What should be replaced when swapping diff - TCCoA Forums
post #1 of 9 (permalink) Old 06-22-2015, 11:26 PM Thread Starter
Later this week I am having used diff with 3.73 gears installed. I purchased diff mounts from SCP so that's getting done. Anything else besides new fluid? Somebody mentioned the speedo being off when upgrading from stock 3.08 to 3.73....what do I need to replace to fix that (link to the part would be awesome!!!)
Thanks!!!
lurch is offline
post #2 of 9 (permalink) Old 06-23-2015, 07:08 AM
For the speedo, you will need a different speedo gear, either a black 23 tooth gear if you have an 8-tooth drive gear, or an orange 20 tooth gear if you have a 7-tooth drive gear. Since the diff is used, I would suggest replacing the axle seals as well while you have it out.
MadMikeyL is online now
post #3 of 9 (permalink) Old 06-24-2015, 05:41 AM
miller1995's Avatar
You are using the Trans you got from me right? It is from a 2000 mustang so you need a speedcal to go to 3.73s.
-Bryan
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #4 of 9 (permalink) Old 06-24-2015, 09:24 AM Thread Starter
That's a bummer. I thought I'd only need to change the speedo gear (which appears easy compared to speedcal install).
Where can I pick up a speedcal and are there instructions for installing on our cars. All I've found are instructions for Mustangs.
Ya, I am installing the 2000 Mustang transmission and the 3.73s I picked up from you. I don't need a tune on top of the speedcal for the transmission to shift correctly do I?
lurch is offline
post #5 of 9 (permalink) Old 06-24-2015, 03:38 PM
Without a tune or a j-mod, you may hit the rev limiter before the trans has a chance to shift at WOT. Basically the computer knows how long it takes to complete the shift, and how fast the car accelerates, so it will command the shift at say 5500rpm to have it actually shift at 6000rpm. If you put steeper gears, it takes less time to accelerate that additional 500rpm, so now your shift that was commanded at 5500 will not happen till maybe 6200rpm. To fix this requires either commanding the shift earlier (tune) or making the shift happen faster (J-mod). As for the speedcal, the Mustang settings should work since our cars work on the same type of signals for the speedo. My only experience with a speedcal was when I put a TR3650 in my MarkVIII. In that case, the 97/98 MarkVIII speedometer reads off the wheel speed sensor, so the speedo was fine, but my speed sensitive steering was going nuts because the VSS signal was reading like 3 times as fast as I was actually going, so at slow speeds in parking lots, my power assist would cut way back. I used the Mustang settings and my speed sensitive steering now works properly, but I have never bothered to check the exact reading vs actual mph on that car, since it doesn't effect the speedo.
post #6 of 9 (permalink) Old 06-24-2015, 05:38 PM
Draetech09's Avatar
I thought only 2003 and up Mustang automatic transmissions needed the Speedcal?
If you Fail to plan, then you plan to Fail!
I'll forever bleed Ford Blue
Drae
Draetech09 is offline
post #7 of 9 (permalink) Old 06-24-2015, 06:09 PM
1995 cougar xr7's Avatar
You defiantly need a new tune because of the speed limiter. I have 3:73 and a jmodkhku in my cougar. I changed the speedo gear to a purple one. The problem is the speedo gears don't last that long they get chewed up. The other problem you can't drive over 80 mph because of the speed limiter. It's sucks people passing you on the highway and you can't go any faster
1995 cougar xr7 is offline
post #8 of 9 (permalink) Old 06-24-2015, 09:02 PM Thread Starter
Argh, all the things I had no idea I needed.
So I need a speedcal to correct the speedometer, and I also need a tune (even with the j-mod already done) to take care of the speed limiter and shift points?
Also, is the new transmission going to shift oddly just driving around town or only at WOT?
As far as needing a tune, I heard from an SCT dealer that I can just purchase the SCT X4 and then adjust the gear ratio and remove the speed limiter right on the device. The alternative is buying the SCT 6600 chip and having a shop tune it for me. Which is the better option?
Lastly, the transmission has not yet been installed. Would it be smart of me to get the SpeedCal before hand and get the wiring done to transmission before having the transmission fully installed? If I don't have speedcal done now, is this something I can do myself later without having a lift or dropping the transmission?
lurch is offline
post #9 of 9 (permalink) Old 06-28-2015, 03:25 PM
miller1995's Avatar
The highest ratio you could run without a Speedcal would be 3.27 with a purple gear. Rule of thumb is that you can go two steps down in gear without getting too out of wack with the shift points. You are going from a 3.27 to 3.73, two steps, so a tune isn't necessary but would still be best. As stated, your speed limiter and shift points (at all throttle positions) will be affected.
I've got an older Speedcal here that I would throw in with the drive shaft. You follow the Mustang directions exactly because the wire color and connectors should be the same.
Our cars don't support adjustment of the speedometer from the EEC.
- Bryan
SOLD1998 Escort ZX2
