Trac Lok Performance - TCCoA Forums
 2Likes
  • 1 Post By theterminator93
  • 1 Post By T6Rocket
post #1 of 18 (permalink) Old 07-20-2017, 08:04 AM Thread Starter
T6Rocket's Avatar
Okay, so after peglegging for 15 years in my 95 T-Bird, I decided my 97 would get a Trac-lok. I found a new NOS Ford unit, and had RobertP install it with Ford LSD additive. I broke it in for 500 miles before even attempting to "test" it.
All said and done, I am not happy with it's performance. It works "pretty well" on a steep, wet road, but it's dry performance is miserable. Occasionally, I have to make a sharp, right turn up a steep driveway. With the open diff, it just sat there and spun the right tire. Now, with the Trac-lok, the same fucking thing! Why isn't the left tire helping push the car? I understand I will still get the inside tire squealing, but why is it just spinning thru the clutches?
On a straight, flat road, it will leave two black marks most of the time. But if there is even the slightest crown in the road, it only spins the left, with a little fishtail to let you know the right wheel is still there. It's like it's lifting the left tire.
Which brings me to another issue: when it spins the left tire, it wheelhops. Actually, it wheelhops a little every time I try to spin the tires. Will replacing the original 69k mile LX shocks take care of that? That is the current plan.
This shit is frustrating, I thought the Trac-lok would solve all of my traction woes. Instead, it's just exposing parts that need replaced along with overall miserable dry performance unless I am on a perfectly straight, flat road.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #2 of 18 (permalink) Old 07-20-2017, 08:38 AM
Well, if you still have the factory, 20 year old bushings still in the rear, it may be bad bushings; wheel hop is more due to the BUSHINGS yielding than anything.
And if they're popping, the TL won't help much.
Fuelly
RalphP is online now
post #3 of 18 (permalink) Old 07-20-2017, 10:45 AM
I'm not sure if it's typical with these but when I had mine rebuilt the shop added extra clutches to help stiffen it up.
If you jack the rear end up, you shouldn't be able to spin one tire if you try to break the lug nuts free. If it slips there's clutch issues; even the 165,000 mile trac-lock I pulled from my father in law's 97 when we were parting it out had enough grip left to keep the tire from turning as I broke the lugs free.
And Ralph is almost certainly on the money (as usual ) about the most likely cause behind the wheelhop. Rubber bushings (even new ones) aren't going to keep you from wheelhop on these cars. Worn out bushings just makes it a whooooole lot worse. Poly bushings will help immensely.
CDsDontBurn likes this.
post #4 of 18 (permalink) Old 07-20-2017, 12:03 PM Thread Starter
T6Rocket's Avatar
The thing is, I never had wheelhop before the Trac-lok on this car, or any other MN-12 we've owned.
Exactly which bushings are you referring to - the end links, or all of them?
I was thinking it was the shocks being a little weak. I do notice this car's back end drops more than any other MN-12 we've had when you put 100+ lbs in the trunk. It drops an inch or two.
RobertP had said he used extra clutches in the past for the race cars, and that makes them wear a whole lot faster. He stopped doing it.
Al
Previous Fords:
T6Rocket is offline
post #5 of 18 (permalink) Old 07-20-2017, 01:40 PM
jco1385's Avatar
Shocks are not holding the car up, that's the springs. If it's sitting low it may be a broken or worn out spring. You can buy poly bushings for all locations in the rear with the exception of the inner-upper that adjusts the camber and the IRS subframe bushings. I run all poly and still get wheel-hop on hard acceleration.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #6 of 18 (permalink) Old 07-20-2017, 03:09 PM Thread Starter
T6Rocket's Avatar
Thanks, you just saved me a bunch of work that I wasn't going to do anyway!
Not too much is worn out on this car, has 69k miles. Front suspension was replaced. It only sits low when I put a bunch of weight in the trunk.
Al
Previous Fords:
T6Rocket is offline
post #7 of 18 (permalink) Old 07-20-2017, 03:17 PM
jco1385's Avatar
Mine squats with weight in the trunk as well. It's past the axle so it exaggerates it a bit more.
jco1385 is offline
post #8 of 18 (permalink) Old 07-20-2017, 05:47 PM
Kenz's Avatar
It sounds like you may have too much Trac-Loc additive. How much did you use and what fluid? If you use too much of that stuff it will end up acting the same as an open rear end. Most synthetic fluid now had an additive in it, you throw an entire bottle of the Ford additive in and the clutches are not going to grip very hard or at all.
96 Cougar Sport - T45 Swapped
Kenz is offline
post #9 of 18 (permalink) Old 07-21-2017, 07:13 AM Thread Starter
T6Rocket's Avatar
I will check with Rob to see if the fluid also has an additive. He did say it's the same fluid he has always used, and it was synthetic. I wasn't crazy about the fact it was the 85/140, that is a little heavy for my taste, even being synthetic.
