Rear end failure - TCCoA Forums
 1Likes
  • 1 Post By r429460
post #1 of 26 (permalink) Old 02-02-2018, 04:08 PM Thread Starter
r429460's Avatar
Rear end failure
I'm just wondering, has any one had the inner joint housing fail for any reason or had the
open differential carrier fail?
I haven't taken the rear end apart yet and am curious.
Also this is are Drive Shaft Shop axles.
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #2 of 26 (permalink) Old 02-02-2018, 04:34 PM
I've seen the bearings torn out; there used to be pix...
Here we go:
http://forums.tccoa.com/960-differen...t-133292.html=
Ron twisted off an axle, but that's not the same...
Post Pix; we love Car Porn, even if it's graphic.
If it's a first, we Name it after you.
Grog6 is online now
post #3 of 26 (permalink) Old 02-02-2018, 04:44 PM
Yep.
And you're running an open diff carrier? Did you weld up the spiders or something?
post #4 of 26 (permalink) Old 02-02-2018, 04:52 PM
The only problem I've had with a 8.8" open carrier wasn't the carrier's fault.
File Type: jpg 10378993_771928722703_4103835941651711650_n.jpg (97.8 KB, 3 views)
post #5 of 26 (permalink) Old 02-03-2018, 03:45 AM Thread Starter
r429460's Avatar
Mini spool.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #6 of 26 (permalink) Old 02-05-2018, 03:48 PM Thread Starter
r429460's Avatar
The inner C/V joint that went into the mini spool broke at a 45* angle in the middle of the splines.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #7 of 26 (permalink) Old 02-05-2018, 05:39 PM
AED Specialist
EECDOC's Avatar
I broke a New Raxle inner like that back in 03-04. Left side as I remember.Was using a 28 spline Detroit locker rear. Switched to a 31 spline locker and Drive Shaft shop Level 5 axles after that episode. Never a problem after that. Of course that was back in the IRS days.
95 T-Bird 4.6 Twin Screw Supercharged
10.0 Best ET and 138 Best MPH
1.44 60' time on Hoosier Drag Slicks
EECDOC is offline
post #8 of 26 (permalink) Old 02-05-2018, 06:21 PM
Chris Keggan's car experienced that at the Shootout in 2007.
IIRC, that was a Raxle halfshaft, too.
post #9 of 26 (permalink) Old 02-05-2018, 06:48 PM
I've never seen grain structure like that; TM is who I'd ask, iirc, he's a metals guy.
Is it just me, or does that look like only the center resisted, and most of the rest fractured?
Those are How Much?
At least Ron's stock axle twisted a half-turn or so before it gave.
Grog6 is online now
post #10 of 26 (permalink) Old 02-05-2018, 07:51 PM
Raxle used stock Ford stubs.
post #11 of 26 (permalink) Old 02-05-2018, 09:05 PM Thread Starter
r429460's Avatar
DSS uses stock ford inners as well.
HAs anyone switched to 31 spline inners?
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #12 of 26 (permalink) Old 02-06-2018, 04:07 AM
AED Specialist
EECDOC's Avatar
Back when I went to DSS level 5 stuff. I had to buy a set of 03-04 Cobra axles also. Had to rob the 31 spline inners to use on the Level 5's. They did not offer a complete axle at that time. Any 31 spline carrier that works in the 03-04 Cobra rear will work in your Cougar.
EECDOC is offline
post #13 of 26 (permalink) Old 02-06-2018, 12:49 PM Thread Starter
r429460's Avatar
So just go with a spool or T/L for 31 spline inners.
That is what I was thinking.
Thanks Mike.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #14 of 26 (permalink) Old 02-06-2018, 01:46 PM
MaddMartigan's Avatar
This thread is interesting to me so that's why I'm commenting/asking questions.
Based on where the unit broke, would 31 spline really make a difference? Is it because the 31 spline part is thicker than the 28 spline part?
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #15 of 26 (permalink) Old 02-06-2018, 03:09 PM
IDK about stronger, but I saw this awhile back at late model resto:
Grog6 is online now
post #16 of 26 (permalink) Old 02-06-2018, 03:15 PM
OK then. That answers my question perfectly.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #17 of 26 (permalink) Old 02-07-2018, 10:50 AM Thread Starter
r429460's Avatar
Interesting, because rock auto advertises 2001 Mustang DOHC (cobra) half shafts for $79.79 plus shipping.
Then all I need is a 31 spline T/L or Spool?
Around $500. or go all out with laddrebars, complete axle, fuel cell, etc. for $3000 to $4000.
We will see.
Plus coil over shocks and some other stuff.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #18 of 26 (permalink) Old 02-07-2018, 10:57 AM
I wouldn't trust those $79 axles. Even though they may be 31 spline, they are probably cheap metal made in china, and I doubt they will be even as strong as the stock ford parts. I believe DSS sells just the inner axle cup, still in 28 spline, but made of a much stronger material.
post #19 of 26 (permalink) Old 02-07-2018, 11:11 AM Thread Starter
r429460's Avatar
The Level 5 axles are stock Ford 28 spline inners.
Then its off to the u pull it.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #20 of 26 (permalink) Old 02-07-2018, 11:42 AM
AED Specialist
EECDOC's Avatar
900 HP Level 5 axle
This is the axle I used back in the day.
The Driveshaft Shop | FORD 2003-2004 Mustang Cobra 900HP Level 5 Bar/Outer and Hub Upgrade - Ford - Domestic Axles
Double click on above image to view full picture
Zoom Out
Zoom In
Email to a Friend
Be the first to review this product
$1,784.99
Parts need to be assembled. Please call our office for build times.
Quick Overview
Warranty: 1 year | Special Notes: Must re-use factory axle inners (inner CV's NOT included)
EECDOC is offline
post #21 of 26 (permalink) Old 02-07-2018, 12:11 PM
OK, so I realize that your axle broke at the inner but I thought that the common failure on stock half shafts was on the 28 spline outer where it went through the hub?
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #22 of 26 (permalink) Old 02-07-2018, 01:52 PM Thread Starter
r429460's Avatar
I broke three stock 28 spline outers before I went to the DSS axles.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #23 of 26 (permalink) Old 02-07-2018, 03:07 PM
OK. That makes sense. Is the breakage of the inner an indication of maybe the TL unit having an issue maybe?
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #24 of 26 (permalink) Old 02-08-2018, 08:49 AM Thread Starter
r429460's Avatar
It was a open carrier with a mini spool installed.
The splines of the inner are one inch (approx.).
The pass has some wheel spin which seemed like one tire would get traction, then the other would get traction.
This was the when the shock was applied to the inner.
All before the 60' mark.
I want to say based on no knowledge of metals, the break started on the smooth part of the inner shaft.
Pictures on tccoa facebook.
MaddMartigan likes this.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #25 of 26 (permalink) Old 02-08-2018, 10:10 AM
This powdered metal crap tends to shatter when you impact load it; I've broken transmission parts like this.
The aftermarket solution there was to use better metal; IDK what to do here.
Grog6 is online now
post #26 of 26 (permalink) Old 02-08-2018, 08:35 PM
The stubs aren't made from powdered metal.
