Trac-loc wanted - TCCoA Forums
 4Likes
  • 1 Post By Woodman
  • 1 Post By T6Rocket
  • 1 Post By JoeyICU
post #1 of 7 (permalink) Old 08-25-2016, 02:37 AM Thread Starter
Trac-loc wanted
I have a 94 tbird lx 4.6, and want posi or Trac-loc, what Ford model has it that will swap over, or can I convert mine
94_tbird is offline
post #2 of 7 (permalink) Old 08-25-2016, 09:08 AM
Woodman's Avatar
You need one set up for the IRS. The 28 spline IRS TracLoc isn't made anymore from what I recall, so you can look for ones off of older Mustang Cobras (99-04) or you can use a solid rear axle unit and leave out the C clips I think. There's a few threads on it I believe. I'll look.
If you're lucky, you can find a Thunderbird/Cougar that had it from factory, usually the SC's had them, but I think it was optional as long as you don't have ABS/Traction control on the later models.
I knew I saw this recently in another thread. Here's the details on how to convert one. http://forums.tccoa.com/960-differen...tl-irs-tl.html
And here's one of our members selling one to be converted...
http://forums.tccoa.com/20-parts-sal...-trak-lok.html
T6Rocket likes this.
Woodman is offline
post #3 of 7 (permalink) Old 08-25-2016, 09:12 AM
T6Rocket's Avatar
Thanks for the plug Woodman!
Al
Woodman likes this.
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #4 of 7 (permalink) Old 09-01-2016, 09:51 PM
Paulyrats's Avatar
Supercoupe performance sells a trac-lock for our IRS cars. Here is the direct link
https://www.supercoupeperformance.co...s-specific-599
-PAULYRATS-95-4.6L-THUNDERBIRD-LX
SVO SUPERCHARGER @ 9PSI
70MM TB,76MM MAF
30# INJECTORS, 255 LPH FUEL PUMP
SNOW PERFORMANCE METHANOL INJECTION
SCREAMIN DEMON COILS, LIVEWIRES PLUG WIRES
CUSTOM LONGTUBE HEADERS,2.5" DUAL EXHAUST
JMODDED 4R70W, 9.5 3200 STALL TC
93 MARK VIII DS, 3:73 REAR GEARS
TUBULAR REAR UPPER CONTROL ARMS
IRS REAR TORSIONAL LOAD BRACE
REAR STRUT TOWER BRACE, SCP PINION BRACE
HEAVY DUTY POLY REAR DIFF MOUNT
1.5 DROP EIBACH SPRINGS
18x9 SALEEN REPLICA WHEELS
COBRA R STYLE HOOD
Paulyrats is offline
post #5 of 7 (permalink) Old 09-12-2016, 02:10 PM
T6Rocket's Avatar
Yes, that is an option. But it is not the Ford factory part (M4204F288) like they are making it out to be, it is aftermarket.
Al
Previous Fords:
T6Rocket is offline
post #6 of 7 (permalink) Old 09-12-2016, 07:42 PM
JoeyICU's Avatar
Also as an FYI the 03-04 Cobra's where 31 spline so unless you are in the mood to change your axles, they are a no go.
Woodman likes this.
JoeyICU is offline
post #7 of 7 (permalink) Old 09-28-2016, 10:18 AM
T6Rocket's Avatar
Why I am posting this when I have one for sale, I have no idea. Mine is much cheaper though it technically is for a solid axle.
Just trying to help a fellow MN-12 owner as these are impossible to find. $60 less than what I paid for one earlier in the year. Allegedly new old stock, but do your homework.
Ford 8 8" Trac Loc 28 Spline NTO Excellent Condition M 4204 F288 | eBay
Al
Woodman likes this.
Previous Fords:
T6Rocket is offline
