Check your rear end mount - TCCoA Forums
post #1 of 37 (permalink) Old 12-20-2013, 12:08 PM Thread Starter
Overkill Fetish Freak
Wow, caught this just in time!
Going with the LPW cover and the SCP Beefy mount.
-Scott
Dr. FrankenCougie is offline
post #2 of 37 (permalink) Old 12-20-2013, 01:26 PM
Nice I used the older mount as they are thicker, and removed all the rubber and put solid metal in mine lol
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #3 of 37 (permalink) Old 12-20-2013, 01:50 PM
miller1995's Avatar
Looka like a little JB weld would fix that right up.
-Bryan
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #4 of 37 (permalink) Old 12-20-2013, 01:51 PM
This also happens when you jack the rear end from this mount.
post #5 of 37 (permalink) Old 12-20-2013, 04:26 PM
r429460's Avatar
Hmmm.
All I break are the outer axle stubs.
I wonder why ,how that happened.
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #6 of 37 (permalink) Old 12-20-2013, 04:40 PM
If you use the jack on the diff, yeah. Placing the jack on the mount is just fine though, done it that way for years.
post #7 of 37 (permalink) Old 12-20-2013, 05:41 PM
guess I am putting my car on the lift tomorrow
transtech520 is offline
post #8 of 37 (permalink) Old 12-20-2013, 06:32 PM
Really? I did that with my 95 v6 many moons ago and cracked it slightly in the same spot. I'm sure that not a safe way to jack the rear anyways.
post #9 of 37 (permalink) Old 12-20-2013, 07:25 PM
There's no way it can crack the diff side of the mount like that unless you put the jack under the pumpkin. All the cars weight ends up at the front diff ears/bushings and the rear mount and the rubber. If you place the jack under the rearmost part of the mount itself though, you're lifting directly on the IRS subframe with zero weight on the diff side of the mount.
It's plenty safe to do it that way, hence why I do it. I always lift from the centers, front/rear and I don't go under myself until I place the stands under first. Never been a fan of jacking the corners, way too tedious.
post #10 of 37 (permalink) Old 12-20-2013, 08:16 PM
VicRattlehead's Avatar
I did that many moons ago
CMP Drag Racing
VicRattlehead is offline
post #11 of 37 (permalink) Old 12-20-2013, 10:41 PM
It's going to be a balancing act every time you left from that mount. You can have the rear left or right tire drop either way while you're jacking the rear upwards. All depends on the weight distribution in the trunk and if your garage floor is level. Also if you have a full tank of gas as well. I wouldn't take the chance, but everyone will do their own thing.
post #12 of 37 (permalink) Old 12-20-2013, 11:18 PM
I'm not lifting all four wheels off of the ground and balancing the car on a central axis, I'm placing a jack under a central member on one end of the car while two wheels are still firmly planted on the other end. It doesn't teeter like that, otherwise tricycles would tip over at rest. Hell one time helped my friend turn his 64 Galaxie a full 180* around in his cracked and rutted driveway whilst pushing the quarters with with jack under the 9". That's admittedly a nerve wracking procedure I wouldn't recommend but damned if it didn't work without any drama.
post #13 of 37 (permalink) Old 12-20-2013, 11:20 PM
I've lifted every MN12 I've worked on since '99 in the same manner as described by Matt above without a single issue. I do work on a level surface, and I don't go under the car until I've placed the jackstands, but I've never had one even hint at leaning when lifting from the center of the front or rear. Placing the jack pad under the rear diff mount can't physically cause the damage seen above.
Scott, plan on sanding the powdercoat on the inside of one half of the diff mount (where the poly bushing slides in). It's a nice mount, but powdercoat thickness wasn't accounted for in the design. It's a bear to assemble the two halves otherwise. The LPW cover is a very very nice piece. Just put a little RTV on the threads of the bearing cap screws before threading them up against the caps to prevent any seepage.
post #14 of 37 (permalink) Old 12-20-2013, 11:31 PM
You guys are all jacked up!
I don't know, I would feel uneasy about it. It's everyone's personal preference I guess. Thanks, Josh
post #15 of 37 (permalink) Old 12-21-2013, 12:45 AM
rushtonracing's Avatar
Now that's a crack! Don't need x-ray vision to see that one. Dang.
The original owner's manual of my 'bird states never lift the rear of the car by placing a jack under the pumpkin.
The rear bracket is a safe, non-damaging, logical choice to lift the whole rear at once. But, I've got it easy. The car has a receiver. I do choose to place a small piece of 2x4 between the jack pedestal, and the metal of the car so that it combats scratches which would promote rust.
Upon making a decision to purchase a floor jack I made sure it was one with a good large pedestal (some are too small) that has a provision to allow the pedestal to turn 360*. And, I decided on a 3 ton.
I've never had a car even hint at tipping to one side, even making maneuvers similar to what Matt has described. The only time I've really sweat that concern is during a four wheeling recovery dilemma. Even then it never happened.
And ah...no, I wasn't four wheeling in the Thunderbird, lol.
