sway bar - TCCoA Forums
post #1 of 6 (permalink) Old 01-26-2011, 06:22 PM Thread Starter
thunderclaw's Avatar
sway bar
how in the hell do you pull the front sway bar off the car. is there a way? it sandwiched between the k-member and the cars frame.
thunderclaw is offline
post #2 of 6 (permalink) Old 01-26-2011, 08:09 PM
You have to lower the K member as per the tech articles
post #3 of 6 (permalink) Old 01-26-2011, 08:36 PM
1996Project-bird's Avatar
Gotta love them tech articles that few have taken the time to read. I think I've read every article in there thoroughly and I must say there is a TON of great info in there.
1996Project-bird is offline
post #4 of 6 (permalink) Old 01-26-2011, 08:39 PM
Or just drop the whole K member completely and "while you're there", replace the oil pan gasket, oil filter adapter gasket, front seal (might as well go with underdrive pulleys...), replace the starter, replace the motor mounts, replace the lower radiator hose, and completely rebuild the front suspension.
It is AMAZING how much you can get done while the K member is out of the way. Yeah, a "little pricy" , but sooner or later you're going to have to do all of those things anyway...
69 F100 LWB w/460 Engine
post #5 of 6 (permalink) Old 01-26-2011, 09:09 PM
KorpseofDeath's Avatar
Send a message via AIM to KorpseofDeath
A+ to that. I needed my oil pan gasket replaced, and my suspension needed rebuild. I just dropped my K member while holding the engine in the bay, and replaced all my seals and gaskets + front suspension, probably the best and easiest way to do everything all at once.
~1997 TBIRD 4.6L LX SPORT ~ Xenon Kit ~ 149K Miles ~ K&N ~ JMOD ~ Daily Driver
~1991 TBIRD 5.0L HO ~ Completely Stock ~
KorpseofDeath is offline
post #6 of 6 (permalink) Old 02-12-2011, 10:16 AM
Got the sway bars front and rear......absolutely love them!!!!!
97 MD SILVERSTREAK is offline