It appears it's not easy getting the old fluid out since the diff is supported by the back cover?
Al
Previous Fords:
T6Rocket is offline
post #10 of 18 (permalink) Old 07-21-2017, 11:38 AM Thread Starter
T6Rocket's Avatar
Rob said the fluid did have the additive. I agree with Kenz that all that combined is too much additive.
What is the easiest procedure for changing the oil? Just support the diff with a jack, and remove the cover and supports?
Maybe I'll get some Lucas oil, plus the Ford additive.
Al
Previous Fords:
T6Rocket is offline
post #11 of 18 (permalink) Old 07-21-2017, 02:52 PM
Al
That's it Al. The rear support is the only one you have to worry about.
post #12 of 18 (permalink) Old 07-21-2017, 03:21 PM Thread Starter
T6Rocket's Avatar
But it appears to be tight up in there to add fluid, even with a mini-pump, even tighter than the Toyota. That's why Rob pre-filled it before installing the pumpkin, lol!
Upon doing some more research, the "experts" say having the proper Ford Trac-lok additive is the most important for the Ford diffs, and that the type of fluid used doesn't matter as much, ie: whether or not it has some infamous "additive" already in it.
Rob said these cars do tend to hop if both wheels are spinning. Anyone else get wheelhop with a Trac-lok? Our Crown Vic's solid axle Trac-lok works perfect.
I need to do more "testing" of the diff. It didn't put it in there to use as a performance diff mainly, but to help in poor traction scenarios. It did fail me once in that respect, but that was an extreme right turn up a steep concrete driveway. But it still should have made it up from a standstill instead of having to back up and getting a little momentum.
Al
Previous Fords:
T6Rocket is offline
post #13 of 18 (permalink) Old 07-21-2017, 05:33 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
On my last 3.73 used track lock I used once quart of Lucas oil stabilizer (it says no friction modifier needed) 80w90 the rest of the way. pulled it from my wrecked car and it's still waiting to be installed in my cousins mark
I'll probably run Lucas in the rear end I got from big Mike a few years ago. Can't wait to get that thing installed!
-Rob
Rob is offline
post #14 of 18 (permalink) Old 07-21-2017, 06:13 PM
Kenz's Avatar
You need to support the differential, and then remove the rear brace & cover to remove the fluid. If you have a garage, good jack, and tools it isn't too bad.
It's easy to add the fluid through the fill hole with the proper fill pump once it's all together.
I read some other Ford forums on and off. Most of the guys with Trac-Locs now are saying to run straight synthetic diff fluid; because it's normally got enough friction modifier in it already. If you need the additive you will know, you can feel the clutches pop and bind.
Next time I change mine I'm going to try running without it. If I get binding, put a 1/4 or 1/2 a bottle in. I put an entire bottle in my truck last time, and unless I'm on snow its not spinning both wheels. With my Cougar I used half, and it's grabbing pretty hard.
Kenz is offline
post #15 of 18 (permalink) Old 07-21-2017, 08:19 PM
For filling the diff, I have a tool that is basically a cylinder with a piston attached to a rod sticking out one end, and the other end has a hose that screws off. The piston holds half a quart, so you open it up, pour half a quart of gear oil in, then close it up and shove the hose in the hole and push the piston in, which pushes all the fluid into the diff, and repeat until it is full.
As for the trak-lok additive, the only purpose of that is to allow the clutches to slip some to prevent them from chattering around turns, so too much definitely could cause your issue. Once the clutches have soaked in gear oil with the friction modifier in it, they no longer need anywhere near as much of the friction modifier, if any at all. Whenever I rebuild build a diff with fresh clutches, I use conventional gear oil with the friction modifier for about 1000 miles, then drain that all out and replace it with synthetic with no friction modifier. I have never put friction modifier back into any diff unless they were brand new clutches, and I have never had any issues with it.
MadMikeyL is online now
post #16 of 18 (permalink) Old 07-31-2017, 08:53 AM Thread Starter
T6Rocket's Avatar
Well, I did some more "testing". It did so well on the straight line test, that I decided to do a donut. Ended up perfectly parked in a parking space!
Equal black marks from both sides. Not a hint of wheelhop either.
If I can get my Toyota wheels with old 28" drag radials to fit they soon will be bald!
Al
Previous Fords:
T6Rocket is offline
post #17 of 18 (permalink) Old 07-31-2017, 09:50 AM
Woodman's Avatar
Al
Based on the tire marks, I wouldn't call that "perfectly parked", LOL!
Glad that it's working though!
Woodman is offline
post #18 of 18 (permalink) Old 07-31-2017, 10:07 AM Thread Starter
T6Rocket's Avatar
That was the start, not the finish! It's hard to see how far the tracks go from the brightness.
Al
Woodman likes this.
Previous Fords:
T6Rocket is offline
