Differential ID - TCCoA Forums
post #1 of 4 (permalink) Old 01-21-2014, 04:35 PM Thread Starter
1996Project-bird's Avatar
Differential ID
No, I'm not asking if i have a trac-lok. I'm going to be checking out a diff for sale near me. The guy says it has a torsen diff and 3.55's in it. How can I verify this without obviously tearing the whole diff apart? What are signs of wear and tear, or common red flags? Thanks!
1996Project-bird is offline
post #2 of 4 (permalink) Old 01-21-2014, 04:56 PM
Rayo's Avatar
Originally Posted by 1996Project-bird
I'm going to be checking out a diff for sale near me.The guy says it has a torsen diff and 3.55's in it. How can I verify this without tearing the whole diff apart?
If you're just talking about about the pumpkin itself..
I don't think there is a way to verify what's inside of it without at least popping off the cover, and counting the teeth of the gears..
There should be 11 pinion gear teeth..Then 39 teeth on the ring gear (the larger one)..
The Torsen Differential uses helical cut gears rather than clutch plates, and spider gears..That's your first clue it's a Torsen vs a Trac-Lok..
Torsen
Trac-Lok
IMO..Unless you're just going to use the diff for the drag-strip..I wouldn't chance buying a used diff to put in your DD unless you know the history of it..
Looks can be deceiving..
1991 Ford Thunderbird Sport
Rayo is offline
post #3 of 4 (permalink) Old 01-21-2014, 04:59 PM Thread Starter
I plan to pop the cover. Thanks for the info!
post #4 of 4 (permalink) Old 01-21-2014, 05:21 PM
Most gearsets will have the ratio stamped right into the edge of the ring gear, too.
Delete my account.
94 Thunderbird XX is offline
