 11-29-2013, 11:54 PM
Open Differential?
-g
That's funny.
The slip is...unlimited.
Actually I prefer the term: Detroit Locker!
The other day I said to the janitor at work, "Do you have a sanitary waste receptacle lining?"
He said, "Huh?"
I said, "Y'know. A trash bag."
2004 Tahoe 5.3 4x4
post #5 of 12 (permalink) Old 11-30-2013, 12:06 AM
Detroit Locker isn't another name for limited slip though, it's either open or it's totally locked.
post #6 of 12 (permalink) Old 11-30-2013, 01:05 AM
Rayo's Avatar
Differential Terminology
Ford refers to it's "Open Differential" in a few different terms..
Such as: "Non-Limited Slip".."Non-Locking".."Conventional"
Ford refers to its "Locking Differential" in a few different terms as well..
Such as: "Limited Slip".."Locker".."Trac-Lok"
These are terms relevant to the MN12 & FN10 platforms..
Ford has used many Differential styles throughout the years..Some of those are listed here: -->>DIFFERENTIALS
I remember having this conversation before..
1991 Ford Thunderbird Sport
Rayo is offline
post #7 of 12 (permalink) Old 11-30-2013, 02:53 AM
Muscle cars I've owned in the past with a Detroit Locker scud the rear tires when accelerating hard from a dead stop, and making a sharp turn. Like pulling out from/into an intersection when committed. Combined with over steer the car can get away from you pretty fast. Let alone on a wet or icy surface.
Those who have ever driven vehicles with their spider gears welded know what I mean.
Since a limited-slip uses a clutch pack that allows some slippage this tendency to scud the rear tires is diminished. Hence the name, "limited...slip". The slip is only limited. It does slip some. Which in turn makes the car easier to handle. The D.L. on the other hand...once locked, the rear carrier turns as a complete unit no matter how sharp you turn.
(I always liked the name Sure-Grip. Like it should be in a line of RATM, Bulls on Parade or something...)
Here's some ol' skool, but true, and easy to understand video of how a differential works. If one can get past the fact that it was made before flowering plants, it does a fairly good job of explaining how the primary, and secondary pinions work.
2004 Tahoe 5.3 4x4
post #8 of 12 (permalink) Old 11-30-2013, 09:38 AM Thread Starter
Arrow
Thanx for the replies. I understand a little better now.
post #9 of 12 (permalink) Old 11-30-2013, 04:05 PM
96PRLBRD's Avatar
That video surprisingly does a good job at explaining the basics of how a differential works.
--> My most recent pics <--
96PRLBRD is offline
post #10 of 12 (permalink) Old 11-30-2013, 05:54 PM
S4gunn's Avatar
I thought Detroit Locker was a specific brand of LSD -- like Qualfe or Torsen (or Kleenex for tissue paper).
This should work in a tbirds 8.8 rear diff, right?
-g
http://www.4wheelparts.com/Drivetrai...FYqFfgodE3UA8g
S4gunn is offline
post #11 of 12 (permalink) Old 11-30-2013, 11:12 PM
Nonsense.
2004 Tahoe 5.3 4x4
post #12 of 12 (permalink) Old 11-30-2013, 11:23 PM
Originally Posted by rushtonracing View Post
Nonsense.
Nice edit
