Considering getting 3:73 gears - TCCoA Forums
 1Likes
  • 1 Post By RalphP
post #1 of 10 (permalink) Old 03-25-2019, 06:47 PM Thread Starter
dukeofdexter's Avatar
Any reccomendations for which gear box to put in my '97 Cougar? Ive heard '03 bolts right on but I may be misremembering.. Any modifications required or should I just put gears in my OEM gear box??
Stage 2 cams will be ordered soon and very likely a torque converter to go along with..
Im thinkin 2600 stall and 3:73's from an '03 cobra, just doin research tbh
dukeofdexter is offline
post #2 of 10 (permalink) Old 03-25-2019, 06:54 PM
Talking about the rear differential right?
The 99 Cobra is the only one that bolts right in because it has the 28 spline axles like our cars.
post #3 of 10 (permalink) Old 03-25-2019, 07:03 PM Thread Starter
Thanks for the tip, I did mean differential not tranny.
Would it make more sense to just put gears in the og diff? Or would be plug and play with the '99?
post #4 of 10 (permalink) Old 03-25-2019, 08:00 PM
I'd put gears into the original diff; or build up a Mark VIII diff, your choice.
Or build up a boneyard MN12 diff; same diff. *grins* Well, the Mark VIII will be aluminum housing.
CDsDontBurn likes this.
Fuelly
RalphP is offline
post #5 of 10 (permalink) Old 03-26-2019, 07:52 AM Thread Starter
Ill keep this in mind, lookin at this project towards the end of summer maybe
post #6 of 10 (permalink) Old 03-28-2019, 05:18 PM
When I did my '96 t-bird 3.73's, I found a low-mileage cougar diff (same diff) at a local junkyard, and built it up with an Auburn LS and 3.73 gears, and then swapped when it was all complete.
If you can have your car down for as long as it'll take to swap the gears and do it "right", you could redo your existing diff. At the time, I couldn't take the downtime. And I actually still have the original diff under my bench
Actually, I think I still have the Ford LS that was in the Cougar diff, complete with side-gears.
I'm getting old
As of 3/2019:
'96 T-bird 4.6L Sport (gone a while back)
'97 Cougar 4.6L 30th Anniversary (still have)
'01 F250SD V10 4x4 (recently sold)
'18 Taurus SHO w/PP
krewat is offline
post #7 of 10 (permalink) Old 03-28-2019, 06:06 PM
Here's my two cents. I have done the gear swap plus the very hard to find TracLoc diff carrier. I paid a lot for labor, and it took like three weeks but I wasn't in a hurry. It costed more because I wanted to use genuine Ford parts. Sourced the diff from the guys at TBSC on the net. Unfortunately once taken apart found parts to be not in good condition. So we replaced all parts with Motorcraft. I could have gone with a pre-assembled Auburn diff from Randy's Ring and Gear for far less and bought the new gear set and get it dialed in by a shop For less than I paid would be my suggestion.
If anyone is interested in a 3:27 ring and pinion, name you price.
Philippe Mentor
Philippe Mentor is offline
post #8 of 10 (permalink) Old 03-28-2019, 06:09 PM
Oh yeah, don't forget to buy a new 21 tooth Speedo gear and retainer clip for the 4R70W automatic. Buy Motorcraft!
Philippe Mentor
post #9 of 10 (permalink) Old 04-05-2019, 05:53 PM
I've seen a 28-spline TL diff for sale on super coupe performance, going for around $400. Anyone know anything about that? Says it's supposed to be a direct replacement for the coog/tb IRS diff.
muhfreedom1776 is offline
post #10 of 10 (permalink) Old 04-06-2019, 08:46 AM
T6Rocket's Avatar
The SCP unit is not a Ford unit, I think it's Yukon. It will work, but will need all the clearances checked once installed. Which most people do anyway.
The Ford unit is a direct drop-in, but it is a crap shoot whether you're getting the newer IRS compatible one or the solid axle one, since the part # is the same. It took me two tries to get an IRS one.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is online now
Similar Threads
Considering getting in to tbird/cougars again LiNkInPaRkFaN4LiFe Newbie Forum 4 10-23-2007 08:13 PM
Im considering getting rid of cable internet. lightevergreenfrost Miscellaneous 22 05-05-2006 03:54 PM
3.73 gears....Do I need to get a speedo gear or.. 95zr7 General Tech 3 08-25-2002 11:16 PM
questions about 3.73 gears with allen supercharger blown96bird Drive Train 6 08-23-2002 08:43 AM
3.73 gears Tx_Cat Drive Train 24 08-09-2002 06:07 AM
