Mark 8 Driveshaft - TCCoA Forums
post #1 of 5 (permalink) Old 08-08-2002, 02:54 PM Thread Starter
Mark 8 Driveshaft
Someone is the classifieds is selling a Mark 8 one piece Driveshaft for 150 bux, plus shipping. Its balanced and has the Tbird yokes on it. Is this a good price?
DGERMANN is offline
post #2 of 5 (permalink) Old 08-08-2002, 08:54 PM
BR1
i paid $75 for mine, $20 to get it balanced, $24 for new joints. and..i believe they come with the correct yokes as they are, if not, then i must have put mine on wrong because i didn't change anything. i'd try to find one in a local yard first. they are long, expensive to ship probably.
BR1 is offline
post #3 of 5 (permalink) Old 08-09-2002, 04:49 PM Thread Starter
thanks
Thanks I will see if I can talk him down, if I can't I will look elsewhere thought that was alot but wasn't sure.
DGERMANN is offline
post #4 of 5 (permalink) Old 08-09-2002, 05:02 PM
5w30 Guzzler
chilipepprflea's Avatar
Send a message via AIM to chilipepprflea
hey BR1
how much did it cost to have it swapped in? or did you do it yourself?
chilipepprflea is offline
post #5 of 5 (permalink) Old 08-09-2002, 07:49 PM
BR1
did it myself. PITA. someone else on here had it done at a shop and they took out the pumpkin, labor was not bad from what i recall. i dropped the gas tank and a couple driveshaft loops. if you have a lift...its easy, jackstands 12" off the ground, not too fun. its not really that bad i guess even on jackstands, i had a cold concrete floor to lay on in the winter and a snap on scissor lift under my car that doesn't work, so that took away like another 5" of working space.
BR1 is offline