Donuts in dirt maybe...
1995 Thunderbird LX 4.6l 97 Headlamps/Hood All Red Tails Muffler/Resonator Delete
2004 Tahoe 5.3 4x4
2008 Acadia Limited AWD
...still looking for a clean, low mileage, rust free 96/97 Thunderbird 4.6
rushtonracing is offline
post #16 of 37 (permalink) Old 12-21-2013, 02:07 AM Thread Starter
Can't say that I've ever lifted from the pumpkin since I know better but I don't have a problem lifting from the rear mount on a "normal" MN12. Cougies 4 inches of exhaust makes it hard to get a bite on the sweet spot of the mount so I choose the sides or a corner area of the IRS near the center works well too. The car goes up flat not matter what side you lift from due to the rear cage and bar that runs betwix the shocks. The previous front mount bushing failure (as in totally gone)I had that made the pinion seal walk in the carrier housing may have helped take the mount out along with the many hard 1-2 shifts I love so much. The JB weld "keep the seal put" mod has held on strong for at least two years now. The mounts I've replaced in the past failed due to the rubber separating but they were easy to get back then and I'm not shy of the bolt mod...
-Scott
post #17 of 37 (permalink) Old 12-21-2013, 11:57 AM
I find it easier to jack from the transmission mount crossmember bolt locations; it lifts both wheels at the same time on each side.
It's also the thickest piece of metal down there, lol.
Grog6 is online now
post #18 of 37 (permalink) Old 12-21-2013, 08:12 PM
I've never not lifted by the mount. It's virtually impossible for it to tip
CMP Drag Racing
post #19 of 37 (permalink) Old 12-21-2013, 09:11 PM
ricklovin93's Avatar
was there any signs it was cracked? Or did you just happened to look at it and saw it was cracked?
"A well regulated militia, being necessary to the security of a free state, the right of the people to keep and bear arms, shall not be infringed"
ricklovin93 is offline
post #20 of 37 (permalink) Old 12-21-2013, 09:31 PM
Really? Great story, tell me more.
post #21 of 37 (permalink) Old 12-21-2013, 11:48 PM
Moderator & Teksid Whore
guitar maestro's Avatar
He's right, you're delusional
-Scott
I just got my LPW cover from Alan. It's a nice piece.
guitar maestro is offline
post #22 of 37 (permalink) Old 06-08-2014, 02:02 PM
I broke/cracked mine on both ears inside where they fasten down. The symptoms were deep thud at 70-75 if I turned the OD button off or sometimes on downshifts, sounded like something in the trunk hitting. A friend of mine welded them back up and placed some more rubber padding in there. Recently when it was on a lift we saw some damage to the MMC driveshaft as a result, i.e a small groove was cut all around.
I come from a dusty place.
4point6r0x0rz is offline
post #23 of 37 (permalink) Old 01-04-2015, 06:50 PM
CougarXR/7's Avatar
Send a message via Yahoo to CougarXR/7
Mount
I weld a 1/4" steel plate across the back to prevent it slipping out and a small plate on each side to add some strength...........I Road Course........I don't need any surprises.
To ALL my fellow Veterans......................Thanks!
U. S. Army 1971 - 1974
1980 Thunderbird - R.I.P.
1992 Super Coupe five speed
1990 35Th "Anni" Super Coupe automatic - R.I.P.
1994 Super Coupe five speed
1994 4.6 LX Thunderbird automatic - R.I.P.
1995 4.6 LX Thunderbird automatic - R.I.P.
CougarXR/7 is offline
post #24 of 37 (permalink) Old 01-04-2015, 07:29 PM
Deep thud? Ouch, you got me wanting to look at mine first thing in the morning..
I get a deep thud at 15 or so mph downshifting to first. Also when od is on and i pat the gas.
94thunderbird46 is offline
post #25 of 37 (permalink) Old 01-04-2015, 08:28 PM
gordonm1's Avatar
Those cracks will buff out.
Where can you lift the front from a centered point? My doors are complaining about my lifting from the sides.
Gordonm1
gordonm1 is offline
post #26 of 37 (permalink) Old 01-10-2015, 07:10 PM
Jacking points circled in red, jackstand points in yellow.
post #27 of 37 (permalink) Old 05-09-2015, 04:25 PM
TwoHaggard's Avatar
robertp do u have any pictures or can explain how you made your solid?
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #28 of 37 (permalink) Old 05-09-2015, 05:23 PM
Tweety Bird's Avatar
Thumbs up
It may take a while, BUT, I really do believe that will buff right out !!!
NOBODY ever tells a story where they look bad !!!
Tweety Bird is offline
post #29 of 37 (permalink) Old 05-10-2015, 01:04 AM
God, you guys get all worked up over the littlest things - that's nothing a little duct tape wouldn't fix, LOL!
post #30 of 37 (permalink) Old 05-10-2015, 09:30 PM
TwoHaggard's Avatar
Anyone have pics of modifying there stock one? I'm thinking about welding it solid and melting the rubber out...
