Can I make my open diff into a TL? - TCCoA Forums
post #1 of 10 (permalink) Old 04-14-2014, 06:22 PM Thread Starter
NO.
Not gonna happen. (I can't believe I was asked about this yet again.....mods: Sticky or Tech Section please?)
You cannot just add the TL clutches and steels to an open carrier. The carrier is not machined for that, and the side gears are unique to a TL as they have teeth to engage the clutch steels.
[/URL]
You will have to either score one from a yard, buy one from a private Seller, or order up a brand-new unit from Summit, Jegs, or other Vendor and then install it.
Delete my account.
94 Thunderbird XX is offline
post #2 of 10 (permalink) Old 09-02-2014, 09:51 AM
conquistador's Avatar
Thanks for posting this and making this clear. There were a couple threads that suggested the idea that you could. It seams that swapping the entire carrier may be easier anyway!
conquistador is offline
post #3 of 10 (permalink) Old 09-09-2014, 10:33 PM
lol...that's a clear answer!
You can convert the diff to trac lok...just takes a wee bit more than the clutches.
DrFishbone is offline
post #4 of 10 (permalink) Old 09-09-2014, 10:36 PM
If I understand correctly, you can use a non-irs 8.8 trac lok unit in an IRS rear end, but there won't be provisions for the axle circlips...right?
post #5 of 10 (permalink) Old 09-10-2014, 03:46 PM Thread Starter
Yes. As long as it's a 28 spline unit, the stock Tbird/Cougie halfshafts will fit. As far as the circlips go here's two options (if it's not an IRS unit) - either remove the circlips from your shafts altogether or get a taper machined or dremel-ed in the side gears.
  • Couldn't-be-Easier: circlips delete.
  • Stickler-for-Correctness: taper the side gears.
Either choice works fine, but if you just slam the shafts home with the circlips into a non-IRS unit, it will be very very difficult to remove them again after that.
Delete my account.
post #6 of 10 (permalink) Old 09-10-2014, 04:36 PM
bowez's Avatar
Any measurements on the taper needed or pics?
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #7 of 10 (permalink) Old 09-10-2014, 05:11 PM
It will drop right in, and the axles fit perfectly.
It is Almost Impossible to disassemble.
The circlips are just metal circular pop-in pop-out clips; normally, I pop them loose with a large screwdriver against the cv point.
Without a bevel, 45° should be fine, you cannot get them to compress from the outside, and from the inside is a nightmare.
I remember this thread has pix, bowez: (Thanks ClintD!)
http://forums.tccoa.com/showthread.php?t=108693
Hopefully, no one here has done this.
post #8 of 10 (permalink) Old 09-11-2014, 07:22 AM
r429460's Avatar
What do those clips even do.
The axles just pull out with no effort.
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #9 of 10 (permalink) Old 09-11-2014, 09:12 AM
S4gunn's Avatar
Perhaps you should make this post a little more clear and upbeat:
* While you cannot modify a open diff carrier to use TL clutches NOR should you use a TL carrier from a non-IRS car without dealing with the c-clips, you CAN just swap in an IRS TL carrier/unit from another tbird/SC without any fuss.
-g
http://goo.gl/csaet4
S4gunn is offline
post #10 of 10 (permalink) Old 09-30-2014, 12:53 PM
TonyBrooklyn's Avatar
-g
You can also use a Power Trax i have one works great.
And it only comes on when you need it.
TonyBrooklyn is offline
