03-04 Mustang Cobra Half Shafts - TCCoA Forums
post #1 of 14 (permalink) Old 01-29-2015, 04:23 PM Thread Starter
Will 03-04 Mustang Cobra Half Shafts fit 97 cougar 4.6?
Turbox is offline
post #2 of 14 (permalink) Old 01-29-2015, 04:38 PM
Nope. They are 31 spline, MN-FN are 28. If you're looking for replacements check rock auto or your nearest autoparts store.
post #3 of 14 (permalink) Old 01-29-2015, 05:35 PM
Also the cobra axles are about 1" shorter than the MN12 ones.
post #4 of 14 (permalink) Old 01-29-2015, 05:39 PM
They will fit with a 31 spline diff however
post #5 of 14 (permalink) Old 01-29-2015, 07:01 PM
Maic's Avatar
You could option for MK8 shafts.
Maic.
Maic is offline
post #6 of 14 (permalink) Old 01-29-2015, 11:26 PM
S4gunn's Avatar
if you are just looking for something cheap, I have a pair of halfshafts from a 93 V8 (5.0) car I'm happy to sell off.
The only catch is that they are for a car w/o ABS as there is no ABS ring on the inner end of the shafts.
PM me if interested.
-g
http://goo.gl/csaet4
S4gunn is offline
post #7 of 14 (permalink) Old 01-30-2015, 07:29 AM
FYI, those can be pulled from another pair of halfshafts and installed if necessary. I've pulled them from stock halfshafts and installed them on DSS Level 2's in the past.
post #8 of 14 (permalink) Old 01-30-2015, 01:24 PM
r429460's Avatar
Want the strongest halfers, get The Driveshaft Shop Axles.
Otherwise stick with stock.
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #9 of 14 (permalink) Old 02-02-2015, 08:08 AM Thread Starter
Thanks everyone!! I have a buddy that converted his 03 a long time ago and those were sitting in his garage and said I could have them and they only had 10k miles so thought I would ask. I dont need them but have been talking about ripping all the stuff off my cobra and making the cougar a sleeper. I bought it to drive my kid to school and got a smoking deal on it because an old couple was moving to Florida but now I see the potential of this car and would love to see it at 500hp..
Turbox is offline
post #10 of 14 (permalink) Old 06-15-2015, 01:32 PM
Yikes those shafts are 1600 bucks! http://www.driveshaftshop.com/domest...rd/thunderbird
Is there anything that splits the difference between $1600 and Cardone?
Jim Stainer
charchri4 is offline
post #11 of 14 (permalink) Old 06-15-2015, 03:15 PM
Moderator & Teksid Whore
guitar maestro's Avatar
...and those are the cheap ones. The better ones are high-alloy 300M steel.
guitar maestro is offline
post #12 of 14 (permalink) Old 06-15-2015, 03:22 PM
r429460's Avatar
There's nothing in between that I know of.
I've broke four half shafts, on launch on a sticky track.
Foot braking.
The stockers break at the end of the splines on the outer stub.
4000 stall, 324hp and torque, 3:73 gears.
All on the right side.
Two were with Traction Locks and two were with a mini spool.
31 splines are not necessary, larger axle shafts are not necessary,
Larger axle joints are not necessary.
Larger outer axle stub is all the DSS axles provide.
They are worth it, for my application.
Now its a 4500 stall and 4:56 gears.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #13 of 14 (permalink) Old 06-15-2015, 04:26 PM
I think what I did was self inflicted. When I rebuilt the diff I swapped out one of the steels for one of the old fibers which made a nice tight locker for the last 15,000 street miles. Over the weekend I took it to a road course and I think what happened is it got hot enough that those clutch packs basically seized up and wouldn't let the outside wheel turn faster on the corners. I broke the inside drivers side CV joint.
So now I'm not sure what to do to fix it. I'm thinking the cardone shaft was fine and I just need to put the clutch packs back to the way Ford had them. I thought about putting a truetrac torsen in it but not sure it's really needed.
Thoughts?
Jim Stainer
post #14 of 14 (permalink) Old 06-15-2015, 08:45 PM
If you're doing road courses, I'd go with a geared instead of clutch-based diff.
Grog6 is online now
